Hard wax v/s liquid wax
Old August 28th 18, 01:30 PM posted to rec.aviation.soaring
FranCP
Default Hard wax v/s liquid wax
Hi,
Can hard wax be replaced by liquid wax application? Of course silicon free, as well as other harmfull adds.
Although i've seen guys maintaining their gliders purely on applying liquid wax regularly, i guess it wont seal & protect the gelcoat as well as a good anual hard wax buffing.
¿Any advice?
Thanks
Old August 28th 18, 01:41 PM posted to rec.aviation.soaring
On Tuesday, August 28, 2018 at 8:30:22 AM UTC-4, FranCP wrote:
Hi,
¿Any advice?
Thanks
Liquid wax is good for maintaining but is not a substitute for the sealing properties of hard wax on polyester finishes.
Hard wax buff, then maintain with liquid wax.
UH
Old August 28th 18, 04:27 PM posted to rec.aviation.soaring
Soartech
Please name a few brands and types of typical "hard wax" for use on gelcoat.
Thanks.
Old August 28th 18, 04:41 PM posted to rec.aviation.soaring
Ross[_3_]
Menzerna seems to be the pick of the bunch here in Europe
G18 first and something like M5 or P175 to give it a glossy finish
Old August 28th 18, 09:38 PM posted to rec.aviation.soaring
Tom BravoMike
Generally, we believe that the smoother and more glossy the surface, the better. Is it actually supported by a scientific research? How about the 'stickiness' of certain substances with regards to the airflow, e.g. caused by electrostatic charge? Any thoughts?
Old September 1st 18, 04:38 AM posted to rec.aviation.soaring
Soartech
Getting back to "what is hard wax?" M&H tells me it is also known as Jeweler's rouge, a stick of a very hard wax that contains a very fine abrasive such as iron oxide (reddish brown) and is used with a cloth wheel to polish metals (or gelcoat).
It is totally different from softer, protective waxes such as paste wax, Carnuba, etc. and is used as a polishing agent, not for protection.
Old September 1st 18, 05:19 AM posted to rec.aviation.soaring
Jonathan St. Cloud
What is recommended for polyurethane finishes?
Old September 1st 18, 07:06 AM posted to rec.aviation.soaring
Non silicone containing good quality (preferably UV filtering) car hand application polish is ideal for PU.
Old September 1st 18, 01:44 PM posted to rec.aviation.soaring
The rouge provides polishing action and the wax carrier is deposited on, and worked into the surface by the resulting heat of polishing. This seals the gelcoat.
After completing, I usually go over with Scotchgard Marine Liquid wax to do final clean up and provide added protection. I think M&H does the same thing.
UH
Old August 28th 18, 04:50 PM posted to rec.aviation.soaring
Tim Taylor
I have had good results recently with Big White Hi-Temp Paste Wax. Put in on thin by hand or smooth pad at low rpm with a random orbit machine. Let dry to a haze, hand wipe off with a clean cloth. Buff with a finishing pad at higher rpm.
As with painting, surface prep before waxing is critical for best results. Remove hard water stains (ehite viniger usually works), polish with an ultrafine compound like 3m Finesse-it II (white color). Be careful of the new 3M ultrafine compound for cars that is blue in color, it can stain white gel coat if left on the surface more than a few seconds.
Saturn V S-IC Stage Liquid Oxygen Tank 6414299.jpg [email protected] Aviation Photos 0 April 12th 07 01:32 AM
Saturn I Liquid-Oxygen (LOX) Tank 6000382.jpg [email protected] Aviation Photos 0 April 10th 07 09:59 PM
Liquid oxygen equipment for glider Bruno Maes Soaring 14 February 25th 07 04:46 PM
Liquid Shim Boelkowj Home Built 1 April 17th 04 06:30 AM
Liquid to liquid coolers Paul Millner Home Built 2 July 5th 03 02:32 PM
