We imported a DG-505 Elan Orion built at the AMS Flight, d.o.o. (AMS)
factory in Slovenia in 2006. It came with a Slovenian Certificate of Airworthiness and an AMS data plate. It was built under a German Standard Airworthiness Certificate which designates AMS in Slovenia as the manufacturer. DG is the owner of the European Standard Flight Certificate. At the time of import the U.S. Standard Type Certificate designated the DG factory in Germany as the only acceptable manufacturer making no mention of AMS in Slovenia. To correct this situation the Small Aircraft Directorate at the FAA for gliders rewrote the type certificate to make AMS in Slovenia an acceptable manufacturer. This in part allowed the glider to receive a U.S. Standard Airworthiness Certificate. Also the glider did not have a German certificate of airworthiness but only a Slovenian certificate of airworthiness. AMS had not sent the aircraft to Germany to receive a German certificate of airworthiness. The FAA was initially demanding a German airworthiness certificate but again the FAA directorate modified the U.S. certificate to make any EASA (the new European Union aviation administration) member nation as an acceptable supplier of an airworthiness certificate. Because Slovenia was on the cusp of being a member of EASA in 2006 (and now is a full member) the designated airworthiness representative granted the U.S. Standard Airworthiness Certificate. Now 2 years later the FAA has told us its own actions were a mistake and is about to revoke the standard airworthiness certificate if we do not relinquish it freely. The FAA is saying that the changes to the U.S. certificate that were made by the directorate in Kansas City were in error. They are indicating that they did not realize that Elan aircraft were not built in Germany and because the FAA has no bilateral agreement (BASA) with Slovenia the certificate must be relinquished. Can the FAA do this at this late date? DG and AMS have not been willing to resolve this issue and have basically said that the only alternative is for us to ship the aircraft back to Germany and have the aircraft reissued at our own expense. Thanks for any help! N505LG |
On Oct 17, 4:06*pm, NG wrote:
We imported a DG-505 Elan Orion built at the AMS Flight, d.o.o. (AMS) factory in Slovenia in 2006. *It came with a Slovenian Certificate of Airworthiness and an AMS data plate. *It was built under a German Standard Airworthiness Certificate which designates AMS in Slovenia as the manufacturer. *DG is the owner of the European Standard Flight Certificate. At the time of import the U.S. Standard Type Certificate designated the DG factory in Germany as the only acceptable manufacturer making no mention of AMS in Slovenia. *To correct this situation the Small Aircraft Directorate at the FAA for gliders rewrote the type certificate to make AMS in Slovenia an acceptable manufacturer. *This in part allowed the glider to receive a U.S. Standard Airworthiness Certificate. Also the glider did not have a German certificate of airworthiness but only a Slovenian certificate of airworthiness. *AMS had not sent the aircraft to Germany to receive a German certificate of airworthiness. The FAA was initially demanding a German airworthiness certificate but again the FAA directorate modified the U.S. certificate to make any EASA (the new European Union aviation administration) member nation as an acceptable supplier of an airworthiness certificate. *Because Slovenia was on the cusp of being a member of EASA in 2006 (and now is a full member) the designated airworthiness representative granted the U.S. Standard Airworthiness Certificate. Now 2 years later the FAA has told us its own actions were a mistake and is about to revoke the standard airworthiness certificate if we do not relinquish it freely. *The FAA is saying that the changes to the U.S. certificate that were made by the directorate in Kansas City were in error. * They are indicating that they did not realize that Elan aircraft were not built in Germany and because the FAA has no bilateral agreement (BASA) with Slovenia the certificate must be relinquished. Can the FAA do this at this late date? *DG and AMS have not been willing to resolve this issue and have basically said that the only alternative is for us to ship the aircraft back to Germany and have the aircraft reissued at our own expense. Thanks for any help! N505LG Is there a reason (e.g. commercial use?) you cannot go experimental racing/exhibition. Otherwise I'd suggest taking your problem to an aviation lawyer. AOPA legal services may be a good place to start. Darryl |
...DG and AMS have not been willing to resolve this issue and have basically said that the only alternative is for us to ship the aircraft back to Germany and have the aircraft reissued at our own expense. Just curious, did you buy the ship through one of their dealers, and if so, what do they have to say about this situation? Bob K. |
On Oct 17, 5:06*pm, NG wrote:
