ILS instrument accuracy? Help......
Old September 19th 03, 03:26 PM
TripFarmer
Default ILS instrument accuracy? Help......
I'm just starting to work on my Instrument Rating and yesterday when doing an
ILS approach I was keeping the localizer centered and my instructor told me to
look up about a mile out. We were maybe 200 yards off the centerline. Next
one we stayed on the centerline (visually) and the needle was 1/2 deflection.
Any thoughts about what to do? It seemed like a practice ILS I did at another
airport didn't do this a couple of weeks ago. Could it be this one facility
(BHM)? Do I need an avionics shop to look at it?
I'm new at this so I'm not really sure what step to take next. Any help will
be appreciated.
Trip
Old September 19th 03, 07:33 PM
C J Campbell
"TripFarmer" wrote in message
an
me to
Next
deflection.
another
facility
Could be your radios. Or if you have a GPS tied to your CDI you might have
inadvertently selected "GPS" instead of "NAV" and so the CDI needle was
actually indicating your position to some GPS course instead of the
localizer. I am seeing this error a *lot* in training.
Old September 19th 03, 07:51 PM
Ben Jackson
What ACUs will allow you to select GPS display when a LOC frequency is
tuned in on the NAV? I know UPSAT's won't actually select the GPS until
you tune a normal VOR on the associated NAV.
Ben Jackson
http://www.ben.com/
Old September 19th 03, 08:11 PM
Dave Butler
I've seen UPS installs where that's true, and where that's not true. Apparently
it depends on how it's installed.
Remove SHIRT to reply directly.
Dave
Old September 20th 03, 05:36 AM
C J Campbell
"Ben Jackson" wrote in message
news:PeIab.524381$uu5.87404@sccrnsc04...
| In article ,
have
The KLN-94 installation in all the new Cessnas has a NAV/GPS button which
must be pushed manually. The NAV/COM is a separate unit; you can tune in all
the localizers and VORs you want, but they will not be displayed on the CDI
unless you select NAV on the ACU.
Old September 20th 03, 10:34 AM
Peter Bondar
The 'preferred' option is to have a loc frequency automatically force the
NAV/GPS switch to go to nav mode.
Almost all wiring suggestions imply that as the deafult mode.
So you barrel along with your gps upto the IAF cros tracking your favourite
VOR then swap frequencies
on nav1 and bingo your automatically lined for a loc intercept.
Personally I find it it irrating and also if P2 happens to tune the ILS/DME
for cross references
purposes and the A/P is on then you can do a beautiful intercept of the ILS
for an airfield you just
happen to be passing!!
Peter
"Stan Gosnell" wrote in message
(Ben Jackson) wrote in
news:PeIab.524381$uu5.87404@sccrnsc04:
frequency is tuned in on the NAV? I know UPSAT's won't
actually select the GPS until you tune a normal VOR on the
associated NAV.
With the installations we have, the HSI has no idea what's
selected, or what frequency. There's a push/push button, which
cycles between VOR & GPS, and the HSI just gets voltage from
whichever is selected. There is no logic at all to prevent
using either one. The nav radios and the GPS are completely
independent, and have no relation to each other in any way.
Regards,
Stan
Old September 21st 03, 05:56 AM
Stan Gosnell
"Peter Bondar" wrote in
automatically force the NAV/GPS switch to go to nav mode.
Well, maybe preferred by some, but I may want to tune in the
localizer while I'm a long way out, getting ready for the
approach, but navigating on GPS until I'm inbound, or at least
on vectors. Forcing VOR mode just because a localizer is tuned
is simply a stupid way to do things.
Regards,
Stan
Old September 19th 03, 09:15 PM
Teacherjh
Perhaps the ILS transmitter is not on centerline? They can be offset, but I
don't know by how much.
The glide slope transmitter is often separate.
Jose
Instrument panel labelling options John Galban Home Built 12 November 18th 04 10:42 PM
Aluminum instrument panel finish? Richard Riley Home Built 31 February 4th 04 02:09 AM
Most Challenging Instrument Approaches in Western US? Angus Davis Instrument Flight Rules 24 September 28th 03 09:25 AM
Got my Instrument Rating! Jazzy_Pilot Instrument Flight Rules 4 August 21st 03 02:35 AM
Which of these approaches is loggable? Paul Tomblin Instrument Flight Rules 26 August 16th 03 05:22 PM
