Glider Fatality in WA
Old June 24th 04, 03:08 AM
Mark Nyberg
Default Glider Fatality in WA
On Sunday afternoon June 19th Joseph Patton died in a glider accident
at Bergseth Field near Enumclaw, WA. Joe had been flying for a few
hours in his motorglider, came in for landing with too much altitude,
stalled and crashed. Joe died instantly.
There will be a visitation (opportunity to pay last respects and talk
with his family) on Friday June 25th from 4 to 8 PM at the
Bonney-Watson Funeral Home. The funeral home is located at 1732
Broadway (between Denny and Pine, across the street from the Seattle
Central Community College) in Seattle on Capitol Hill. Parking is
available on the north side of the funeral home.
Funeral Services will be held in the chapel at that same funeral home
on Saturday June 26th at 11:00 AM.
Old June 24th 04, 08:29 PM
Mark Nyberg
I am new to sport (2 years). Because seems so difficult to stall a
glider when intentionally practicing both straight ahead and turning
stalls I have a hard time understanding why it is such a common reason
for a tragic incident like this.
Hal,
A credible witness observed that by the time Joe realized he was in
trouble, he was too high, had a slight tailwind and had too much
energy for a normal landing. If he proceeded straight ahead he was
certainly going to overrun the runway and end up rolling into the
trees. For some reason he made a hard turn to the right followed by a
hard turn to the left. He ended up low (about 50' AGL) and slow near
midfield.
Out training teaches us to keep our speed up, but at very-low
altitudes our human nature tells us to pull back on the stick in a
turn to stay away from the ground. I didn't understand this very well
until I went up with and instructor who had me practice some slow
skidding turns (like the kind of turn we might be tempted to make from
base to final if we don't have much altitude). I found that stalling
and spin entry can be much easier and more dramatic than I thought. I
am glad you asked about this.
Mark Nyberg
Old June 24th 04, 10:42 PM
Shawn Curry
midfield.
Mark Nyberg
It got me thinking about what I would do in the same situation. It
sounds like he made a reasonable choice by adding some length to his
final by doing some turns. Someone mentioned the field was 2000 feet or
so. Being able to loose enough energy to be slow and midfield at 50
feet sounds like he achieved his goal all too well. 1000 feet to land
from 50 feet sounds tight but doable especially if you're already slow
and need to speed up to do a proper flare. The thing I figured is that
it would *look* tight and maybe impossible especially if the drill at
that field is to land on the numbers (I don't know this). I do know
I've never been drilled with "Fly over most of the runway and stop with
the nose at the far end of the runway." If this was the situation he
was in, I could see how it ended badly.
My condolences to his family and friends
Shawn
Old June 25th 04, 12:10 AM
Eric Greenwell
feet or so.
Airnav lists the runway length at 2100'. The Terraserver image from
1998 shows it is about 2300'-2400' from the trees at one end to the
trees at the other end. I've never been there, but the lengths and
images suggest a field with very small margins for error.
Being able to loose enough energy to be slow and midfield at 50 feet
slow and need to speed up to do a proper flare. The thing I figured
is that it would *look* tight and maybe impossible especially if the
drill at that field is to land on the numbers (I don't know this). I
do know I've never been drilled with "Fly over most of the runway and
stop with the nose at the far end of the runway." If this was the
situation he was in, I could see how it ended badly.
In the situation described above, I think the only option left is full
spoiler, dive steeply and put it on the ground as soon as possible, then
use full wheel brake and full forward stick. If that didn't stop the
glider in time, aiming between the trees as they approach might avoid
serious injury, as likely the speed would be slow by the time of collsion.
I'm not sure I would think of this if I were in that situation, as the
ground would seem to be going by rapidly with the tailwind, and the
trees would likely look very threatening.
Eric Greenwell
Washington State
USA
Old June 25th 04, 12:17 AM
Vaughn
It is the fences that scare the hell out of me. Post 9/11, barbed wire is
probably much more prevalent on airport fences than it once was, just about neck
high when you are seated in a glider.
Vaughn
Old June 25th 04, 03:45 AM
Mark Navarre
This reminds me of why I am thankful for the short field landing practice I was
urged to do when I first started flying my ASW-20.
My instructor told me to put traffic cones next to the runway 300-400 feet
apart and practice touching down at the first cone and stopping before the
second. Repeat three times every visit to the glider port the first month or
so.
Now a 2000 foot runway looks like Los Angeles International.
Mark Navarre
2/5 black ace
LoCal, USA
remove brain to reply
Old June 25th 04, 11:22 AM
Joeri Cools
I've been thaught the two methods. In Belgium an instructor told me to make
S-turns when high on final, in France this seems to be illegal and a steep
dive with full spoilers is recommended. About aiming between the trees, this
makes me wonder. In a glider with a span of let's say 15 to 18 m you
probably end up hitting a tree with one or two wings. An article in our club
magazine about outlanding mentioned that stick full forward and
intentionally ground-looping as the method of choice. The stick forward
would bring the tail up and prevent it from snapping off. Speed would be
down and the glider and more importantly yourself would survive. Anyway,
there is no more damage than hitting a tree with a wing.
Joeri.
"Eric Greenwell" schreef in bericht
feet or so.
Eric Greenwell
Washington State
USA
Old June 25th 04, 08:37 PM
Tom Seim
I once landed my DG-400 (1,000 lbs gross) on a 1,200 ft runway,
stopping a little more than halfway. I wanted to clear a stand pipe on
one side of the runway, so I gave up about 200 ft. This means I really
used about 500 ft to stop. This was a real life situation-not a
simulated one. This guy, flying a lighter glider than mine, should
have been able to get down from 50 ft and be fully stopped with 1,000
ft of runway he had left. In any case, going off the end of the runway
at low speed sure as hell beats going in vertical. S turning at 50 ft
is highly unadvisable.
Tom Seim
Richland, WA
Old June 24th 04, 01:40 PM
Richard Branch
I don't normally comment on these posts for fear of upsetting someone, but
in this instance it is clear the report is confused, one does not crash
after a stall because of having too "much" altitude. Rich...
Joe had been flying for a few hours in his motorglider, came in for
landing with too much altitude, stalled and crashed.
Sport Pilot - School Won't Offer Gary G Piloting 38 February 16th 05 10:41 AM
Bad publicity David Starer Soaring 18 March 8th 04 03:57 PM
I wish I'd never got into this... Kevin Neave Soaring 32 September 19th 03 12:18 PM
Restricting Glider Ops at Public Arpt. rjciii Soaring 36 August 25th 03 04:50 PM
