Changes to Aircraft Approach Categories?!
Old February 6th 04, 10:43 PM
skyliner
Default Changes to Aircraft Approach Categories?!
I've been away from this newsgroup for quite some time, so forgive me if
this has already been covered.
The other day, one of my colleagues pointed out something I hadn't noticed
in the latest set of approach plates, which came out at the end of December.
Its on page A2, under "Aircraft Approach Categories."
Previously, the paragraph included a sentence "...If it is necessary to
MANEUVER at a speed in excess of the upper limit of the speed range for an
aircraft's category, the minimums for the category for that speed shall be
used." Thus, if landing straight-in, one would use the approach speed based
on VREF or 1.3 VSO to determine which category to use, and only move up to a
higher category if -circling- for landing.
Now, the sentence reads, "...If it is necessary to OPERATE at a speed in
excess of the upper limit of the speed range for an aircraft's category, the
minimums for the category for that speed shall be used." And there is also a
new example, "...a Category A airplane which is operating at 130 knots on a
straight-in approach shall use the approach Category C minimums."
This is going to change things...now all my students who like to fly
approaches over 90 kts in their Archers will be moving up to Category
B...whether it's circling or straight-in. Did anyone else miss this? I feel
kinda sheepish for not realizing it for a whole month.
-Eric
CFII, MEI
Old February 6th 04, 11:01 PM
Teacherjh
Now, the sentence reads, "...If it is necessary to OPERATE [was Maneuver] at a
speed in
I don't see a difference... I've always assumed that one is still maneuvering
when one does a straight-in approach. The word "operate" is clearer in being
all-encompassing, but I always took "maneuver" to also be all-encompassing.
Even on a straight in, if you are going fast enough, you use the next category.
This makes more sense when considering the room needed for a missed at varous
speeds.
Jose
Old February 7th 04, 01:39 AM
Ron Rosenfeld
On Fri, 06 Feb 2004 22:43:37 GMT, "skyliner"
I don't see that on my Jepps. Or in the AIM. Are these "approach plates"
US? (There are ICAO speed restrictions for different categories that might
apply).
Old February 7th 04, 04:39 AM
skyliner
Sorry, guess I left that out.
Yes, these are in the latest FAA US Terminal Procedures Publications, aka
"NOS Approach Plates."
EC
"Ron Rosenfeld" wrote in message
noticed
December.
might
apply).
Old February 7th 04, 12:43 PM
Ron Rosenfeld
On Sat, 07 Feb 2004 04:39:26 GMT, "skyliner"
I think I would wait until seeing information in TERPS or in the AIM before
applying the higher category minimums to straight-in procedures.
It seems to me that, as I was taught many years ago, that the issue is with
circling procedures, in that the protected circling radius varies depending
on a/c speed. However, that would not seem to apply to straight-in
procedures.
In addition, it is my understanding that the missed approach procedure is
constructed in accord with the highest category of a/c authorized to use
that approach. So again, flying at a speed attributable to a higher
category a/c should not seem to alter minimums for straight-in procedures.
One area to be careful of, especially with the (expected) proliferation of
GPS/RNAV approaches to smaller airports, is that a number of these may be
designed for just Category A and/or B. If that is the case, you would not
want to execute the approach at a Category C speed. Probably not something
that us FLIB drivers think about, too often.
Old February 7th 04, 01:31 PM
Ron Rosenfeld wrote:It seems to me that, as I was taught many years ago, that
the issue is with
procedures.
There are some approaches where the straight-in minimums step-up for each
higher approach category because of a turning missed approach obstacle issue
that affects the higher turning radii more than the lower.
Old February 7th 04, 08:00 PM
Dave S
Dont fly so fast, and it wont be a problem 1.3 VSO is a lot different
from 2.0 VSO
yea yea.. I've heard em say "Keep Your Speed Up" too
Dave
-Eric
CFII, MEI
Old February 8th 04, 01:38 PM
Are you certain that is the reason for the higher minima? Could you give
an example of an approach where you believe that to be the case?
Medford, Oregon, ILS Runway 14. Note the turning missed approach and a higher
DA/H for each higher approach category.
I am questioning it because I have also seen straight-in minimum visibility
step-up for higher approach category a/c where the missed approach is NOT a
turning one. So clearly, at those approaches, turn radius is not an issue.
An example of this would be the LOC29 approach at KPWM.
Visibility minimums are based on Approach Category and the geometric relationship
of the height of the MDA or DA/H. It is not directly related to any turning
missed approach issue.
Also, well -- I don't know if you use Jepp charts or NOS charts. But on my
Jepp charts, the minima for straight in approaches is subdivided by
aircraft category. The minima for circle-to-land approaches is subdivided
by speed in knots. To me this suggests that the maneuvering speed is
important only in the circle-to-land approach, and not in the straight-in
approach.
The information in the AIM, and in the FAA Instrument Flying Handbook, and
an FAA inspector with whom I used to fly from time to time, all have
indicated to me that the increased category minima for increased a/c
maneuvering speeds only apply to circling approaches, at least for TERPS'd
approaches.
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 03:13 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 1st 04 02:31 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 03:07 AM