We imported a DG-505 Elan Orion built at the AMS Flight, d.o.o. (AMS) factory in Slovenia in 2006. *It came with a Slovenian Certificate of Airworthiness and an AMS data plate. *It was built under a German Standard Airworthiness Certificate which designates AMS in Slovenia as the manufacturer. *DG is the owner of the European Standard Flight Certificate. At the time of import the U.S. Standard Type Certificate designated the DG factory in Germany as the only acceptable manufacturer making no mention of AMS in Slovenia. *To correct this situation the Small Aircraft Directorate at the FAA for gliders rewrote the type certificate to make AMS in Slovenia an acceptable manufacturer. *This in part allowed the glider to receive a U.S. Standard Airworthiness Certificate. Also the glider did not have a German certificate of airworthiness but only a Slovenian certificate of airworthiness. *AMS had not sent the aircraft to Germany to receive a German certificate of airworthiness. The FAA was initially demanding a German airworthiness certificate but again the FAA directorate modified the U.S. certificate to make any EASA (the new European Union aviation administration) member nation as an acceptable supplier of an airworthiness certificate. *Because Slovenia was on the cusp of being a member of EASA in 2006 (and now is a full member) the designated airworthiness representative granted the U.S. Standard Airworthiness Certificate. Now 2 years later the FAA has told us its own actions were a mistake and is about to revoke the standard airworthiness certificate if we do not relinquish it freely. *The FAA is saying that the changes to the U.S. certificate that were made by the directorate in Kansas City were in error. * They are indicating that they did not realize that Elan aircraft were not built in Germany and because the FAA has no bilateral agreement (BASA) with Slovenia the certificate must be relinquished. Can the FAA do this at this late date? *DG and AMS have not been willing to resolve this issue and have basically said that the only alternative is for us to ship the aircraft back to Germany and have the aircraft reissued at our own expense. Thanks for any help! N505LG Appear to be four in the US. You might also advise the FAA Governmental Liaison Committee if you haven't already done so. Frank Whiteley |
On Oct 17, 11:47*pm, Frank Whiteley wrote:
On Oct 17, 5:06*pm, NG wrote: We imported a DG-505 Elan Orion built at the AMS Flight, d.o.o. (AMS) factory in Slovenia in 2006. *It came with a Slovenian Certificate of Airworthiness and an AMS data plate. *It was built under a German Standard Airworthiness Certificate which designates AMS in Slovenia as the manufacturer. *DG is the owner of the European Standard Flight Certificate. At the time of import the U.S. Standard Type Certificate designated the DG factory in Germany as the only acceptable manufacturer making no mention of AMS in Slovenia. *To correct this situation the Small Aircraft Directorate at the FAA for gliders rewrote the type certificate to make AMS in Slovenia an acceptable manufacturer. *This in part allowed the glider to receive a U.S. Standard Airworthiness Certificate. Also the glider did not have a German certificate of airworthiness but only a Slovenian certificate of airworthiness. *AMS had not sent the aircraft to Germany to receive a German certificate of airworthiness. The FAA was initially demanding a German airworthiness certificate but again the FAA directorate modified the U.S. certificate to make any EASA (the new European Union aviation administration) member nation as an acceptable supplier of an airworthiness certificate. *Because Slovenia was on the cusp of being a member of EASA in 2006 (and now is a full member) the designated airworthiness representative granted the U.S. Standard Airworthiness Certificate. Now 2 years later the FAA has told us its own actions were a mistake and is about to revoke the standard airworthiness certificate if we do not relinquish it freely. *The FAA is saying that the changes to the U.S. certificate that were made by the directorate in Kansas City were in error. * They are indicating that they did not realize that Elan aircraft were not built in Germany and because the FAA has no bilateral agreement (BASA) with Slovenia the certificate must be relinquished. Can the FAA do this at this late date? *DG and AMS have not been willing to resolve this issue and have basically said that the only alternative is for us to ship the aircraft back to Germany and have the aircraft reissued at our own expense. Thanks for any help! N505LG Appear to be four in the US. *You might also advise the FAA Governmental Liaison Committee if you haven't already done so. Frank Whiteley Sorry, meant SSA Governmental Liaison Committee. |
First the problems with the DG-300 spars, and now the DG-505
paperwork. In both cases DG apparently feel that they are absolved of any responsibility to their customers--and have little concern for future sales, apparently. Fine airplanes, as a rule: damn poor attitude, though. Have DG never heard of customer support after the sale? There must be people here in the US who would be willing to help US owners of both types sort through these problems with minimal cost and frustration, if DG would be willing to do their part to coordinate. Expecting customers to ship a glider back to Europe at the owner's expense to solve factory production or government paperwork problems, is not a foundation on which to build trust. Perhaps they should remember that designing good aircraft is only one part of the business. The FAA have their own problems, of course. How nice it would be if DG could show it is on a higher plane. Jack |
