https://en.wikipedia.org/wiki/Focke-Wulf_Fw_190
The Focke-Wulf Fw 190 Würger (English: Shrike) is a German single-seat, single-engine fighter aircraft designed by Kurt Tank in the late 1930s and widely used during World War II. Along with its well-known counterpart, the Messerschmitt Bf 109, the Fw 190 became the backbone of the Luftwaffe's Jagdwaffe (Fighter Force). The twin-row BMW 801 radial engine that powered most operational versions enabled the Fw 190 to lift larger loads than the Bf 109, allowing its use as a day fighter, fighter-bomber, ground-attack aircraft and, to a lesser degree, night fighter. The Fw 190A started flying operationally over France in August 1941, and quickly proved superior in all but turn radius to the Royal Air Force's main front-line fighter, the Spitfire Mk. V,[3] especially at low and medium altitudes. The 190 maintained superiority over Allied fighters until the introduction of the improved Spitfire Mk. IX.[4] In November/December 1942, the Fw 190 made its air combat debut on the Eastern Front, finding much success in fighter wings and specialised ground attack units called Schlachtgeschwader (Battle Wings or Strike Wings) from October 1943 onwards. In the opinion of German pilots who flew both the Bf 109 and the Fw 190, the latter provided increased firepower and, at low to medium altitude, manoeuvrability. The Fw 190A series' performance decreased at high altitudes (usually 6,000 m (20,000 ft) and above), which reduced its effectiveness as a high-altitude interceptor. From the Fw 190's inception, there had been ongoing efforts to address this with a turbosupercharged BMW 801 in the B model, the C model with the Daimler-Benz DB 603, and the D model with the Junkers Jumo 213. Problems with the turbos meant only the D model would see service, entering service in September 1944. While these "long nose" versions gave them parity with Allied opponents, it arrived far too late in the war to have any real effect. Specifications (Fw 190 A-8) General characteristics Crew: 1 Length: 9.00 m (29 ft 5 in) Wingspan: 10.51 m (34 ft 5 in) Height: 3.95 m (12 ft 12 in) Wing area: 18.30 m² (196.99 ft²) Empty weight: 3,200 kg (7,060 lb) Loaded weight: 4,417 kg (9,735 lb) Max. takeoff weight: 4,900 kg (10,800 lb) Powerplant: 1 × BMW 801 D-2 radial engine, 1,250 kW (1,700 PS, 1,677 hp) Performance Maximum speed: 656 km/h (408 mph) at 19,420 ft (5,920 m) Range: 800 km (500 mi) Service ceiling: 11,410 m (37,430 ft) Rate of climb: 15 m/s (2,953 ft/min) Wing loading: 241 kg/m² (49.4 lb/ft²) Power/mass: 0.29-0.33 kW/kg (0.18-0.21 hp/lb) Armament Guns: 2 × 13 mm (.51 in) synchronized MG 131 machine guns with 475 rpg 4 × 20 mm MG 151/20 E cannon with 250 rpg, synchronized in the wing roots and 140 rpg free-firing outboard in mid-wing mounts. Specifications (Fw 190 D-9) General characteristics Crew: 1 Length: 10.20 m (33 ft 5½ in) Wingspan: 10.50 m (34 ft 5 in) Height: 3.35 m (11 ft 0 in) Wing area: 18.30 m² (196.99 ft²) Empty weight: 3,490 kg (7,694 lb) Loaded weight: 4,270 kg (9,413 lb) Max. takeoff weight: 4,840 kg (10,670 lb) Powerplant: 1 × Junkers Jumo 213A 12-cylinder inverted-Vee piston engine, 1,287 kW (1,750 PS, 1,726 hp) or 1,508 kW (2,050 PS, 2,022 hp) with boost (model 213E) Performance Maximum speed: 685 km/h (426 mph) at 6,600 m (21,655 ft), 710 km/h (440 mph) at 11,000 m (36,000 ft) Range: 835 km (519 mi) Service ceiling: 12,000 m (39,370 ft) Rate of climb: 17 m/s (3,300 ft/min) Wing loading: 233 kg/m² (47.7 lb/ft²) Power/mass: 0.30–0.35 kW/kg (0.18–0.22 hp/lb) Armament Guns: (all synchronized to fire through propeller arc) 2 × 13 mm (.51 in) MG 131 machine guns with 475 rpg 2 × 20 mm MG 151 cannons with 250 rpg in the wing root Bombs: 1 × 500 kg (1,102 lb) SC 500 bomb (optional) * |
On 2016-06-28 14:05:02 +0000, Miloch said:
Here is one of my shots taken at Paso Robles. -- Regards, Savageduck |
In article 2016062807172345813-savageduck1@REMOVESPAMmecom, Savageduck says...
