My first freezing rain encounter
Old January 3rd 05, 06:21 PM
Default My first freezing rain encounter
The weather was perfect for flying yesterday morning, sunny, mostly
blue sky with about 12000' ceiling and little wind (unlike the day
before when we canceled our flying plan due to 13G24 wind). As usual,
we checked weather sites, TAF/weather map etc before heading to the
airport. Bad weather is moving in but not until later in the day with
3000' ceiling at 3pm and light rain predicted at midnight or so. Our
plan was just to do some local IFR training flights taking turns
wearing foggles or acting as the safety pilot.
After entering the gate, we glanced at the ramp and saw quite a bit
of activities with several vehicles and a small group of people at the
north side of runway 24. In closer look, we saw a plane landed off the
runway in the grassy area with half of the wing stuck in a fence. We
immediately thought that the accident was due to the gusty/windy
condition the day before. It turned out that it was due to an engine
trouble on take off, luckily the pilot walked away unarm. We saw both
the pilot and the owner in the pilot lounge. Both looked quite grave
and were busy checking AIG insurance policy on open pilot cause.
We have always done a thoroughly preflight inspection and
preparation but this incident made us double-checks everything. After
plugging in the Reiff heaters and put on the nose mitten, Rick went and
chatted with a friend who was preheating his with a propane tank. He
also had a new engine and we both felt that preheating was needed even
in temp near 40F. The was quite a lot of activities on the ramp and in
the pattern in this relatively warm January weather. We went to the
mall nearby to pick up some tools at Sears while the engine being
heated. In checking the sky after our shopping, I was somewhat
concerned of the overcast instead of earlier blue sky but Rick assured
me that the ceiling should stay high enough for our practices.
We had planned to take off at before noon, but all the activities
added up and we did not depart until 1pm. The tanks were more than half
full. We thought of topping off but to save time, Rick suggested that
instead of flying northeast to Pawling VOR, he could do his practice on
the way north to Columbia. We could fuel there and I could fly to
Pawling on the swayback for my practice turn. ATIS at taxi time
indicated 5000' ceiling with about 2C spread between temp and dew
point.
While Rick was under the hood, I noticed that both the ceiling and
visibility seemed to get worse as we approached 1B1, so I suggested him
to cut the practice short and just prepared to land. Columbia AWOS
indicated wind at 200, 12 gusting to 18 (in contrast with 6 knots wind
at Dutchess) and with only 1C spread between temp and dew point. We
quickly fueled up, sumped the fuel, did a walk around inspection,
listened to AWOS then took off again. Ceiling had lowered to 3500' and
temp and dew point were both at 3C. I turned on the pitot heat and
made sure that cowl flap was close and the engine was leaned. After
about 15 to 20 minute under the hood, I heard Rick said in a somewhat
alarming voice "Change your plan, we are heading back to Dutchess - It
has started to rain". Then his raised his voice "Full throttle, full
throttle, we have ice on the windshield". Rick immediately put on the
defroster while I flipped on all our lights, landing/taxi/nav and
double checked that the pitot heat was on, cowl flap close, carb heat
off, engine leaned. We wanted the engine to kick off as much heat as
possible. At the same time, I was also trying to descend to a lower
altitude while keeping the speed just below the yellow arc. Rick wanted
me to go down to 2000' both for warmer air and less headwind (we have
something like 40' headwind at 3000') but I settled for 2500'thinking
altitude was my friend. Rick told me the GPS showed the nearest airport
was Kingston at 7nm and asked me whether I wanted to land there. Our
encounter with freezing rain was quite brief probably less than a
minute, because the windshield ice seemed to start melting where the
defroster hit at the pilot's side and there was no evidence of
additional ice build up. I had plenty of lift at full throttle, had to
pull back the power to stay at 2500' and not getting in the yellow arc.
I told Rick that I would continue south to Dutchess toward better
weather. KPOU ATIS indicated ceiling of 4000' with 1C spread between
temp and dew point. I contacted the tower for landing and also
reported our light icing encountered. The tower told us that they would
notify flight service. By this time, my side of the windshield was
clear enough for VFR. In my vague recollection, I probably relied
mostly on the instrument panel trying to keep straight and level,
descent at steady rate, following the VOR radial back to KPOU. I have
not officially started my instrument training but had done dozens of
foggles hours and had just spent the entire week playing with my
Christmas present, Elite v.8 with the IFR training manual. The
practices really came in handy.
