iPaq screen reflections - anyone really happy with their solution?
Old December 2nd 03, 12:51 AM
Jim Kelly
Default iPaq screen reflections - anyone really happy with their solution?
Greetings!
Summer has begun down under, and my first flight with an iPaq
reminded me just how bad the reflections are in bright light . . .
sooo hard to read, especially when wearing sunglasses.
Were there any solutions that worked well for you Northerners this
season??
I have noted a film from Brando at:
http://shop.brando.com.hk/screenprotector.php
(not much reference to stopping reflections though)
.. . and ClearTouch as sold by Richard at CraggyAero:
http://www.craggyaero.com/screen_protectors.htm
http://www.boxwave.com/products/clea...t3_ipaq_39.htm
Perhaps Paul Remde, and others have solutions too?
Anything found to work REALLY well??
Any comments??
Thanks.
Best regards,
Jim Kelly
Old December 2nd 03, 03:21 AM
HL Falbaum
The ClearTouch is easy to apply and works better than the WriteRight by
Fellows. I use blue blocking sunglasses and the bluish backlight from my
3955 is attenuated somewhat. It is functional, but frankly I was
disappointed in the overall image. I like my 1550 better but Winpilot
stopped supporting it. I have had a few flights with the SN10-the screen
visibility is very good, but the overall unit would take some time to
learn.
Overall, it is not as pretty as I wished, but it is useable, and the
ClearTouch does cut the reflections, by spreading them out and 'defocusing'
them. A slight tilt of the swivel mount helps somewhat. (Mine is mounted in
the center of the panel and close to it)
I am considering a black velvet 'bib' as the next step, to cut reflections
from the shirt and chute hardware.
Hartley Falbaum
ASW27B "KF" USA
"Jim Kelly" wrote in message
u...
Greetings!
season??
Any comments??
Thanks.
Best regards,
Jim Kelly
Old December 2nd 03, 04:11 AM
Jim Kelly
'defocusing'
mounted in
Sounds like ClearTouch "sort of" works, ie 'better than nothing'.
Anyone found a better product??
reflections
This has proven to work by one of our Aussie WinPilot gliding gurus.
Black is not the coolest choice to wear though!!
Thanks,
Old December 2nd 03, 05:28 AM
Marc Ramsey
I had a quick look at an iPaq with ClearTouch in direct sunlight, and it
was noticeably better than the screen protectors I have been using
(Micro Writeguards), which in turn were better than anything else I'd
found...
Marc
Old December 2nd 03, 06:06 AM
F.L. Whiteley
I hear there will be a shift in displays tech in the next few months that
should make these current kits obsolete.
"Marc Ramsey" wrote in message
. com...
found...
Marc
Old December 2nd 03, 06:29 AM
Marc Ramsey
Organic LED (OLED) and/or electronic ink technology has been supposed to
take over "real soon now" for a number of years. OLEDs use discrete
light emitters at each pixel, giving good contrast with no backlight
needed. Electronic ink uses tiny particles for pixels, electrically
flipping them between light and dark sides, which supposedly provides
contrast comparable to ink on paper.
As I remember, exactly one cellphone briefly made it onto the market
last spring with an OLED display. Apparently, OLEDs and e-ink still
have problems which need to be solved...
Marc
Old December 2nd 03, 10:36 AM
Steve Hopkins
Didn't someone develop an "eye piece", worn over one eye and linked to
the visual output of a PDA? The article, (long since lost in the bowels
of this computer), portrayed a view of the countryside as seen by the
pilot and, overlaid on this, was the GPS data and output from an
electrical Artificial Horizon. If anyone remembers this, could they post
the link?
Steve
-----Original Message-----
Sent: Tuesday, December 02, 2003 1:05 AM
To: Steve Hopkins
Subject: [r.a.s] iPaq screen reflections - anyone really happy with
their solution?
Newsgroup: rec.aviation.soaring
Subject: iPaq screen reflections - anyone really happy with their
solution?
Author: Jim Kelly
Date/Time: 01:00 02 December 2003
Greetings!
Summer has begun down under, and my first flight with an iPaq reminded
me just how bad the reflections are in bright light . . . sooo hard to
season??
Any comments??
Thanks.
Best regards,
Jim Kelly
Old December 2nd 03, 01:37 PM
tango4
These things are known as 'enhanced reality' displays. Much more practical
than HUDIS ( Fixed colimator projected head up display ) since in a
sailplane one needs to be looking about all the time.
I have seen a few at shows. Most are a complete waste of time in terms of
resolution, power drain and interface capabilities or are simply too large
to get onto your head with the canopy closed!
http://www.crd.ge.com/esl/cgsp/projects/er/
Ian
Old December 3rd 03, 03:33 PM
JohnD
I started using my Ipaq last spring and had a lot of trouble with
glare. Definitely not as good a view as with my Compaq Aero. Tried a
black glare shield, not much help. Then the ClearTouch Richard
suggested. Much better. But in order to use the Ipaq effectively and
easily I had to turn off the color.
In B&W it is easy to read. Too bad, spent all that money on an
Ipaq.....
"tango4" wrote in message ...
Ian
Old December 3rd 03, 10:03 PM
Paul Remde
Hi,
How did you "turn off the color"?
Paul Remde
"JohnD" wrote in message
om...
Ipaq.....
practical
of
large
Ian
Calling all aviation enthusiasts – this is your chance to see two classic RAF movies on the big screen (Hull - Yorkshire). Phillip Rhodes Military Aviation 0 September 7th 04 01:30 PM
Ipaq - GPS_Log Help needed (Long) Steve B Soaring 1 September 27th 03 06:00 AM
iPAQ h2210/h2215 Review Paul Remde Soaring 0 September 3rd 03 03:45 AM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 09:25 AM
iPaq screen viewability Raphael Warshaw Soaring 7 July 27th 03 06:02 PM