This is a multi-part message in MIME format. On 2016-06-28 14:05:02 +0000, Miloch said: Here is one of my shots taken at Paso Robles. I see you're using a Nikon D300S...I have a Nikon CoolPix 630S (heh) and try shooting airplanes whenever I see them. Yup...I see a plane's contrail at 30,000 feet and I'm trying to get a 'good' shot of it with my pocket camera and its telephoto cranked all the way out! Of course a CoolPix wasn't made for that but I keep on trying. Spectacular shot! A testament to the camera and especially you the photographer. I make the assumption you were using a telephoto lens...about how high up and far away was the plane? * |
On 2016-06-28 15:22:21 +0000, Miloch said:
In article 2016062807172345813-savageduck1@REMOVESPAMmecom, Savageduck says... This is a multi-part message in MIME format. On 2016-06-28 14:05:02 +0000, Miloch said: Here is one of my shots taken at Paso Robles. I see you're using a Nikon D300S...I have a Nikon CoolPix 630S (heh) and try shooting airplanes whenever I see them. Yup...I see a plane's contrail at 30,000 feet and I'm trying to get a 'good' shot of it with my pocket camera and its telephoto cranked all the way out! Of course a CoolPix wasn't made for that but I keep on trying. Spectacular shot! A testament to the camera and especially you the photographer. Thanks. I make the assumption you were using a telephoto lens...about how high up and far away was the plane? Yup! I was using a Nikkor 70-300mm. It was making a high speed, low level pass at ±800ft. For that shot the range was 400-500 yds. This was earlier in the approach for that pass when they were about 1000 yds out on the other side of the airport. It was a good day for shooting warbirds, and they cooperated with some good low passes with P-51's, P-38L, B-25 and others. -- Regards, Savageduck |
On 2016-06-28 16:01:05 +0000, Savageduck said:
On 2016-06-28 15:22:21 +0000, Miloch said: In article 2016062807172345813-savageduck1@REMOVESPAMmecom, Savageduck says... This is a multi-part message in MIME format. On 2016-06-28 14:05:02 +0000, Miloch said: Here is one of my shots taken at Paso Robles. I see you're using a Nikon D300S...I have a Nikon CoolPix 630S (heh) and try shooting airplanes whenever I see them. Yup...I see a plane's contrail at 30,000 feet and I'm trying to get a 'good' shot of it with my pocket camera and its telephoto cranked all the way out! Of course a CoolPix wasn't made for that but I keep on trying. Spectacular shot! A testament to the camera and especially you the photographer. Thanks. I make the assumption you were using a telephoto lens...about how high up and far away was the plane? Yup! I was using a Nikkor 70-300mm. It was making a high speed, low level pass at ±800ft. For that shot the range was 400-500 yds. This was earlier in the approach for that pass when they were about 1000 yds out on the other side of the airport. image It was a good day for shooting warbirds, and they cooperated with some good low passes with P-51's, P-38L, B-25 and others. ....and then there was on the ground taxiing. -- Regards, Savageduck |
The only flightworthy original FW 190A - complete with BMW 801 engine
- owned by the Flying Heritage Collection in WA State. Rescued from a Russian swamp in the 1980s. |
![]() Seen here with the FHC's Bf 109E, found on a French beach. |
Cockpits 8 - Focke-Wulf Fw 190 b.jpg (1/1) | Mitchell Holman[_8_] | Aviation Photos | 0 | May 25th 15 12:53 PM |
Cockpits 7 - Focke-Wulf Fw 190 a.jpg (1/1) | Mitchell Holman[_8_] | Aviation Photos | 0 | May 24th 15 02:00 PM |
Hamilton Air Show Batch 4 [12/31] - Focke Wulf Fw-190-4.jpg (1/1) | Indrek[_6_] | Aviation Photos | 0 | June 25th 13 02:44 AM |
focke wulf ta 283 1944 | fox[_2_] | Aviation Photos | 0 | March 17th 10 06:38 PM |
Focke Wulf, Falcon Wing??? | James Dandy | Military Aviation | 14 | January 13th 04 11:23 PM |
