I have a gps nav. I have a serial sync cable for my Ipaq 3630. I have
made a connector cable for the gps-nav to the sync cable. I am getting data transfer. Power is through the 8 pin on the db9 on the gpsnav. Can anyone confirm the pin to receive 5 volt power on the db9 sync cable? Also if 5 volts is supplied through the serial cable will the yellow light blink? Rich |
"Rich Chesser" wrote...
I have a gps nav. I have a serial sync cable for my Ipaq 3630. I have made a connector cable for the gps-nav to the sync cable. I am getting data transfer. Power is through the 8 pin on the db9 on the gpsnav. Can anyone confirm the pin to receive 5 volt power on the db9 sync cable? Also if 5 volts is supplied through the serial cable will the yellow light blink? The voltage regulator in the GPS-NAV supplies adequate current for older PDAs, such as the Compaq Aero 1500. It does not provide enough current for an iPAQ, particularly if the battery needs charging. You'll probably end up with a discharged iPAQ and/or a fried GPS-NAV. I'd suggest buying a separate 5V power supply. Marc |
Hi,
For a long time I was highly recommending a 12V to 5 V power converter when powering iPAQs with the GPS-NAV. But I've heard from a few customers that say they have had success without the power converter. Cambridge told me the current output data on the GPS-NAV and 302 and I created a note on my Goddard page for GPS-NAV users. I would love to sell a Goddard PS-5a to every customer, but they may or may not need one. If they keep their iPAQ charged every night, they might be OK without the power converter. The note I'm referring to is near the top of the page below. http://www.cumulus-soaring.com/goddard.htm However, I should mention that I have one customer that was powering his iPAQ with his GPS-NAV and he told me that Cambridge said the GPS-NAV was damaged and needed repair. I recommend using the power converter to avoid damage to the GPS-NAV, and to make sure you don't have an incomplete flight log due to the iPAQ pulling the GPS-NAV down. Good Soaring, Paul Remde Cumulus Soaring, Inc. "Marc Ramsey" wrote in message ... "Rich Chesser" wrote... I have a gps nav. I have a serial sync cable for my Ipaq 3630. I have made a connector cable for the gps-nav to the sync cable. I am getting data transfer. Power is through the 8 pin on the db9 on the gpsnav. Can anyone confirm the pin to receive 5 volt power on the db9 sync cable? Also if 5 volts is supplied through the serial cable will the yellow light blink? The voltage regulator in the GPS-NAV supplies adequate current for older PDAs, such as the Compaq Aero 1500. It does not provide enough current for an iPAQ, particularly if the battery needs charging. You'll probably end up with a discharged iPAQ and/or a fried GPS-NAV. I'd suggest buying a separate 5V power supply. Marc |
homemade EFIS system and EMI | jcpearce | Home Built | 75 | February 22nd 05 02:07 AM |
Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 4th 04 11:55 PM |
LOP operation | Roger Long | Piloting | 35 | April 17th 04 05:29 AM |
Ipaq - GPS_Log Help needed (Long) | Steve B | Soaring | 1 | September 27th 03 06:00 AM |
iPAQ h2210/h2215 Review | Paul Remde | Soaring | 0 | September 3rd 03 03:45 AM |
