What could cause extremely high effort to release a Tost CG hook on aTwin Astir?
Old May 31st 15, 11:31 PM posted to rec.aviation.soaring
Bill D
Default What could cause extremely high effort to release a Tost CG hook on aTwin Astir?
The scenario is winch rope break practice with the instructor pulling the release to simulate rope breaks.
I'm not talking about just an ordinary hard pull. This is a maximum-effort, adrenaline pumped, two-handed strain to get the release to work.
On the ground, the CG hook checks out as a little stiffer than one might prefer but otherwise normal. But trying for a mid-winch launch release it requires all the strength I can muster using both hands. Tost CG hook pull effort is not supposed to be dependent on rope tension.
The pull cable runs and pulleys have been checked and re-checked. The Tost CG hook itself is new and seems to work as advertised. There is nothing obvious one can see with the seat pans and instrument pedestal cover removed.
Any ideas?
Old June 1st 15, 01:43 AM posted to rec.aviation.soaring
Bill T
I believe I remeber a Kestral that had a "stiff release" issue. He removed the seat pan and discovered that the pan was depressing with his weight in it and binding the cable. But you said you have removed the seat pans and checked all of the cables.
My second guess would have been that there was a worn spot or nick in the "jaws" of the TOST release that might be catching on the ring under strain. But you said the TOST was fairly new. Is the TOST ring in fairly good shape and not one of the imposters that were on the market a few years back?
It would be great if you could have a cable under load at GS=0 to visually watch the release mechanism, but that is not a safe venture without a lot of precautions in set up.
BillT
Old June 1st 15, 01:58 AM posted to rec.aviation.soaring
Bill D
Default What could cause extremely high effort to release a Tost CG hookon a Twin Astir?
My second guess would have been that there was a worn spot or nick in the "jaws" of the TOST release that might be catching on the ring under strain.. But you said the TOST was fairly new. Is the TOST ring in fairly good shape and not one of the imposters that were on the market a few years back?
BillT
Both the CG hook and the ring pair are brand new. My only guess (AKA pure speculation) is an improper (and unrecorded) repair left the whole forward fuselage weak so it is deforming under winch launch loads causing the yellow-ball to CG hook cable system to bind. FWIW, I do not suspect the hook itself.
Bill D
Old June 1st 15, 02:02 AM posted to rec.aviation.soaring
Bill D
BillT
Bill D
FWIW, CS-22 regs say a CG hook operating force can't exceed 140N (31.5 Lbs-F) I'm guessing this one takes 200 Lbs-F or more.
Old June 1st 15, 02:46 AM posted to rec.aviation.soaring
Frank Whiteley
BillT
Bill D
New hook, correct hook? Correctly installed? Cracked plates? Is replacement of plates logged? Sounds like hook could be rotating under tension but you can't duplicate on ground. Cracked or broken mount plates could perhaps cause this. See these SB's
http://www.ltb-lindner.com/g-103-ad-...ofG%20hook.pdf
Old June 1st 15, 02:58 AM posted to rec.aviation.soaring
Frank Whiteley
BillT
Bill D
Has this changed since winch testing and training started, or remained consistent?
Frank W
Old June 1st 15, 03:05 AM posted to rec.aviation.soaring
Bill D
BillT
Bill D
Aircraft log show compliance with both AD's on Apr 6, 2013
Old June 1st 15, 03:12 AM posted to rec.aviation.soaring
Bill D
BillT
Bill D
Frank W
No change.
Bill T
Hate to launch again as an "experiment " without knowing what is really going on.
You said the instructor "rear" seat release pull took what you estimate is a 200 lb pull.
Is the front seat release having a problem?
Any problems with an auto back release at top of climb?
BillT
Old June 1st 15, 03:18 AM posted to rec.aviation.soaring
Bill D
BillT
Yes, rear seat release.
The front seat release hasn't been tested in flight.
The "back-release" function seems to work well at the top of the launch.
Tost tow hook STC for C-182 ? [email protected] Soaring 6 September 27th 16 01:13 AM
TOST Release Failure - Two Uncommanded Release's [email protected] Soaring 11 October 13th 12 10:23 AM
needed!! drawings/data for Tost hook for Pawnee thing73 Soaring 3 November 13th 09 02:14 AM
Cessna 185 with a Tost hook? Nimbob Soaring 1 September 29th 09 12:43 PM
Tost hook on Cessns 180 Paul Soaring 6 October 18th 04 10:32 PM
