Airspace files
Old May 9th 19, 01:37 PM posted to rec.aviation.soaring
Tom (TK)
Default Airspace files
I am downloading files Club Class Nationals and came across airspace files with "xformat-SSA modifications" (I have previously used Soaringdata.info for SUA files)
What are the SSA modifications?
Old May 9th 19, 04:23 PM posted to rec.aviation.soaring
2KA
Tom,
Airspace files published in connection with contests document (exactly) the airspace that is closed to the contest. "SSA Modifications" means that the airspace vertical limits have been modified in accordance with the practice that "Airspace above closed airspace is closed to the contest". For example, the ceiling for Blass B airspace will be extended to FL180.
Again note that the reason for publishing contest airspace files is to document what airspace is closed to the contest. It is entirely possible that airspace included in files from Soaringdata.info would be missing from the contest file. For example, if there is a nearby MOA or Parachute Jump Area that the contest committee elects to keep open to the contest, that would be missing from the contest airspace file.
Lynn Alley
"2KA"
Old May 9th 19, 06:37 PM posted to rec.aviation.soaring
Tom (TK)
Thanks for the excellent explanation Lynn and thank you for providing the on-line resources!
Old May 9th 19, 10:29 PM posted to rec.aviation.soaring
John Leibacher
Note that the complete airspace file for the contest is also available, to provide you with the full picture.
John L
using airspace files on XCSOAR/ Kobo firsys Soaring 1 April 27th 16 06:00 PM
Oudie 2 airspace files 2G Soaring 4 July 1st 14 08:08 PM
US-Canada airspace/border files available Tuno Soaring 2 April 3rd 10 11:25 PM
(USA) Soaring airspace files from NFD -- now available Tuno Soaring 11 December 23rd 07 04:15 PM
Load airspace files into emap Jon Marshall Soaring 0 August 14th 05 08:56 AM
