Life glider hours with winch
Old March 21st 19, 05:14 PM posted to rec.aviation.soaring
Default Life glider hours with winch
Hi all.
I listened from some pilots that the glider life hours reduce if you use winch start.
Is that true? I looked for some data about and I did not found.
have a nice day, José.
Old March 21st 19, 05:31 PM posted to rec.aviation.soaring
Frank Whiteley
On Thursday, March 21, 2019 at 11:14:42 AM UTC-6, wrote:
Hi all.
Any life adjustment issues should be in the POH or the maintenance manual. There were adjustment factors on our L-23 for winch launches, flying with the wing tip extensions, solo/dual flight, or for aerobatic flight.
Frank Whiteley
Old March 21st 19, 06:52 PM posted to rec.aviation.soaring
José Ignacio Otero
Hi all.
Any life adjustment issues should be in the POH or the maintenance manual.. There were adjustment factors on our L-23 for winch launches, flying with the wing tip extensions, solo/dual flight, or for aerobatic flight.
Frank Whiteley
Hi Frank,
Thanks for reply, L-23 is an special situation with the AD in the wing roots.
What about K-13, Ka-6, Libelle, Std Austria, Lak-12, Std Cirrus, ASW-20...
Old March 21st 19, 07:45 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Hi all.
use winch start.
flight.
Frank Whiteley
Hi Frank,
roots.
ASW-20...
There is nothing my Std Libelle's POH about launch method affecting
airframe lifetime. AFAIK they are fitted as standard with both CG and
nose hooks. Mine was, and so are the other two others based at the club.
Re-life inspection is at 3000 hours regardless of launch method.
Martin | martin at
Gregorie | gregorie dot org
Old March 22nd 19, 11:41 AM posted to rec.aviation.soaring
José Ignacio Otero
Thansk Martin !!
Hi all.
use winch start.
flight.
Frank Whiteley
Hi Frank,
roots.
ASW-20...
Martin | martin at
FS/T: Glider Winch Towline Chutes Vicarious Icarus Soaring 6 July 31st 17 10:20 PM
Motorglider hours same as glider? [email protected] Soaring 13 October 1st 15 04:56 PM
Glider Hours Walt Connelly Soaring 18 April 29th 11 10:17 PM
Biggest Glider Ever Launched via Winch? [email protected] Soaring 25 November 22nd 06 10:17 PM
Glider hours count towards ATP? Michael Soaring 1 November 9th 03 02:24 AM
