As a fairly new transitioned glider pilot I am interested in
information concerning wing loading and determining the speed to achieve best L/D and effects on Minimum Sink I think I have a basic understanding of the effects wing loading has on the flight of the glider. The heavier the wing loading the move lift needed to climb and the climb will be slower than a glider with light wing loading. Once the altitude is gained the heavier glider will have the higher speed between thermals as long as the correct speed for the weight of the glider is flown. I am also researching the used glider market for one day purchasing a glider. Which leads to what I am asking here. Is there an optimum wing loading that is the best middle of the road for performance? And, which gliders would exhibit them; LS3, LS4, ASW 19, DG300, Mosquito for example? What weight is used by the manufacturer to determine the wing loading when it is published? All up max weight or some other arbitray value? What weight is the glider flown at when the manfacturer is determining the polar? Once you have determined the weight of the glider How do you determined the airspeed for best L/D and min sink? Or, is this all non-issue? Thanks 65E |
Here start playing with the spreadsheet contained in this thread
http://www.gliderforum.com/thread-view.asp?threadid=32 Al |
It's definitely not a non-issue, but requires a different perspective.
Assuming you are an experienced power pilot, you are used to going into the airplane's performance charts and determining hard numbers to set such things as cruise power, takeoff and landing distances, etc - all based on actual loading of the plane. The bigger the plane, the more critical (and precise) this becomes. Gliders are different, for one big reason - you are trying to optimize your performance (be it climb or cruise) in a constantly changing environment. Every thermal will be of different strength, size, turbulence. Every glide will be through a different airmass, with different quantities (and gualities!) of lift and sink. So it becomes less a matter of determining a hard number to set on the airspeed indicator, and more a matter of always analyzing what point on the polar (or performance range, if you will) you want to be at for the immediate conditions, and for the goal of the flight (just floating around the field or going for that 500k). More specifically, wing loading is about going faster XC. As a rough rule of thumb, a full load will bump all your reference speeds up about 10 knots. You will find that you rarely fly at L/D max. If there is any lift at all you will be cruising at least 10 - 20 knots faster. And min sink when thermalling is the lowest speed you can comfortably fly and climb at the wingloading and bank angle you decide on. And this has to be pretty much determined by trial and error, although most glider manuals have charts that are starting points. Suggestion: Get a hold of Reichmann's "Cross Country Gliding" - the first half is invaluable. Good luck! Kirk 66 |
65E wrote:
Which leads to what I am asking here. Is there an optimum wing loading that is the best middle of the road for performance? And, which gliders would exhibit them; LS3, LS4, ASW 19, DG300, Mosquito for example? Don't think about those other ships. You want a Mosquito. ;-) Shawn |
