Motorglider hours same as glider?
Old September 28th 15, 10:22 PM posted to rec.aviation.soaring
Default Motorglider hours same as glider?
I understand you can use glider hours towards a private pilot license, but can you use motor glider hours toward a glider pilot license?
Old September 28th 15, 10:45 PM posted to rec.aviation.soaring
A glider certificate has 3 endorsements for launch.
Aero tow
Ground launch(winch or auto)
Self launch
Flying a self launch sailplane is a way to get a glider certificate. Then additional training is required to get endorsed for the other launch types.
UH
Old September 30th 15, 05:16 AM posted to rec.aviation.soaring
Frank Whiteley
Aero tow
Self launch
UH
Unless things have changed, I don't think a student can solo in self-launch under the SSA Group Plan. There may be other options.
Frank Whiteley
Old September 30th 15, 04:21 PM posted to rec.aviation.soaring
Dan Marotta
"I don't think a student can solo in self-launch under the SSA Group Plan."
That has been my experience. I bought a Pipistrel Sinus with the
intention of teaching my wife to fly in it. Costello said, "NO, only
/_licensed_/ and /_named_/ pilots" can fly a motor glider on their policy.
....So she's learning in a G-0102...
Aero tow
Self launch
UH
Frank Whiteley
Dan, 5J
Old September 30th 15, 06:38 PM posted to rec.aviation.soaring
Soartech
Consider yourself lucky that there is one in your state.
They are rare in the northeast.
Old September 28th 15, 10:51 PM posted to rec.aviation.soaring
son_of_flubber
From http://www.ssa.org/GliderPilotRatings
"Holders of a valid FAA Power plane license with 40 hours as pilot-in-command need a minimum of 10 solo flights to qualify to take the glider flight test. No written exam is required to add a glider rating to a power license. In all cases, refer to the Federal Aviation Regulations for details on pilot licensing."
Your CFI-Glider decides how many glider flights you need before you receive the endorsement to fly solo in the glider. The amount of pre-solo training that you require depends on your present skill and aptitude. In that sense, your experience in a motor glider may help you to solo sooner (or later).
Old September 28th 15, 11:54 PM posted to rec.aviation.soaring
Brian[_1_]
A glider is a glider...
If the FAR says required time in a glider it counts.
If the FAR says required time in an aircraft it counts.
If the FAR says required time in an airplane, it doesn't count.
Brian
Old September 29th 15, 02:18 AM posted to rec.aviation.soaring
Brian
Also, a private license is a private license. It's issued
for particular classes and categories. So, you can have a
private pilot license authorized for glider, airplane single engine land,
airplane multiengine land, or whatever. You'll have one
piece of plastic in your pocket saying "PRIVATE PILOT"
which on the back will specify what you can use it in.
Matt
Old September 29th 15, 09:02 PM posted to rec.aviation.soaring
Is there any trick to locating a motorglider/instructor other than a Google search? (Austin, TX area)
Old September 29th 15, 10:06 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Man, are you in luck!
http://www.learn2soar.net/
Just up the street from you!
Glider Hours Walt Connelly Soaring 18 April 29th 11 10:17 PM
In your country how many hours in a glider can count towards therequirements for a power license? Markus Graeber Soaring 5 December 18th 08 04:06 AM
3 Down in last 24 hours thepearl Rotorcraft 0 September 25th 05 04:29 PM
IFR in motorglider, or any glider Jim Culp Soaring 2 June 30th 04 04:50 PM
Glider hours count towards ATP? Michael Soaring 1 November 9th 03 02:24 AM
