18m Nationals weight restriction at Seminole
Old March 9th 18, 02:06 AM posted to rec.aviation.soaring
Andrzej Kobus
Default 18m Nationals weight restriction at Seminole
I just found out that due to a short runway at Seminole a decision was made to restrict the weight of each glider to 1150 lb. Supposedly the decision was made after consultation with pilots, not sure with whom. I would love to know who thought that it was a great idea. This leaves gliders with higher wing area (mostly self launchers) at disadvantage. E.g. ASH-31 Mi would have to fly with lower wing loading by 1.1 lb/sq foot comparing to ASG-29. It puzzles me greatly who made this decision and why. A much more reasonable solution would have been to limit the wing loading for each glider. That is how it is done in a Grand Prix event. In my opinion it is the only fair way to limit weight at such a low, for 18 m class, weight range. I don't think an organizer should be able to limit weight effectively creating a different class. I decided to withdraw from the competition. It is one more reason contest participation is dropping.
Old March 9th 18, 03:19 PM posted to rec.aviation.soaring
Kevin Christner
Wilbur Wright personally approved of this limit. He and asw20pilot are very positive on Seminole Lake.
Old March 9th 18, 04:05 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
There are two reasons for this approach:
1) Takeoff distance is driven primarily by takeoff weight and only secondarily by wing loading. A full aerodynamic factor analysis of takeoff performance was done to confirm this fact. A wing loading limit would have allowed gliders with larger wing area to take off at a heavier weight than smaller wing area gliders, compromising the takeoff safety goal.
2) FAI and Grand Prix rules are different. Grand Prix attempts to handicap gliders, FAA decidedly does not. Some glider designs are optimized for running at high wing loading and give up some climbing ability and others are the opposite. Pilots choose to fly different gliders in part because they are making choices for one design strategy over others. FAI rules specifically allow for different wing loading design strategies. The maximum wing loading of the various 18M gliders in this contest range from 10.4 lbs to 12.3 lbs. Setting a wing loading limit would have eliminated these design differences on the run while forcing smaller wing area designs to fly with a climb tradeoff. A wing loading limit would advantage large wing area gliders and disadvantage low wing area gliders as compared to flying within the normal limits of the 18M FAI class.
The minimum intervention in the relative competitiveness of gliders to achieve the takeoff distance goal for this airport is therefore takeoff weight. The approach you suggest would have conferred an advantage to the specific glider you are flying that is not part of the philosophy or rules of the FAI 18M class.
Hope that helps.
Andy Blackburn
9B
For the Rules Committee
Old March 9th 18, 04:35 PM posted to rec.aviation.soaring
Andrzej Kobus
On Friday, March 9, 2018 at 11:05:04 AM UTC-5, Andy Blackburn wrote:
"The approach you suggest would have conferred an advantage to the specific glider you are flying that is not part of the philosophy or rules of the FAI 18M class"
Andy, I can't believe what you wrote, did you read it before you sent it? Did you write it in the name of the Rules committee or is it your own opinion?
What advantage would I get, if I fly at the same wing loading as an ASG-29?
You must be kidding the 18M class weight restriction is 1320 lb. By limiting the weight you are handicapping me more than you are handicapping an ASG-29. On the east coast the optimum wing loading is around 10 lb/sq foot. You let the ASG-29 fly with that wing loading while handicapping me to 9 lb/sq foot. If not for the restriction I would be able to fly at the optimal wing loading. How is that fair? It seems to me the competition should never have been allowed to be held at an airport that can not handle the requirements of the 18 m class. Hopefully this is the last time Seminole is awarded a FAI class competition.
Old March 9th 18, 04:59 PM posted to rec.aviation.soaring
Ron Gleason
Andrej, while I understand your passion and desire to 'level the playing field' IMHO safety has to be number one priority. A 10/lb per sq ft wing loading does you no good if you are on the ground in a field or the swamp around Seminole because the tow plane had to release you for their own safety.
In 2016 at Nephi we intentionally launched the open class last each day for safety. Even with 5,000 feet plus of usable runway getting 800 Kg open class gliders in the air safely was on the margin even with the most powerful tow planes. We took heat for it but it is just the right thing to do. Yes it caused shorter tasks some days but we had 100% safety record for launches and that was our goal and priority.
