How does the manufacturer of new gliders determine the
recommended best approach speed. ? JAR 22 specifies the yellow triangle on the airspeed indicator to be at the manufacturer's lowest recommended approach speed at max weight without water ballast but I can't find how that that speed should be determined. I have thought that the minimum approach speed (-0- wind) should be best L/D at max gross weight w/o water ballast so that with half spoilers the pilot can be at an approach angle half way between the best glide over the ground and the steepest descent possible at that same constant airspeed with full spoilers. (Wind would require additional speed.) Does this analysis conform to what JAR or manufacturers' use to determine the recommended minimum approach speed? Thanks. Pete -- Peter D. Brown http://home.gci.net/~pdb/ http://groups.yahoo.com/group/akmtnsoaring/ |
| F/A-18 approach speed rule of thumb | tscottme | Naval Aviation | 5 | December 7th 04 12:13 AM |
| VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 06:03 AM |
| Canadian holding procedures | Derrick Early | Instrument Flight Rules | 24 | July 22nd 04 05:03 PM |
| Changes to Aircraft Approach Categories?! | skyliner | Instrument Flight Rules | 10 | February 9th 04 09:55 PM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
