MIT's Ion-drive sustainer takes flight
Old November 22nd 18, 02:33 PM posted to rec.aviation.soaring
son_of_flubber
Default MIT's Ion-drive sustainer takes flight
https://techxplore.com/news/2018-11-...ver-plane.html
Old November 22nd 18, 02:41 PM posted to rec.aviation.soaring
son_of_flubber
https://phys.org/news/2013-04-thrust...ternative.html
Old November 22nd 18, 03:26 PM posted to rec.aviation.soaring
teck48[_2_]
This was a cover story in popular mechanics in the mid sixties. A gentleman named De Seversky I think. I started building one planning to figure out how to use a van de graf generator to provide the ~100K volts. My parents weren’t too enthused...
Old November 22nd 18, 04:56 PM posted to rec.aviation.soaring
Dan Marotta
Or something like this: https://en.wikipedia.org/wiki/Project_Pluto
And it wouldn't even need those nasty batteries!
Dan, 5J
Old November 22nd 18, 05:59 PM posted to rec.aviation.soaring
I saw that on a car forum. While interesting, I wish they had a RC modeler help with rigging the craft. I also wonder how much the launch device added to the flight distance......basically, would it have gone close to as far just due to the launch?
Old November 22nd 18, 09:56 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
On Thu, 22 Nov 2018 09:59:05 -0800, Charlie M. (UH & 002 owner/pilot)
I'd guess they had model fliers involved: the wing looks very much like a
free flight model wing and looks to be about the same size (2.5m span) as
a modern F1A wing and the flying speed looks similar to an F1A as well.
I looked for a launcher but couldn't see one, so maybe it was hand
launched. That would be easy enough: use a timer to turn on the high
voltage after its 1-2 meters away from the launcher. The launch looked
nice and smooth, which also points to a model flyer doing it.
Also, MIT is Mark Drela's home territory: he's long been heavily involved
in RC soaring and low speed aerodynamics and is the man behind X-Foil.
Martin | martin at
Gregorie | gregorie dot org
Old November 22nd 18, 11:11 PM posted to rec.aviation.soaring
Wen it flies off the ramp, look for the long black bungee (20' or so long) that is visible at the top of the ramp.
Old November 22nd 18, 11:50 PM posted to rec.aviation.soaring
On Thu, 22 Nov 2018 15:11:04 -0800, Charlie M. (UH & 002 owner/pilot)
Thanks: I missed that, at least partly because I couldn't stop the first
video on https://techxplore.com/news/2018-11-...ver-plane.html and
didn't think to watch the second one, which shows a lot of launches from
directly behind the test aircraft.
Martin | martin at
Old November 23rd 18, 12:32 PM posted to rec.aviation.soaring
teck48[_2_]
https://images-na.ssl-images-amazon....fL._SY445_.jpg
Old November 22nd 18, 10:16 PM posted to rec.aviation.soaring
Luke Scharf
On Thursday, November 22, 2018 at 12:59:07 PM UTC-5, Charlie M. (UH & 002 owner/pilot) wrote:
Here are two papers from Steven Barrett on the topic:
http://rspa.royalsocietypublishing.o.../2175/20140912
http://rspa.royalsocietypublishing.o...20120623.short
They're from 2013 and 2015, so they may not answer any questions about this specific demonstration. I imagine that Dr. Barrett is working on publishing another paper which should answer those questions directly.
-Luke
Facebook's massive solar-powered drone takes its first flight Larry Dighera Piloting 1 July 25th 16 03:25 AM
Flight training before learning to drive? Ricky Piloting 18 May 15th 09 11:45 PM
X-48B Blended Wing Body Research Aircraft Takes First Flight [1 attachment] §qu@re Wheels[_4_] Aviation Photos 5 July 30th 07 06:17 AM
Local reporter takes an intro flight Tony Cox Piloting 28 February 25th 07 05:14 AM
DG goes the sustainer option. Paul Soaring 25 June 4th 04 12:16 AM