On Oct 17, 10:56*pm, Jack wrote:
First the problems with the DG-300 spars, and now the DG-505 paperwork. In both cases DG apparently feel that they are absolved of any responsibility to their customers--and have little concern for future sales, apparently. Fine airplanes, as a rule: damn poor attitude, though. Have DG never heard of customer support after the sale? There must be people here in the US who would be willing to help US owners of both types sort through these problems with minimal cost and frustration, if DG would be willing to do their part to coordinate. Expecting customers to ship a glider back to Europe at the owner's expense to solve factory production or government paperwork problems, is not a foundation on which to build trust. Perhaps they should remember that designing good aircraft is only one part of the business. The FAA have their own problems, of course. How nice it would be if DG could show it is on a higher plane. Jack After sale? DG did not make a sale here. From what I can see based on the registration date of this glider this was likely sold by a US Dealer of AMS Flight. DG was not involved. If the USA Dealer or AMS Flight stated the aircraft was type certificated in the USA they should fix the issue. Maybe the AMS dealer was sloppy or unaware of an issue (but they ought to still help fix it), maybe he thought it would be registered as experimntal. First question again is does the glider need to be type certificated or will experimental do. It looks like it is registered to two individual owners, if it's just for private flying then stop all the hassle now and go experimental. If the problem was the glider needed a real live German certificate of airworthiness at time of import then it may well be that DG cannot just go and retroactively do paperwork to fix this. Maybe time to get am aviation lawyer involved. Of course if it turns out that DG can do something and is just sitting on their hands it's a different matter, but until somebody knows for sure... Darryl |
On Oct 17, 10:47*pm, Frank Whiteley wrote:
On Oct 17, 5:06*pm, NG wrote: We imported a DG-505 Elan Orion built at the AMS Flight, d.o.o. (AMS) factory in Slovenia in 2006. *It came with a Slovenian Certificate of Airworthiness and an AMS data plate. *It was built under a German Standard Airworthiness Certificate which designates AMS in Slovenia as the manufacturer. *DG is the owner of the European Standard Flight Certificate. At the time of import the U.S. Standard Type Certificate designated the DG factory in Germany as the only acceptable manufacturer making no mention of AMS in Slovenia. *To correct this situation the Small Aircraft Directorate at the FAA for gliders rewrote the type certificate to make AMS in Slovenia an acceptable manufacturer. *This in part allowed the glider to receive a U.S. Standard Airworthiness Certificate. Also the glider did not have a German certificate of airworthiness but only a Slovenian certificate of airworthiness. *AMS had not sent the aircraft to Germany to receive a German certificate of airworthiness. The FAA was initially demanding a German airworthiness certificate but again the FAA directorate modified the U.S. certificate to make any EASA (the new European Union aviation administration) member nation as an acceptable supplier of an airworthiness certificate. *Because Slovenia was on the cusp of being a member of EASA in 2006 (and now is a full member) the designated airworthiness representative granted the U.S. Standard Airworthiness Certificate. Now 2 years later the FAA has told us its own actions were a mistake and is about to revoke the standard airworthiness certificate if we do not relinquish it freely. *The FAA is saying that the changes to the U.S. certificate that were made by the directorate in Kansas City were in error. * They are indicating that they did not realize that Elan aircraft were not built in Germany and because the FAA has no bilateral agreement (BASA) with Slovenia the certificate must be relinquished. Can the FAA do this at this late date? *DG and AMS have not been willing to resolve this issue and have basically said that the only alternative is for us to ship the aircraft back to Germany and have the aircraft reissued at our own expense. Thanks for any help! N505LG Appear to be four in the US. *You might also advise the FAA Governmental Liaison Committee if you haven't already done so. Frank Whiteley There are more than four, there are over 20 DG-500/DG-505/DG-500M etc. variants in the USA and they list different permutations of manufactures. The FAA database for these gliders looks a bit of a mess if you try to match dates/claimed manufacturers etc. Darryl |
The glider was purchased for private use but keeping the standard
