We are trying to determine the status of this glider at our field.
It appears that this aircraft (which was built in 1997) had an airworthiness limitation of 20 years, which took it to 1997. However, there was a 15 year extension that took it to 2012. Assuming I have my facts right, the question is whether there will be another extension that takes it beyond 2012. Does anyone have any knowledge about this? |
On Jun 16, 2:50*pm, Greg Arnold wrote:
We are trying to determine the status of this glider at our field. It appears that this aircraft (which was built in 1997) had an airworthiness limitation of 20 years, which took it to 1997. *However, there was a 15 year extension that took it to 2012. Assuming I have my facts right, the question is whether there will be another extension that takes it beyond 2012. Does anyone have any knowledge about this? What I understand is that the current life limit extensions for the US gives us 35 years from date of manufacture for the standard airworthyness certificate. To comply with this requires documentation of a simple but comprehensive corrosion inspection. IAR or other US Lark owners may be able to supply the necessary forms. If a Lark owner doesn't want to do the inspection paperwork or has a Lark older than 35 years the certificate can be registered Experimental for as long as needed. Under that designation there is no life limitation in the US though you then cant use it for commercial purposes. Austrialians have done an extensive study of the Lark airframe and have determined that it is a very robust structure that is worthy of further life extension. Perhaps someone there will provide more details here. Matt Michael former owner Lark 28DG |
we have one in our club in the U.K they are lifed to 10,000 hours or 30.000 launches whichever is sooner. it used to be 6000 hours but the extension from brasov took it to 10K. why it the states is it lifed on its age, seems an awful waste?? jan |
On Jun 17, 1:43 am, Jan Eldem wrote:
we have one in our club in the U.K they are lifed to 10,000 hours or 30.000 launches whichever is sooner. it used to be 6000 hours but the extension from brasov took it to 10K. why it the states is it lifed on its age, seems an awful waste?? jan IIRC, the same 10000hr/30000launch extension included a 20 year service life, or at least did not alter it. That was done later under life extension inspections. I looked at a low time IS28B2 in the UK and did not buy it at the time due to the then unresolved 'shelf life'. That was in 1995. BGA rules at that time regarding such things are somewhat different than US FAA rules. Those vary from country to country. A classic example is the L-13, which is 'lifed' by hours in many countries, but not in the US. In Australia, some IS28B2's have far exceeded 10,000 hours. Frank W |
On Jun 16, 12:50*pm, Greg Arnold wrote:
...Assuming I have my facts right, the question is whether there will be another extension that takes it beyond 2012. Word is, they're doing a remake of Escape from New York. Does that count? Bob "von New Amsterdam" K. |
| Thread Tools | |
| Display Modes | |
| IAR IS-28B2 Twin Lark Manuals Needed | Markus Graeber | Soaring | 3 | July 8th 12 11:54 AM |
| Lark IS-28B2 Glider for Sale | [email protected] | Soaring | 0 | July 5th 07 11:50 PM |
| Looking for a Lark IS-28B2 or IS-32 | [email protected] | Soaring | 3 | June 2nd 06 07:35 AM |
| Twin Lark - CG release | Mark Zivley | Soaring | 7 | August 17th 04 05:20 PM |
