DG 100 canopy?
Old November 29th 17, 06:03 PM posted to rec.aviation.soaring
Pete[_9_]
Default DG 100 canopy?
Hi all,
I'm looking for a DG 100 canopy used or new in the USA. I thought I would try here as this Group also helped me find the glider that needs the canopy.
It's old, scratched, and poorly installed. There's a lot of excess "goop" around the frame. Seems like new one would be best. I know it may cost me as much as the glider costs though!
I understand I can contact DG, but it will be $6,000+ for the canopy and another $500 for the service contract and then $400 annually.
I've avoided it since 2013, hopefully going to continue....
Old November 29th 17, 06:12 PM posted to rec.aviation.soaring
Hi Pete,
it may be worth getting in touch with Plexi Weiss (https://www.plexiweiss.de/en/home.html). They have the molds to produce new canopy glasses for DG gliders at quite reasonable prices, including a C of C. Shipping from Germany may be expensive, though. You will also need someone to mount it to your canopy frame.
Best
Christoph
Old November 29th 17, 07:29 PM posted to rec.aviation.soaring
Dan Marotta
You didn't say where you're located, but Fidel at One Air Composite in
Moriarty, NM does excellent work, including acquiring the plexiglass.
On 11/29/2017 11:03 AM, Pete wrote:
Hi all,
Dan, 5J
Old November 29th 17, 11:21 PM posted to rec.aviation.soaring
On Wednesday, November 29, 2017 at 1:03:13 PM UTC-5, Pete wrote:
Hi all,
Hey Pete,
I can't help you directly, but there are several companies that "make" or "distribute" canopies in the US. I would do a google search and see what it brings up.
I do have a question for you? What kind of trailer do you have?
I just had a DG101g deliver a few weeks ago, and when the a-hole left, he did not give me the keys. When asked he said he put them in the front of the trailer, but nothing there, and claims they are not in his pockets.
So after looking at the glider, I closed the back door thinking it was unlocked. It is locked, do not understand that, but can't get it open. So now have a glider that I can't do any winter work on because I can't get into the trailer. and the fuselage is a tight fit out the front.
I have a vintage Pfieffer trailer. Hoping you might have a matching trailer? Keys? Let me know! Thanks!
Old November 30th 17, 12:24 AM posted to rec.aviation.soaring
JS[_5_]
Hi all,
Hey Pete,
Eagle:
Believe the Pfeiffer locks are Volkswagen parts.
Should be an easy blank to find. A locksmith should be able to get you up and running.
Old November 30th 17, 01:45 PM posted to rec.aviation.soaring
Pete[_9_]
Thanks for the links guys. I will continue my search there....
Eagle....Bummer about your trailer but score on the glider!! The best club class glider out there IMO!!! For what it's worth I don't even have a lock anymore. I took mine off the cylinder gave out and I had to unbolt it from the mechanism. Now I use a screw driver to lock and unlock the hatches.
Thanks for your help everyone. I'm on the East Coast. Moriarity is too far....
Old December 5th 17, 11:03 PM posted to rec.aviation.soaring
2G
On Wednesday, November 29, 2017 at 10:03:13 AM UTC-8, Pete wrote:
Hi all,
This hated service contract has effectively devalued most used DG and LS gliders. Check it out BEFORE you buy any of any DG or LS glider so that you aren't unpleasantly surprised when you need some minor spare part.
Tom
Looking for new or used canopy Troy Hartman Soaring 1 December 12th 16 12:44 AM
Canopy Ejection and Canopy Lanyard Casey[_2_] Soaring 6 April 12th 16 05:09 PM
1-35 Canopy [email protected] Soaring 14 April 30th 08 06:18 PM
Need 1-26E Canopy USA [email protected] Soaring 2 March 5th 08 12:23 AM
SGS 2-32 canopy? Gary Boggs Soaring 0 January 6th 04 11:21 PM
