Ipaq - GPS_Log Help needed (Long)
Old September 27th 03, 05:55 AM
Steve B
Default Ipaq - GPS_Log Help needed (Long)
Bingo... a fine gentelman pointed me to the need to set the Garmin to NMEA Out only.
Now it works like a charm!
Thanks folks
(Steve B) wrote in message om...
Question 1
I connect 3955 to a PC via ActiveSync cradle using my 9pin cable. With
my Garmin 195. The Garmin has:
Pin 1 - Ground = Black
Pin 4 - NMEA out = Blue
Pin 5 - NMEA in = Brown
Then pin 5,2 and 3 on that connector. 5 is ground. I connect: black-5,
blue-3 and brown-2 on the female PDA cable pin 3 receives data (in),
pin 2 sends data (out).
I made certain that in the NMEA setup dialog the "Use RX_FLAG"
checkbox is cleared. I use the RMC code and do all my testing outdoors
on real GPS signal, as I understand the GPS may mark "emulator" data
invalid. I set data rate to 4800. I have tried to do serial port
testing indoors with enable raw data logging in logging options. When
enabled, all data coming in on serial port are logged to a
rawGPS_LOGdata##!!.txt file
But the file shows 0 bytes.
Once I get NMEA data into that file, I should expect program to work
with above settings on real GPS data.
The pins on the ipaq female connector looking at the connector plug I
assume are as follows:
_______
\ 54321/
\9876/
So I connected:
Pin 1 to 5 on female
Pin 4 to 2 on female
Pin 5 to 3 on female of Ipaq
I checked the Garmin and it is set Inpt / output to Data Transfer
and
Slave mode
The Ipaq is set to
setup / NMEA to RMC and (check length) is checked and port is Com 1
Question # 2
I also purchased a generic data cable for the Ipac
The generic cable has 4 wires as follows:
Pins 1 to 22
2 = Red = Power? I am not using this lead
7 = White = Tx or Rx ???
8 = Yellow = Rx or Tx ???
22 = Blue = Ground ???
I could not get it to work with this either... do you know where I
can find the pinouts for the Ipaq 3900 that would show pins 1 to 22?
Any help on how I can I trouble shoot the problem would be greatly
appreciated.
Thanks in advance
Steve
Ps? (just shoot me if I cant get this thing to work)
Old September 27th 03, 07:00 AM
Larry Goddard
Steve,
I will take a look at this on Monday and pull out my tech manuals. We can
get it figured out.
Larry Goddard
"01" USA
See our ::Goddard:: cables at www.cumulus-soaring.com
Steve B wrote:
Question 1
_______
\ 54321/
\9876/
So I connected:
and
Slave mode
The Ipaq is set to
Question # 2
Pins 1 to 22
appreciated.
Thanks in advance
Steve
Ps… (just shoot me if I cant get this thing to work)
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 06:07 PM
Flight test update - long nauga Home Built 1 June 5th 04 04:09 AM
SWRFI Pirep.. (long) Dave S Home Built 20 May 21st 04 04:02 PM
Simpy One of Many Stories of a Time Not So Long Ago Badwater Bill Home Built 40 March 16th 04 07:35 PM
IFR Long X/C and the Specter of Expectations David B. Cole Instrument Flight Rules 0 February 24th 04 08:51 PM
