(USA) Soaring airspace files from NFD -- now available
Old December 21st 07, 07:48 PM posted to rec.aviation.soaring
Tuno
Default (USA) Soaring airspace files from NFD -- now available
Positive control check complete:
http://www.justsoar.com/
For $20/year you get current Tim Newport-Peace (*.sua), OpenAir
(*.txt) and Google Earth (*.kml) files for your desired region, based
on the latest FAA National Flight Database (NFD), which is updated
every 28 days.
When I get the secret decoder ring for the SN-10 format, I'll endeavor
to add that too. I will also try to work with 2KA to integrate
anything he comes up with for airspace from another source --
alternatives are always good.
More info at the main page and the FAQ linked therein.
~ted/2NO
Old December 21st 07, 09:54 PM posted to rec.aviation.soaring
every 28 days.
~ted/2NO
Nice job on this Ted but I ran into a problem. I'm using GNII with a
Compaq Aero 2100.
The appearance on the downloaded file differs from the normal SUA file
when viewed using notepad. When I open the new one with notepad
everything is displayed as a continuous line of text as opposed to the
old one, which has separate lines of text for each coordinate.
When I loaded the new file into my Compaq Aero it locks up when trying
to open the files. I had to reboot to exit the program.
Wecome to the wonderful world of software programs.
Old December 21st 07, 10:35 PM posted to rec.aviation.soaring
Tuno
Gary,
What you're seeing is the difference between Windows/DOS text files
and Linux/Unix text files. They use different end-of-line characters.
My two test platforms are SeeYou (for .sua and .txt) and WinPilot (as
an actual PDA platform, using .txt) and neither of those cared, but
since your applications had trouble, we can make the software
explicitly use the Windows/DOS format.
Stay tuned.
~ted/2NO
Old December 21st 07, 11:13 PM posted to rec.aviation.soaring
Tuno
Gary,
I sent you an e-mail, the problem is now fixed, please re-run your
query and let me know how it goes on your Compaq Aero.
2NO
Old December 22nd 07, 04:05 AM posted to rec.aviation.soaring
Eric Greenwell
every 28 days.
Can my desired region be the USA? Or do I have download a bunch of
smaller areas? I'm using a full USA file now with SeeYou, which is
convenient.
Old December 22nd 07, 04:24 AM posted to rec.aviation.soaring
Tuno
Your desired region can be as big as you want. To get everything,
specify top = 89, left = -175, bottom = 0, right = 0.
Just don't open the .kml file with Google Earth -- it will gag on it.
(At least mine does, and I have a googleplex of RAM.)
2NO
Old December 22nd 07, 05:02 PM posted to rec.aviation.soaring
On Dec 21, 3:35*pm, Tuno wrote:
Gary,
Stay tuned.
~ted/2NO
Thanks for the quick fix on this!
Old December 23rd 07, 05:03 AM posted to rec.aviation.soaring
Eric Greenwell
2NO
OK, signed up, paid my money, got my airspace - good website!
One good featu the MOA's are named the same as the names on the
chart, and are the names used by the "controlling agency". The SeeYou
airspace files use numeric names that weren't recognized by anybody.
If/when we get the radio frequencies for the MOAs in the files, I will
be one happy camper!
Let the whining begin...
1) In my area (Washington and Oregon States) there are two "For reasons
of national security, pilots are requested to avoid flight at and below
1800' (or 5000'- Oregon) MSL in this area". These are displayed as
Prohibited areas, instead of something like a "warning area". Don't know
what the official designation is, but it's definitely not Prohibited.
2) The coordinates in the FAQ for pilots wanting the entire USA caused
the website to issue an error when I tried to use them. The ones I used
instead are
Top: 50
Bottom: 24
Right: -130
Left: -65
and they seemed to get the entire continental USA. I didn't try for
Alaska! Been there, done that, wouldn't mind doing it again, but not in
2008.
3) Adding small note that the numbers are Latitude and Longitude in
degrees, and W longitudes are negative (-) numbers will speed things up
for the initially clueless like me. Or let people put in N and W, in
addition.
Old December 23rd 07, 05:24 AM posted to rec.aviation.soaring
Tuno
Eric-San,
Thanks for signing up!
I'll fix the coordinates in the FAQ -- thanks for the heads up.
For the places in the northwest that you mention, when you say 'These
are displayed as
Prohibited areas, instead of something like a "warning area"', I
assume you're referring to the airspace file and not to the chart? The
nfd2sua tool (the software behind the web page) does not translate
airspace items that are in the NFD as "Prohibited" -- they will go
into the output files as Prohibited (always forever and ever).
(See the caveats on the front page -- the NFD airspaces are tranposed
to the output files "as is"; if the NFD is wrong, your airspace file
will be wrong.)
The only translation done in the nfd2sua tool is Restrictive types for
OpenAir files. NFD restrictive types Alert, Caution, MOA, Training,
Warning and Danger areas are written as "AC Q" (for "danger").
(Restricted and Prohibited use R and P, as per the OpenAir description
at winpilot.com.)
Good suggestion on the lat/lon help -- will do.
2NO
Old December 23rd 07, 05:46 AM posted to rec.aviation.soaring
Tuno
Eric,
A good example of where charts differ from (alternate) reality exists
in the area around the Grand Canyon.
If you look at a chart, it says "The airspace overlying the Grand
Canyon National Park below 18,000 feet MSL is subject to special air
traffic rules." That's *all* it says.
The National Flight Database does *not* have any restrictive or
controlled airspaces above the Big Ditch.
But if you dig deep in the FARs, section 93.305 subpart U describes 4
named areas officially designated as Class E in which you cannot fly
below 14,500 feet MSL.
I've looked at the digital charts for OR/WA and I see the areas you're
referring to. I don't know why the charts don't say "Prohibited", but
they are most definitely that subtype in the NFD.
-ted
Successful conversion of .cai files to .igc files for OLC danlj Soaring 2 August 5th 07 02:45 PM
Wichita Airspace Question and overlapping airspace Owen[_4_] Piloting 1 February 14th 07 09:35 PM
Load airspace files into emap Jon Marshall Soaring 0 August 14th 05 08:56 AM
Two airspace classes for one airspace? (KOQU) John R Piloting 8 June 30th 04 04:46 AM
Soaring Server/Worldwide Soaring Turnpoint Exchange back online John Leibacher Soaring 0 June 21st 04 05:25 PM