Your statement 'It seems to me the competition should never have been allowed to be held at an airport that can not handle the requirements of the 18 m class. Hopefully this is the last time Seminole is awarded a FAI class competition.' is short sighted and selfish. The number of locations that are able and willing to host contests is shrinking across the US. IMO compromises, like a weight limit, are acceptable for some locations.
With that said, I do believe that the SSA contest committee and site selection committee should have caught this sooner (folks that volunteer on these committees have and do fly out of Seminole) and had this information available to interested pilots at time of sanctioning and/or registration.
Ron Gleason
Old March 9th 18, 05:08 PM posted to rec.aviation.soaring
If 1150lb is what is decided as the max safe tow weight, then you could set the wing loading limit to highest entered wing area glider / 1150lb.
Handicap on wingloading, advantage the JS1. Handicap on weight, advantage the ASG29.
¯\_(ツ)_/¯
Andrej, while I understand your passion and desire to 'level the playing field' IMHO safety has to be number one priority. A 10/lb per sq ft wing loading does you no good if you are on the ground in a field or the swamp around Seminole because the tow plane had to release you for their own safety..
Ron Gleason
Old March 9th 18, 05:27 PM posted to rec.aviation.soaring
Andrzej Kobus
¯\_(ツ)_/¯
Absolutely, that is how they should have done this to be fair.
Old March 9th 18, 08:27 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
Hi Andrzej,
Thanks for your thoughts.
This was exhaustively analyzed and debated over a period of weeks, not a knee-jerk decision. I did supporting analysis, but the waiver request was from the contest organizers and approved by the SSA Board. Feel free to blame me as I support the approach taken and I meant exactly what I said above.
There were three approachers considered:
1) Fixed wing loading
2) Fixed MTOW
3) Fixed % reduction in MTOW from max certified
The criteria were basically twofold:
1) Address as directly as possible the concerns related to takeoff distance over an obstacle
2) Minimize any alteration to the existing relative performance differences across glider types - that is, minimize handicapping by glider type.
The maximum certified wing loading of gliders flying in 18M Class under the rules a
HpH 304S - 10.4 lbs/sf
ASH-31Mi - 10.8 lbs/sf
JS1C-18 - 11.0 lbs/sf
Ventus 3 - 11.3 lbs/sf
ASG-29 - 12.3 lbs/sf
JS3 - 12.4 lbs/sf (none signed up as of this writing)
Without any weight restrictions, the ASH-31 and JS1 would fly at close to 1..5 lbs lower maximum loading that the ASG-29 and JS3 and about half a pound lighter than the Ventus 3. A percent weight limit preserves the proportionate max wing loading differences but reduces the absolute differences by the amount of the % reduction. Setting a weight limit closes that gap to closer to 1 lb/sf and a wing loading limit totally eliminates it - effectively handicapping the higher wing loading gliders. To answer your specific question, handicapping most of the gliders other than yours gives you a benefit that you wouldn't otherwise have. I can see why you would prefer this as it would help you compete under strong conditions in particular.
However, there is nothing in the letter or the spirit of the rules governing 18M class (unlike Sports Class or SGP racing) that says we should handicap the performance of gliders - quite the opposite. People in non-handicapped classes purchase gliders for the specific design and performance tradeoffs of that design and have a right to expect that those choices wouldn't be deliberately diluted through changes in the rules. Motor gliders present some unique challenges because the designs represent an inherent tradeoff in wing loading range to accommodate a motor. That's the choice you make when you buy a motorglider - there are some benefits and some tradeoffs.
The other point is a wing loading limit doesn't purely address the takeoff distance challenge. It allows gliders with more wing area to fly at a higher MTOW, making them less safe in terms of takeoff distance due to higher rolling friction on soft ground, slower acceleration under the same thrust, etc. I can take you through the calculations if you like. Restricting takeoff weight is the clearly preferred safety option - it most directly addresses the takeoff distance challenge and does a decent job not changing the competitive capability differences across gliders (actually a % MTOW reduction does slightly better, but does less well on simply addressing the takeoff distance requirement).
