My Twin Lark (located in West Virginia) needs its shock absorber repaired/overhauled or replaced (it's fully depleted and a nitrogen re-charge did not help). I've received help from others so far, but welcome additional insight, sources, recommendations, etc. on either repairing or replacing this shock absorber quickly. Thanks in advance.
-Brian |
On Friday, 28 July 2017 15:11:26 UTC+1, wrote:
My Twin Lark (located in West Virginia) needs its shock absorber repaired/overhauled or replaced (it's fully depleted and a nitrogen re-charge did not help). I've received help from others so far, but welcome additional insight, sources, recommendations, etc. on either repairing or replacing this shock absorber quickly. Thanks in advance. -Brian Brian, I obtained a few Blanik shock absorbers in good condition, after the aircraft were scrapped ( mainspar issue). I fitted one to my IS28B2 -Lark quite easily, it only needed the filling valve to be exchanged ( they face in different directions. I would advise using a new copper sealing washer if you do change the valve over). The Lark unit is the same as the Blanik unit, except for this difference. I suggest you either obtain one similarly. The Blanik dealer in USA ( I have forgotten his name) should be able to provide new seals if you want to refurbish it yourself, though I would ask him to do this for you. I was offered some new shock absorber units recently, if you wish I can dig out the contact. Best wishes. Pete |
My Twin Lark (located in West Virginia) needs its shock absorber repaired/overhauled or replaced (it's fully depleted and a nitrogen re-charge did not help). I've received help from others so far, but welcome additional insight, sources, recommendations, etc. on either repairing or replacing this shock absorber quickly. Thanks in advance. -Brian Brian, some further info. Pacific aerosport can sell you a seal kit. This is the part number for the Blank shock absorber Seal Kit for shock absorber P/N: 9064N L13.BA-01- |
On Friday, July 28, 2017 at 10:11:26 AM UTC-4, wrote:
My Twin Lark (located in West Virginia) needs its shock absorber repaired/overhauled or replaced (it's fully depleted and a nitrogen re-charge did not help). I've received help from others so far, but welcome additional insight, sources, recommendations, etc. on either repairing or replacing this shock absorber quickly. Thanks in advance. -Brian Hey, can I piggyback on this post please? I have an IS-29 D2 Lark and the shock absorber needs worked on. The rubber donuts are going to need replaced. Anyone know what I can get replacement donuts for the shock? By the way, Peter, I think you helped me out a while back on getting a new life extension on my Lark. Happy to see you're twin still flying! Jim. |
Hey all, I called Blannik USA and they sell a rebuild kit for 500$ I'm thinking of getting one. The L-13 has the same shock absorber then the twin lark. I hope this helps. Unless you're just trying to replace the donuts. I'm in the same predicament with a1977 twin Lark.
Christian Wurtsboro, NY |
Here are some pictures of the rebuild that my club did a few years back on an L23. You might find it useful. The first go at the rebuild and it didn't hold pressure. We found out some seals were reversed. Keep track of the order of things as you tear it apart! http://aviation.derosaweb.net/#blanik
Best of luck, John |
| IS-28B2 Twin Lark - Service Life Extension Program | Pat McCartan | Soaring | 77 | December 22nd 20 06:30 AM |
| IS-28B2 Twin Lark Factory Contact | Pat McCartan | Soaring | 0 | October 27th 13 10:19 PM |
| IAR IS-28B2 Twin Lark Manuals Needed | Markus Graeber | Soaring | 3 | July 8th 12 11:54 AM |
| IS-28B2 Twin Lark status | Greg Arnold[_2_] | Soaring | 4 | June 17th 08 04:34 PM |
| Looking for a Lark IS-28B2 or IS-32 | [email protected] | Soaring | 3 | June 2nd 06 07:35 AM |
