transponder 2 year check
Old May 9th 19, 05:36 AM posted to rec.aviation.soaring
[email protected][_2_]
Default transponder 2 year check
I have a trig transponder (no ADSB yet). This transponder is not legally required in a glider. So, do I still have to get the transponder checked every two years per 91.413?
https://www.law.cornell.edu/cfr/text/14/91.413
It appears so to me, but am I missing something?
Old May 9th 19, 06:08 AM posted to rec.aviation.soaring
Darryl Ramm
Yes, there is no difference here between gliders (and other transponder partial exemption aircraft) and a VFR powered aircraft. It is clear in the regulations.
Old May 9th 19, 02:10 PM posted to rec.aviation.soaring
Jonathan Foster
This may be a silly question if at the end of two years you decide not to use the transponder anymore but leave it in your panel always turned off. Would you still legally be required to have it checked?
Old May 9th 19, 06:14 PM posted to rec.aviation.soaring
Darryl Ramm
You don’t have a simple option to leave a transponder turned off. Once installed you are required to use it in *controlled airspace*. 14 CFR 91.215....
Old May 9th 19, 08:01 PM posted to rec.aviation.soaring
My understanding of the regs.....you have the equipment (transponder), it "shall be turned on for flight onless plackered (sp) as 'inoperative'" for that flight.
I do not believe there are exemptions for standard vs. experimental.
Basically, "you got it, you use it".
Old May 9th 19, 10:20 PM posted to rec.aviation.soaring
kinsell
I think the AIM differs from the FAR's on that point. Common sense
dictates that you just keep it on.
Old May 9th 19, 06:17 PM posted to rec.aviation.soaring
Darryl Ramm
Replying again, in the right thread this time.
Old May 9th 19, 07:04 PM posted to rec.aviation.soaring
Paul Agnew
This may be a silly question if at the end of two years you decide not to use the transponder anymore but leave it in your panel always turned off.. Would you still legally be required to have it checked?
If it's not currently useable due to the being out of currency, so to speak, I would think you could legally use 91.213 d(3) (ii) to deactivate it, placard it, and go fly.
Paul A.
Jupiter, FL
Old May 9th 19, 07:29 PM posted to rec.aviation.soaring
Darryl Ramm
Paul A.
Jupiter, FL
Please no. More responsibly/safely, if maybe less complaint with regulations, fly with the transponder turned on, get it tested ASAP. Thankfully lots of clubs/FBOs are good at arranging transponder check days and getting somebody out to test all the gliders at a site in one day so this hopefully never comes up a an issue.
There should be no real excuses nowadays to flying with a transponder tuned off. As JJ mentioned, the transponder being turned off in the ASG-29 involved in the middair with the Hawker 800 (a "fast twin" :-)) near Minden was pretty unfortunate (no, OK stupid). And more recently than that events like the ASH26E (no transponder installed) close encounter with a B737 going into Chicago is a reminder that transponders are important safety devices in busy airspace, especially with TCAS equipped fast jets and airliners, etc.
Old May 9th 19, 02:12 PM posted to rec.aviation.soaring
If it is transmitting then others might depend on it, so it is good to know it is correct.
I've always found the trip to the shop pleasant because the tech was doing something a little different.
Transponder check Neal Fulco Home Built 5 September 5th 09 03:40 PM
Transponder vs. Portable Transponder Detectors John Murphy Soaring 16 December 20th 08 08:25 AM
check it out berben2 Military Aviation 0 September 16th 04 02:26 AM
Transponder check-How much? mike regish Piloting 15 December 2nd 03 01:00 AM
transponder check? Russell Duffy Home Built 10 August 15th 03 12:36 AM