In setting up for landing, I tried to stay high and slipped in with
only 10-degree flap. Over the fence, I was still pretty high and
somewhat fast so I dropped to 20-degree flap and reduced power to near
idle to make sure that I would not land long on the 3000 feet runway.
The landing was good and I was able to turn left to Alpha taxiway right
to our tie-down area.
The windshield was totally clear by the time we landed. I immediately
got out and check the wings. They were still coated with a clear thin
layer of ice which was melting quickly at 38F ground temperature.
After my icing report to the tower, there were two planes taking off
northbound. On our way out of the airport, we noticed several people
standing near the ramp area having their picture taken. Rick stopped
and asked whether they planned to go up soon. They nodded with big
smiles. The pilot was on the ramp getting the plane ready. Rick told
the passengers about the freezing rain/icing and suggested that should
not go up. I am not sure whether they comprehend the danger of the
situation by the look on their faces. I just hope that they would tell
the pilot of our advice.
In reviewing the incidence, we realized that we have made several
small errors. First, we should leave a wider margin of time for the
incoming bad weather. Secondly, we should not have changed our flight
plan at the last minute. If we had planned to go north to Columbia, we
would have paid closer attention to Albany TAF and weather report.
After our flight, I checked my mail and found an urgent winter storm
watch and warning for Albany region which remained in effect from noon
to 5pm:
"WARM MOIST AIR AHEAD OF A WARM FRONT MOVING INTO THE NORTHEAST FROM
THE OHIO VALLEY WILL RIDE OVER VERY COLD AIR TRAPPED NEAR THE
SURFACE. A MIXTURE OF FREEZING RAIN AND SLEET WILL OVERSPREAD THE
REGION FROM WEST TO EAST DURING THE AFTERNOON AS TEMPERATURES
GRADUALLY RISE THROUGH THE 20S AND TOWARD THE FREEZING MARK"
It I had seen this warning of the temperature inversion, we would not
done this flight!
Doing my logbook after the flight, I noticed that this flight
completed my 400th hour in 4 years. Paul Craig's "The Killing Zone"
book identified the dangerous zone being between 50-350hrs. I don't
really believe that I am safe being outside of this zone. Piloting is
lifelong learning experience. We were just being a bit too complacent
with our local flights. This incident was a great wakeup call.
Hai Longworth
Old January 3rd 05, 06:32 PM
Jose
Good work, but when iced up, (I hear) it's important not to make big
changes in airfoil when landing. The iced up wing is more sensitive
to such changes and the disturbed airflow may separate, leading to a
low altitude stall. I've never landed with ice, so all this is from
what I've heard and read (and seen in FAA videos); others will
certainly fill in.
It can sure happen quickly.
Jose
r.a.student trimmed
Freedom. It seemed like a good idea at the time.
Old January 3rd 05, 10:34 PM
Colin W Kingsbury
"Jose" wrote in message
m...
low altitude stall.
As I understand there's an evolving body of thought that the real culprit in
many of these cases is a tailplane stall rather thna a wing stall. Flap
deployment seems to be a decisive factor in precipitating these. The fun
part is that if you get into one the recovery procedure is the
opposite--nose up--than for a wing stall. This was all in a recent AOPA
Pilot issue IIRC. All the more reason to avoid the situation in the first
place.
-cwk.
Old January 3rd 05, 11:24 PM
Jay Honeck
Good job, Hai. A little ice goes a long ways toward making you want to be
on the ground.
The one time we ran into significant icing, we had been trying to flank a
cold front that stretched from Illinois to Mexico on a flight from Florida
to Iowa. We kept the cold front off our left wing the whole day, as we made
our way north, flying just far enough east to stay in the clear. When we
got to the "top" of the front, in Illinois, we momentarily penetrated a rain
shower that made our windshield go completely opaque just like *that* -- no
warning at all. It was quite a shock.
Luckily, as we descended toward the nearest airport the ice began
sublimating, and we were suddenly on the backside of the front in the clear,
cold air. With that, all was well -- but it's an experience we'll never
forget.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old January 3rd 05, 11:48 PM
Bob Gardner
Because ice accretion is inverse to the radius of the collecting surface,
you will have about three times as much ice on the leading edge of the
horizontal stabilizer compared to the wing's leading edge. Best current
guidance is to avoid flap extension if icing is suspected because of the
possibility of tailplane stall.
Other than that, you done good!!!
Bob Gardner
point.
to 5pm:
done this flight!
