https://en.wikipedia.org/wiki/Focke-Wulf_Fw_44
The Focke-Wulf Fw 44 is a 1930s German two-seat biplane known as the Stieglitz ("Goldfinch"). It was produced by the Focke-Wulf company as a pilot training and sport flying aircraft. It was also eventually built under license in several other countries. Role Biplane trainer National origin Germany Manufacturer Focke-Wulf FMA First flight Late summer 1932 The Fw 44 was designed as a biplane with conventional layout and straight, untapered wings. Its two open cockpits were arranged in tandem, and both cockpits were equipped with flight controls and instruments. The Fw 44 had fixed tailwheel landing gear. It employed ailerons on both upper and lower wings. It did not use flaps. It was flown with a Siemens-Halske Sh 14 radial engine. The first prototype flew in 1932. After many tests and modifications to increase the plane's durability and aerodynamics, the final Fw 44 proved to have excellent airworthiness. A second version of the Fw 44 was the Fw 44B, which had an Argus As 8 four-cylinder inverted inline air-cooled engine of 90 kW (120 hp). The cowling for this engine gave the plane a more slender, aerodynamic nose. 20 Fw 44s purchased by China were modified for combat missions, and participated in the early stage of the Second Sino-Japanese War until all were lost in action. The last series version was the Fw 44J, which was sold or built under license in several countries around the world. It was equipped with a seven-cylinder Siemens-Halske Sh 14 radial engine. Specifications (Fw 44) General characteristics Crew: two, student and instructor Length: 7.30 m (23 ft 11 in) Wingspan: 9.0 m (29 ft 6 in) Height: 2.80 m (9 ft 2 in) Wing area: 20 m² (215.2 ft²) Empty weight: 565 kg (1,243 lb) Loaded weight: 770 kg (1,694 lb) Max. takeoff weight: 785 kg (1,727 lb) Powerplant: 1 × Siemens Sh 14 A-4 7-cylinder radial engine, 118 kW at 2,100 rpm (160 hp) Performance Maximum speed: 185 km/h (115 mi) Range: 550 km (340 mi) Service ceiling: 3,900 m (12,790 ft) * |
Focke-Wulf Fw 190 pics [08/20] - Focke-Wulf Fw 190.jpg (1/1) | Miloch | Aviation Photos | 4 | June 30th 16 01:29 AM |
Focke-Wulf Fw 190 | Miloch | Aviation Photos | 7 | June 29th 16 07:28 AM |
Focke-Wulf Fw 190 pics [09/20] - focke-wulf-fw-190a-wallpapers.jpg (1/1) | Miloch | Aviation Photos | 0 | June 28th 16 03:07 PM |
Focke-Wulf Fw 190 pics [07/20] - Focke-Wulf Fw 190 Cockpit.jpg (1/1) | Miloch | Aviation Photos | 0 | June 28th 16 03:07 PM |
Focke-Wulf Fw 190 pics [04/20] - Focke Wulf FW-190A8N.jpg (1/1) | Miloch | Aviation Photos | 0 | June 28th 16 03:07 PM |
