Tost hook for Grob 102 Astir CS
Old May 11th 19, 04:10 AM posted to rec.aviation.soaring
soaringjac
Default Tost hook for Grob 102 Astir CS
Anyone know which nose Tost Hook model is in the Grob 102 Astir CS?
Old May 11th 19, 02:31 PM posted to rec.aviation.soaring
AS
Best to check your maintenance manual. There were different G102 models, i.e. the earlier blunt nosed ones and the later ones with a more pointy nose. That could already make a difference for the nose hook model.
If all fails, check with Robert Mudd in Moriarty - he is the US Astir guru - or LTB Lindner in Germany. They provide service for the Grob Astir line(s).
Uli
'AS'
Old May 12th 19, 01:33 AM posted to rec.aviation.soaring
soaringjac
Uli
'AS'
Thanks Uli!
Old May 13th 19, 03:46 AM posted to rec.aviation.soaring
soaringjac
So it looks like the Tost node hook for the Grob 102 Astir CS is the E-72, but looking on wings and wheels there are two version "short lever" and "standard level". Anyone know which one to get?
Old May 14th 19, 04:24 PM posted to rec.aviation.soaring
JS[_5_]
It's easy to swap the lever from the old one if needed.
Old May 14th 19, 04:29 PM posted to rec.aviation.soaring
soaringjac
ahh good to know, thanks Jim!
Std. 2 Jantar - CG Tost hook? [email protected] Soaring 6 November 28th 17 09:11 AM
Looking to buy Tost hook [email protected] Soaring 2 March 4th 17 01:02 PM
Tost tow hook STC for C-182 ? [email protected] Soaring 6 September 27th 16 01:13 AM
What could cause extremely high effort to release a Tost CG hook on aTwin Astir? Bill D Soaring 23 June 2nd 15 08:57 PM
Cessna 185 with a Tost hook? Nimbob Soaring 1 September 29th 09 12:43 PM