certification would be paramount to its resale value. This was recognized by the small aircraft directorate at the FAA in Kansas City and is part of the reason that the U.S. type certificate was modified in 2006 (see above). As an experimental the aircraft cannot be used for commercial rides. When giving rides for fun and not for pay as we always do we will have to announce to the passenger that this is an experimental and as such does not have the safety of a standard certified aircraft. We will be limited to a 300 mile range of usual activity. We cannot fly over populated areas (Phoenix suburbs). Without requesting and receiving written permission from the FAA we will not be able to fly outside of the 300 mile radius of a stated home base in a usual manner. The aircraft was purchased from AMS directly. At the time of the initial certification problems we contacted DG and purchased a 2 way ticket for a DG/German FAA inspector to come to the U.S. to inspect and place a German airworthiness certificate on the aircraft. We paid a special German FAA (LBA) fee for after factory inspection, bought the airline ticket, and 4 days hotel fees. When the FAA decided to grant the standard certificate without jumping through this hoop we called off the inspector but lost all this money since none of it was refundable (expedia ticket and reservations). Now Mr. Dirks and Mr. Weber at DG have stated that the only way to fix the problem is to send the aircraft back to Germany apparently for re- issue. We feel that the AMS and DG oversight to distribute the aircraft with proper paperwork to meet standard certification as agreed upon in the purchase deal, and the flip flopping of the FAA 2 years after the fact has placed an undo burden on us as buyers. |
On Oct 18, 1:03*am, Darryl Ramm wrote:
On Oct 17, 10:47*pm, Frank Whiteley wrote: On Oct 17, 5:06*pm, NG wrote: We imported a DG-505 Elan Orion built at the AMS Flight, d.o.o. (AMS) factory in Slovenia in 2006. *It came with a Slovenian Certificate of Airworthiness and an AMS data plate. *It was built under a German Standard Airworthiness Certificate which designates AMS in Slovenia as the manufacturer. *DG is the owner of the European Standard Flight Certificate. At the time of import the U.S. Standard Type Certificate designated the DG factory in Germany as the only acceptable manufacturer making no mention of AMS in Slovenia. *To correct this situation the Small Aircraft Directorate at the FAA for gliders rewrote the type certificate to make AMS in Slovenia an acceptable manufacturer. *This in part allowed the glider to receive a U.S. Standard Airworthiness Certificate. Also the glider did not have a German certificate of airworthiness but only a Slovenian certificate of airworthiness. *AMS had not sent the aircraft to Germany to receive a German certificate of airworthiness. The FAA was initially demanding a German airworthiness certificate but again the FAA directorate modified the U.S. certificate to make any EASA (the new European Union aviation administration) member nation as an acceptable supplier of an airworthiness certificate. *Because Slovenia was on the cusp of being a member of EASA in 2006 (and now is a full member) the designated airworthiness representative granted the U.S. Standard Airworthiness Certificate. Now 2 years later the FAA has told us its own actions were a mistake and is about to revoke the standard airworthiness certificate if we do not relinquish it freely. *The FAA is saying that the changes to the U.S. certificate that were made by the directorate in Kansas City were in error. * They are indicating that they did not realize that Elan aircraft were not built in Germany and because the FAA has no bilateral agreement (BASA) with Slovenia the certificate must be relinquished. Can the FAA do this at this late date? *DG and AMS have not been willing to resolve this issue and have basically said that the only alternative is for us to ship the aircraft back to Germany and have the aircraft reissued at our own expense. Thanks for any help! N505LG Appear to be four in the US. *You might also advise the FAA Governmental Liaison Committee if you haven't already done so. Frank Whiteley There are more than four, there are over 20 DG-500/DG-505/DG-500M etc. variants in the USA and they list different permutations of manufactures. The FAA database for these gliders looks a bit of a mess if you try to match dates/claimed manufacturers etc. Darryl FWIW, there are only four (DG505KK, DG505KM, DG505LG, and DG505PB) with the same aircraft code as AMS production, 3802559, all DG 505's AKA DG500 Elan Orion. I've been in contact with a club that has another. They had been called and had to go over their paperwork as the FAA had said one entered the US without the German inspection. Looks like they were looking for indications of other problems. Whether it was FAA CYA...who knows? If they called about other DG5XX variants, then it sounds like findings from an internal audit. Too bad, as the next NG post indicates they may have lost an opportunity to correct it with a post import German inspection, or not, as the factory is requesting return for re-issue. AOPA may know of precedents. Frank |
| Thread Tools | |
| Display Modes | |
| Airworthiness Certificate Replacement? | [email protected] | Soaring | 6 | June 26th 08 08:11 PM |
| TBO and airworthiness | Jim Stewart | Owning | 26 | April 17th 07 06:05 PM |
| USA Glider Experimental Airworthiness Certificate | charlie foxtrot | Soaring | 4 | April 15th 06 06:04 AM |
| Exhibition/Racing Airworthiness Certificate Question | bsquared | Soaring | 5 | June 22nd 04 07:24 PM |
| Airworthiness Directives for Jantar Standard 3 | Miguel Lavalle | Soaring | 5 | January 24th 04 11:55 AM |