I can see why you would have preferred a wing loading limit as it would have benefitted you by reducing the wing loading gap you'd otherwise have faced versus other gliders, but it's not the job of the Rules Committee (or the organizers or the SSA Board) to change that differential for you - particularly if it does a less good job at addressing the primary safety objective..
These issues are not simple to address as there are many moving parts. We attempt to maintain a safe and fair competitive environment consistent with the letter and spirit of the rules, but clearly different alternatives to addressing specific challenges will affect different gliders and pilots differently. Our attempt here is to minimize the changes in the competitive differences between gliders. I'm very comfortable this does the best job of all the alternatives, none of which is 100% perfect. The perfect solution is a longer runway, but that wasn't a realistic alternative.
Andy
Old March 9th 18, 09:50 PM posted to rec.aviation.soaring
Andrzej Kobus
Hi Andrzej,
2) Fixed MTOW
Without any weight restrictions, the ASH-31 and JS1 would fly at close to 1.5 lbs lower maximum loading that the ASG-29 and JS3 and about half a pound lighter than the Ventus 3. A percent weight limit preserves the proportionate max wing loading differences but reduces the absolute differences by the amount of the % reduction. Setting a weight limit closes that gap to closer to 1 lb/sf and a wing loading limit totally eliminates it - effectively handicapping the higher wing loading gliders. To answer your specific question, handicapping most of the gliders other than yours gives you a benefit that you wouldn't otherwise have. I can see why you would prefer this as it would help you compete under strong conditions in particular.
Andy
Andy, your reasoning is completely flawed because on the east coast no one flies with wing loading of 12. You so called solution allows some glider to fly at optimum wing loading for the east coast while handicapping higher wing area gliders. I hope you can understand that. If the contest was held in Uvalde your reasoning would have been justified but not at the location the contest is going to be held. I hope you can admit this.
Again, you could take the weight 1150 divide by the highest wing area glider and establish weight for each of the 4 or 5 types that would never exceed 1150.
Wrong again! I was not disadvantaged on the east coast because I could not use a higher wing loading on the east coast anyway. Once again no one flies on the east coast with wing loading of 12. Your west coast 18,000 cloud bases experience with wide thermals does not translate well to making rules on the east coast.
Old March 9th 18, 10:31 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
Hi Andrzej,
2) Fixed MTOW
Andy
Andrzej,
Your proposed solution is to set the takeoff weight for your glider suitable to meet the takeoff requirement and then put an additional (and unnecessary to the safety goal) weight reduction on other gliders with less wing area. It's not in the spirit or letter of the rules to force other gliders down to an artificially reduced wing loading. If they can take off at a higher wing loading and you can't because your glider is heavier, it's not up to the rules to equalize that any more than it is the job of the rules to equalize it in a situation without a runway limitation.
It did not escape anyone that on any given day the optimal wing loading may be anywhere across a range of possibilities depending on conditions - or that average thermal strength is generally lower in the east than the west. The issue is should we impose an additional wing loading reduction on other gliders with less wing area than the heaviest ones flying even though there is no reason to do it from a takeoff perspective?
I appreciate that you may have the view that the optimal wing loading in Florida is no more than 9 lbs/sf and that suits you and your glider, but there are many other gliders and many other pilots as well. For instance a JS3 would be forced to take off 200 pounds lighter than an ASH-31mi to meet 9 lbs/sf. When faced with the requirement of limiting weight for safety purposes, there's simply no rationale in the rules for imposing additional restrictions beyond what's required for safety.
If you'd like to introduce a proposal that we impose a maximum wing loading in 18M class as a general rule we could certainly survey the pilots and see if there is broad agreement, but it's not in the rules now. These decision need to be made based on a consistent set of principles, not what suits one person or another or one glider or another.
Andy Blackburn
9B
Glider Weight/Wing Loading and determing speed for best L/D for a given weight 65E Soaring 3 January 26th 06 09:26 PM
250 KIAS SPEED RESTRICTION Thomas J. Hammond Piloting 23 October 19th 05 08:49 AM
A Temporary Flight Restriction is like ... Larry Dighera Piloting 1 August 19th 05 03:21 AM
Age restriction for ATC? Snoopy Piloting 5 November 17th 04 08:16 PM
Received my first speed restriction Peter R. Piloting 14 March 12th 04 08:56 PM
