Liquid oxygen equipment for glider
Old February 24th 07, 01:33 PM posted to rec.aviation.soaring
Bruno Maes
Default Liquid oxygen equipment for glider
Has someone ever implemented a liquid oxygen system inside a glider?
Old February 24th 07, 03:22 PM posted to rec.aviation.soaring
Tony Verhulst
Of course! See http://en.wikipedia.org/wiki/Perlan_Project.
Google is your friend,
Tony V.
http://home.comcast.net/~verhulst/SOARING
Old February 24th 07, 04:00 PM posted to rec.aviation.soaring
Bill Daniels
I looked into this seriously a few years ago. The earliest aviation O2
systems in WW1 used liquid oxygen systems. LOX has some advantage and some
serious disadvantages.
Positives:
Long duration supply for extended wave flights.
Light weight compared to compressed oxygen of comparable duration.
Small size
Negative:
Short shelf life . i.e. "use it or lose it".
Difficult support system. Essentially, LOX must be manufactured on the
gliderport for it to make sense. Such "air reduction" devices do exist for
medical LOX but they are expensive.
LOX can be dangerous for inexperienced people to handle.
The temptation is that used "wearable" medical LOX systems are available on
E-Bay cheap.
Bill Daniels
"Tony Verhulst" wrote in message
Tony V.
Old February 24th 07, 05:10 PM posted to rec.aviation.soaring
Vaughn Simon
"Bill Daniels" bildan@comcast-dot-net wrote in message
Negative:
I have a bit of experience using medical lox and the above need not be
true. Patients who use lox keep a device at home that looks a lot like at beer
keg. A guy in a truck comes around every week or two to top the "keg" off. The
oxygen can be used straight from the "keg" or transfered to a portable oxygen
system. Assuming that there were enough users to make it pay, that same truck
could come by a gliderport. Naturally, it is those portable oxygen systems that
are of prime interest to aviators. Many of them have a pulse system to conserve
oxygen and make it last even longer. I have no idea if they would be safe for
aviation use, but I think that we can safely assume that they are not built with
that in mind.
Yes.
E-Bay cheap.
Yes. I covered that above.
Vaughn
Old February 24th 07, 06:28 PM posted to rec.aviation.soaring
Ralph Jones[_2_]
On Sat, 24 Feb 2007 16:10:38 GMT, "Vaughn Simon"
Negative:
system.
I take it the capability to fill portable containers is the motivation
for using lox, as opposed to using a concentrator?
rj
Old February 24th 07, 07:12 PM posted to rec.aviation.soaring
Eric Greenwell
What mission do you have in mind?
Old February 24th 07, 07:56 PM posted to rec.aviation.soaring
nimbus
Not really a mission in mind but more an engineering challenge...
What equipment of small size does exist? Is it easier to use than the
classical A14 oxygen regulator or EDS?
I searched a lot on the internet for pictures, detailed schematic
etc...but found nearly nothing except very general text I can't use.
Bruno
Old February 24th 07, 08:15 PM posted to rec.aviation.soaring
bumper
news:8e%Dh.667$RN6.579@trndny07...
Eric,
One step at a time, buddy. First we get the LOX tanks on-board, then we add
the kerosene . . .
bumper
Minden NV
QV & MKII
Old February 24th 07, 08:39 PM posted to rec.aviation.soaring
Dan G
People might be interested in the British Summit Oxygen systems,
originally designed for HA climbing - http://www.summitoxygen.com/index.php
.. It uses a cannula instead of a face mask and an electronic pulse-
dose meter system, which can supply up to 22 hours of oxygen from one
bottle.
Few climbers use Summit sets as they proved very unreliable on
Everest. The British Army and Navy rave about them, but that's
probably because the company was set up by two ex-Royal Engineers. Get
Mapping uses them in their aircraft, apparently.
Climbers instead use the simple but effective Russian Poisk system
that afaik has never had a failure, but requires many more bottles to
be carried. While the fancy design of the Summit system is unsuitable
for climbing, it's probably alright in the gentle environment of a
glider.
Dan
Old February 24th 07, 08:58 PM posted to rec.aviation.soaring
Vaughn Simon
"nimbus" wrote in message
"What equipment of small size does exist?"
Medical systems can be about the size of a thermos flask, and (these days)
often include a pulse system.
Vaughn
New Oxygen Equipment For Sale [email protected] Soaring 0 September 10th 06 10:04 PM
Oxygen equipment for sale [email protected] Soaring 0 May 29th 05 03:18 AM
Oxygen equipment Roger Worden Soaring 1 May 9th 05 03:59 PM
Liquid Shim Boelkowj Home Built 1 April 17th 04 07:30 AM
Liquid to liquid coolers Paul Millner Home Built 2 July 5th 03 03:32 PM