Hai Longworth
Old January 4th 05, 06:08 AM
steve.t
The tail plane stall that all keep talking about, isn't it caused by
icing over a stablizer that is at or just below the plane of the wing?
Then when the flaps are deployed, the air is disturbed sufficiently
that the tail stalls?
Therefore, if flying a T tail (or similar), deployment of flaps should
not affect the tail. Is this correct?
I'm asking because of flying a Piper wherein the wing is actually below
the stabliator. Deployment of 15 degrees of flaps should not
sufficiently disturb the airflow to cause the tail plane stall in this
case. Is this correct?
Later,
Steve.T
PP ASEL/Instrument
ps. I'm almost at that 350hr mark some one else mentioned. T-storms,
fog and ice conditions are automatic no-go situations for me. Too much
at stake.
Old January 4th 05, 02:27 PM
Denny
It is not just the flap deployment altering airflow over the stabilizer
that causes a tail plane stall - though that is a major problem for
many airplanes - but it is also the slowing up with flap deployment
which forces the horizontal stabilizer to fly at a higher angle of
attack (downward attack, of course)... So T-tails need to be flown
exactly the same way as straight tails... If the ship has a load of ice
(weight) forcing the airfoils to fly at a higher angle of attack to
begin with and the stab has ice distorting it's airfoil, then
increasing the angle of attack even further by slowing up will/can be
the final straw leading to an accelerated tail plane stall followed
instantly by the nose pitching downward sharply..... If you are iced
up, forget the flaps and keep the speed up until the wheels are just
above the runway... It is far better to deal with a possible low speed
over run off the end of the runway, than a pitch over at a few hundred
feet of altitude where death is certain...
Thunder bumpers, fog, and icing, are ABSOLUTE no-go situations for
me...
Remember this old saw, because it is absolutely true:
There are old pilots...
There are bold pilots...
But there are no old-bold pilots...
Denny
Old January 4th 05, 07:48 PM
Denny,
Is is our modus operandi too. As I mentioned in my reply to Bob
Gardner, we attended the Wing Safety Seminar on Winter Operation last
November. Our thought was that we would never let it happen to us !
Little did we know that we would encounter icing in a short local
excursion on a day which we thought was perfect for flying. BTW, the
urgent weather warning which I received was through my-cast, a
'regular' and not aviation weather servcie. The TAF for Albany area
mentioned drizzle rain but much later in the day. POU TAFdid not
indicate any precipitation, 1B1 is between the two airports. The very
short duration of the freezing rain indicated that it could be very
local, just under a rain cloud. We might not have encountered it if
we were few miles East or West.
Old January 4th 05, 08:51 PM
Steve,
Bob is correct, never, ever use flaps on landing if you have any ice on
the airplane, it does not matter a bit about the position of the
horizontal stabilizer. Flaps change the airflow in the area of the
tail and also move the center of lift aft, both of which increase the
angle of attack of the tail, moving it closer to the stalling angle of
attack should it have any ice at all.
You might want to go to NASA's website and find the information there
on icing and tailplane stalls; it's eyewatering. They also sell a DVD
of inflight footage of their testing. Also go to AVweb
(www.avweb.com), click on "columns" then on "The Pilot's Lounge" and
scroll down to the column on tailplane stalls. If you get IFR
Magazine, there is an article on dealing with inflight icing in the
November 2004 issue.
If in ice, leave the flaps up. Cessna POHs make this clear, I'm not
sure whether Piper POH's mention it. Touch down fast, and do NOT
reduce power at all until the wheels are rolling as the power reduction
may take you from flying at above the power on stall speed to
descending fast at below the power off stall speed.
All the best,
Rick
Old January 4th 05, 09:52 PM
Rick,
I just checked my Cardinal POH and it does state leaving wing flaps
retracted.
I have few questions: for this particular case whether icing is
very mimimum (thin layer of clear ice) and the runway is relatively
short (3000') and there appeared no loss of any lift power, do you
think that I still should have used no flaps and no power reduction
until touch down?
Another question is with the cabin heat and defroster knobs? We left
both on full blast and the POH indicated the same thing but if we want
to melt the windshield ice quickly, shouldn't we close off the cabin
heat to divert all the heat to to the windshield area first?
Hai
Issues around de-ice on a 182 Andrew Gideon Piloting 87 September 28th 05 12:46 AM
Rain and autopilot unstable W9MV Owning 3 May 18th 04 09:51 PM
