Dittel FGS50 issue and OAT Indicator
Old August 16th 12, 06:51 AM posted to rec.aviation.soaring
Default Dittel FGS50 issue and OAT Indicator
All,
I wanted to check if anyone has seen this problem before with a Walter Dittel FGS50: When I power up the display shows 188.888 and will not transmit nor receive.
If RAS fails I'll call Peninsula Avionics.
Also, I'm looking for a source for 2 glider specific items.
1) The vertical bar style outside air temperature indicator.
2) Blue spoiler handle - cross country ski pole style.
BK and 2Y
Old August 16th 12, 11:13 AM posted to rec.aviation.soaring
Bob
Same problem with the display on my FGS50, but it does still transmit and receive. Please post if you come up with a solution.
Thanks..
Dittel FSG 50 Karl Kunz[_2_] Soaring 6 June 25th 12 12:21 AM
reversed polarity to Dittel issue Sam Zimmerman Soaring 5 April 16th 10 02:56 AM
Dittel FSG 50 in Dittel base station [email protected] Soaring 2 February 18th 09 09:15 AM
Dittel FSG 50 in Dittel base station, Perfect for crews and FBO [email protected] Soaring 1 February 18th 09 09:15 AM
Dittel FSG 15 A. Wolfert Soaring 0 December 18th 04 01:14 PM
