This question is motivated by the recent discussion about deriving
polars from flight logs. We know that GPS fixes have some amount of (absolute) error. What is their accuracy relative to each other? In other words, when I'm analyzing flight logs, how accurately can I calculate something like sink rate using just the GPS fixes ("B" records)? I'm thinking about taking an early morning tow sometime this winter when the pressure is high and the air is stable (at least vertically) so I can calculate my actual polar, but I don't want to waste time and money on this if the flight log isn't good enough. (And a few cockpit notes of course -- IAS at various times, etc). |
Prove the altitude variance to yourself, stand still and watch the
altitude change slowly up and down. It can really move around, maybe enough to make a GPS polar useless. 1 meter per second change while dead still is seen frequently on my GPS. Bob wrote: This question is motivated by the recent discussion about deriving polars from flight logs. We know that GPS fixes have some amount of (absolute) error. What is their accuracy relative to each other? In other words, when I'm analyzing flight logs, how accurately can I calculate something like sink rate using just the GPS fixes ("B" records)? I'm thinking about taking an early morning tow sometime this winter when the pressure is high and the air is stable (at least vertically) so I can calculate my actual polar, but I don't want to waste time and money on this if the flight log isn't good enough. (And a few cockpit notes of course -- IAS at various times, etc). |
Ah. I knew that. I'd have to use the pressure altitudes from the B
records. But these have to be adjusted .. the OAT must be recorded at the various altitudes and used to adjust the pressure altitudes to SL/standard atmosphere. Can anyone fill me in on how to do that? |
"But these have to be adjusted .. the OAT must be recorded at the
various altitudes and used to adjust the pressure altitudes to SL/standard atmosphere. Can anyone fill me in on how to do that?" Why? You're not concerned with absolute (True) altitude; just a delta between contiguous points. As long as you're flying through a sharp frontal boundary during your measurements, I can't see how this will matter. It's been a while since I actually did these manually, but Rho (density) cancels out in a ratio of Lift to Drag, no? L = 1/2RhoV2 CL S D = 1/2 Rho V2 CD S In any case, there are a number of places to get the gas law equations to convert to ISA. Google on ISA conversion formula or somesuch - I got several. P3 D= |
Should have writtent "NOT flying through a sharp frontal boundary..."
EGT Accuracy | O. Sami Saydjari | Owning | 6 | March 16th 04 10:53 PM |
Garmin 196 and Land Accuracy | Crispy3M | Products | 5 | March 14th 04 01:57 PM |
ILS instrument accuracy? Help...... | TripFarmer | Instrument Flight Rules | 19 | September 22nd 03 08:26 PM |
MS FS 2002 Pro - scenery accuracy and the VFR UK scenery | Gary | Simulators | 4 | July 15th 03 03:34 PM |
