Sailplane Canopy
Old August 20th 18, 09:32 PM posted to rec.aviation.soaring
Default Sailplane Canopy
I'm wanting to find out the manufacturer contact info of the sailplane canopies specifically a Libelle 201 that are located in Colochester. Gram Drinkell mentioned they can produce a 201 canopy for 400 pounds. I'd like to have contact info for this company.
Old August 21st 18, 05:36 AM posted to rec.aviation.soaring
Tango Whisky
Why don't you try to contact Mecaplex in Switzerland?
Old August 21st 18, 07:25 AM posted to rec.aviation.soaring
Expensive...
Old August 21st 18, 07:54 AM posted to rec.aviation.soaring
Ross[_3_]
Mecaplex won’t sell direct
You need to go to Streifeneder
Expensive yes, but will fit and be good first time
Gliding is generally not a cheap sport when it comes to spare parts
Old August 21st 18, 06:26 PM posted to rec.aviation.soaring
For older gliders - a canopy replacement can approach half of the total glider value or more. So more cost effective canopies are then required.
Old August 21st 18, 07:44 PM posted to rec.aviation.soaring
It isn't any less expensive to produce a canopy for an older glider. Nor is it less expensive to install them. Shipping from Yerrup, if coming from there, is the same.
Sometimes cheap gliders aren't so cheap.
Unfortunately that is just how it is.
UH
Old August 22nd 18, 01:02 PM posted to rec.aviation.soaring
FranCP
I'd recently bought a front canopy and 2 sliding windows for a Fournier RF5 in Argentina, the company is called Plásticos Sampaolesi
http://www.sampaolesiplastic.com.ar/aero.php
Fair price (1/4 than Mecaplex), and actually surprisingly good optical quality. I know shipping may be an issue, but i think worth to ask for a quotation. Besides, they have lots of old gliders flying in Argentina, maybe they have the mould, or access to one.
Old August 23rd 18, 10:42 PM posted to rec.aviation.soaring
Ross[_3_]
Having owned 2 201 and 2 301 I would really like to know what the difference in the blank canopy is. Surely it cannot be a great deal if anything at all
Fitted a racing canopy to both and I am not sure I could tell you the difference
Here are some pics of that operation and a little more
https://drive.google.com/open?id=0B3...3VfZkdsdFV0cmc
It was a load of work but well worth it in the end
Old August 24th 18, 12:02 AM posted to rec.aviation.soaring
George Haeh
Google for "aircraft canopy makers". There's several.
Old August 24th 18, 12:05 AM posted to rec.aviation.soaring
Craig Funston[_3_]
Beautiful Libelles Ross!
Fitting something like a libelle canopy that doesn't flow into the curvature of the forward fuselage is much more challenging than typical canopies. Lots of small cuts and trial fits.
Cheers,
Craig
DG 100 canopy? Pete[_9_] Soaring 6 December 5th 17 11:03 PM
Looking for a new canopy for KA-6 [email protected] Soaring 4 November 27th 17 10:27 PM
Canopy Ejection and Canopy Lanyard Casey[_2_] Soaring 6 April 12th 16 05:09 PM
K8 Canopy Jack Wyman Soaring 0 June 9th 04 08:36 PM
SGS 2-32 canopy? Gary Boggs Soaring 0 January 6th 04 11:21 PM
