I have an interesting radio problem hopefully one of you have solved... My transmitted audio signal is clipping. It 'breaks up' intermittently during the transmit cycle. After many hours of checking everything, I found an interesting correlation. When the radio squelch circuit is turned off (via front switch), it transmits just fine - perfect clarity. When the squelch circuit is turned on (switch all the way up), it is intermittent. I adjusted the squelch pot several times with no change in the results. I don't understand how the squelch circuit is affecting the transmit side of the radio. Anyone come across this? Have a solution?
Is the power source to test it a regulated power supply or battery? Monitor the voltage at receive, receive with squelch open and during transmit. In our Dittel portable field/mobile unit with a charger and internal nicads, it behaved similarly until both the regulator chip and nicads were replaced. Nothing to do with the squelch setting except that tiny change in milli amps draw. Assume you already looked at the tx signal "clipping" on comm monitor. Good luck. Hope its something simple.
I'm using batteries. two 7AH in parallel. There should be no issues w.r.t.. battery. I also turned off all other components and it still behaved the same. I have not tried measuring the current draw. I'll try that to see the difference. but then, what would be the solution assuming the batteries are good?
On Tuesday, June 20, 2017 at 8:36:17 AM UTC-7, ZP wrote:
I'm using batteries. two 7AH in parallel. There should be no issues w.r..t. battery. I also turned off all other components and it still behaved the same. I have not tried measuring the current draw. I'll try that to see the difference. but then, what would be the solution assuming the batteries are good? ZP, the squelch correlation is as you say interesting. You could spend time and money on 35-year-old electronics or pick up a replacement FSG60M for 50 Euros plus shipping. Even a newer 25kHz radio like Dittel FSG71M or Becker AR3201 will not be much more than that, but you'd need to build a panel adapter and change the multipin connector. http://www.segelflug.de/osclass/inde...&sCategory=110 Jim |
![]() http://www.segelflug.de/osclass/inde...&sCategory=110 Jim Jim, I'd like to buy the FSG-60M, but can't figure out to do that. I live in the US. |
On Wednesday, June 28, 2017 at 4:01:43 PM UTC-7, ZP wrote:
http://www.segelflug.de/osclass/inde...&sCategory=110 Jim Jim, I'd like to buy the FSG-60M, but can't figure out to do that. I live in the US. PM sent. Jim |
thanks!
Dittel Fsg-5 radio | [email protected] | Soaring | 0 | July 21st 16 06:24 PM |
Dittel FGS50 issue and OAT Indicator | [email protected] | Soaring | 1 | August 16th 12 11:13 AM |
reversed polarity to Dittel issue | Sam Zimmerman | Soaring | 5 | April 16th 10 02:56 AM |
Wanted: Walter Dittel FSG60M | [email protected] | Soaring | 0 | April 21st 08 02:06 AM |
Dittel FSG60M radio and cradle for sale | [email protected] | Soaring | 2 | May 9th 06 09:08 AM |
