Pic 20's in the rain
Old April 30th 04, 01:58 AM
Matt
Default Pic 20's in the rain
do they fall out of the sky when they get wet?
Old April 30th 04, 04:17 AM
Arnie
Max,
Most gliders of that generation use the Wortmann FX 67 airfoil, which has
degraded performance when wet.
Some examples are :
Kestrel, DG-400, Pik-20, Nimbus 2, Lak-12, LS-3, Janus, HP-18, Jantar 2B
Apparently some are worse than others, I suppose this is due to the fact
that some use this profile on the wing roots only, with another profile
towards the wingtips (these being "better" or more "tolerant"), while some
use only the FX-67 only. But it could be something else.
Apparently the laminar flow is disturbed very easily on this profile, so not
only water, but bugs will degrade their performance as well.
Reading Dick Johnson's flight tests, especially some from the 70s, will tell
you a little bit more about this.
If you go to this link (http://www.ssa.org/Magazines/Johnson.asp) and scroll
down, there are 3 reports about the Pik-20, very illuminating.
"Matt" wrote in message
Old April 30th 04, 04:43 AM
MikeYankee
Apparently one landed out near Ridge Soaring the other day after being caught
in a shower. He was at 6000' msl over Milesburg (less than 10 nm away) and
couldn't make it back to the airport. I wasn't there but heard about it.
Mike Yankee
(Address is munged to thwart spammers.
To reply, delete everything after "com".)
Old April 30th 04, 06:59 AM
Doug Turner
Mine did!
Old April 30th 04, 09:31 AM
Derrick Steed
Mike Yankee
I have a PIK20B and I have experimented with this aspect of its performance (incidentally, mine is one of those with a different section at the tip - it's FX67K-170 out to the aelerons, then progressively changes to FX67K-150 at the tip). After reading Dick Johnson's articles and noting his assertion that the performance of this sections is strongly dependent on Reynolds number (which is probably why the K21, Nimbus 2, Kestrel, etc. aren't affected so badly - e.g. larger chord). On the basis of his assertion I wandered under a shower cloud (it was virga really) at about 50Kts and around 2Kts sink, the wings got wet and the sink rate went to 8Kts! Following the reasoning about Reynolds number I increased speed to 100Kts, sink rate? Still 8 Kts - it strikes me that you have to accept that there are large changes in the glider's polar and if you don't react to these then you will end up not making it. I think the rule "fly faster when the wings are wet" applies very strongly wi!
th these sections - just remember that they work better at higher Reynolds numbers and there are only two ways to achieve them: put water in it (= flying faster), or fly lots faster when the wings get wet.
Rgds,
Derrick.
Old April 30th 04, 11:34 AM
Don Johnstone
Cant say about the Pik but I can tell you the Kestrel
does, and some. All the aerodynamic qualities of a
housebrick. Grob 103 not much better.
On the plus side an ASW 17 does not appear to be effected,
it climbs with wet wings, bonus if you fly in the UK.
At 02:30 30 April 2004, Arnie wrote:
Max,
Some examples are :
HP-18, Jantar 2B
is due to the fact
towards the wingtips (these being 'better' or more
'tolerant'), while some
else.
as well.
and scroll
'Matt' wrote in message
Old April 30th 04, 01:21 PM
Sf760
Mosquito's the same, starts rumbling the instant it gets the slightest bit wet.
Si
Old April 30th 04, 03:50 PM
Andreas Maurer
On 30 Apr 2004 09:34:46 GMT, Don Johnstone
The 17 uses the FX 62K-131 (as well as the 20).
This airfoil is by far the most docile one concerning bugs and water
that I ever saw. Just as you said - nearly no performance loss with
wet wings or lots of bugs on the leading edge.
Bye
Andreas
Old April 30th 04, 02:48 PM
Hank Nixon
"Matt" wrote in message ...
In a word-Yes
PIK is sensitive to rain and bugs but is a very good glider otherwise.
I used to wash mine with very soapy water solution and let it dry on
front 1/3 of wing. This would allow water to wet out and flow off
wing. Good for about 10 minutes in the rain.
Also found it climbed better if never sanded smoother than 400 grit on
leading edge area. When it stopped climbing, I just roughed it up a
bit.
Standard PIK alarm installation: Rain drop hits canopy- alarm says put
the gear down!
All joking aside they are good value for the money.
Good Luck UH
Old May 1st 04, 06:27 PM
Steve
(Hank Nixon) wrote in message
Good Luck UH
I have heard of people doing this. Has anyone tried that new car
washing stuff I have seen advertised on TV? Says it makes it so you
will never have to dry your car again. The water sheets up and runs
off. Dries without spotting. Sounds ideal for those of us flying the
ole 67K 150/170 sectioned gliders.
I have wanted to run a test by flying in a balast dump trail. Prepare
a test section of wing and fly in the dumped ballast. Do a visual
comparison of the standard and prepped sections. I have seen the
dreaded "wall of water" that forms on the top of the wing. Not sure
if it is more depressing to see it on a 15 meter wing, or a 22 meter
wing, though. ;-)
And I don't know if it was just the rain, or some sink, too. But I
was on a 40 mile or so final glide in my Zuni with an ASW-20. GPS
tracks showed neck and neck until I flew through a small shower. He
made it home, and I landed 6 miles short. He said he didn't get wet,
and looks to have been less than half a mile to my side and a bit
behind. A year or so previous, that same 20 was out ahead of me on a
final glide. He found sink and claimed picked up a headwind. Landed
about 6 miles short. I started for home a couple of turns after him
and a bit behind, and made it home. I guess what comes around goes
around.
Steve Leonard
Zuni II (15 meters worth of water spoiler)
604 (22 meters worth of water spoiler)
My first freezing rain encounter [email protected] Piloting 21 January 6th 05 04:44 AM
Rain, rain, go away... PJ Hunt Rotorcraft 3 October 30th 04 08:51 AM
Personal VFR Minimums Neil Bratney Piloting 6 September 2nd 04 09:32 AM
Icing David Megginson Piloting 3 August 11th 04 11:35 PM
Rain and autopilot unstable W9MV Owning 3 May 18th 04 09:51 PM
