I have a radio that needs a wiring harness, Becker AR3201 can anyone help. Thanks, Bob
On Wednesday, September 4, 2019 at 1:36:42 PM UTC-7, Bob Youngblood wrote:
I have a radio that needs a wiring harness, Becker AR3201 can anyone help. Thanks, Bob http://www.craggyaero.com/becker.htm Or call Richard www.craggyaero.com |
At 20:36 04 September 2019, Bob Youngblood wrote:
I have a radio that needs a wiring harness, Becker AR3201 can anyone help. Thanks, Bob Suggest you try the European site (uras). Must be lots of these kinking around after our recent 833 switch over. |
On Wednesday, September 4, 2019 at 5:15:06 PM UTC-4, Al McNamara wrote:
At 20:36 04 September 2019, Bob Youngblood wrote: I have a radio that needs a wiring harness, Becker AR3201 can anyone help. Thanks, Bob Suggest you try the European site (uras). Must be lots of these kinking around after our recent 833 switch over. Most kept their wiring harness. |
At 22:05 04 September 2019, Dan Daly wrote:
On Wednesday, September 4, 2019 at 5:15:06 PM UTC-4, Al McNamara wrote: At 20:36 04 September 2019, Bob Youngblood wrote: I have a radio that needs a wiring harness, Becker AR3201 can anyone help. Thanks, Bob Suggest you try the European site (uras). Must be lots of these kinking around after our recent 833 switch over. Most kept their wiring harness. Jup. Just changed the connector. |
On Thursday, September 5, 2019 at 3:00:07 AM UTC-4, Eric Munk wrote:
At 22:05 04 September 2019, Dan Daly wrote: On Wednesday, September 4, 2019 at 5:15:06 PM UTC-4, Al McNamara wrote: At 20:36 04 September 2019, Bob Youngblood wrote: I have a radio that needs a wiring harness, Becker AR3201 can anyone help. Thanks, Bob Suggest you try the European site (uras). Must be lots of these kinking around after our recent 833 switch over. Most kept their wiring harness. Jup. Just changed the connector. It is not too hard to make your own harness. Especially if the system is simple: power, mic, PPT and speaker, no intercom or second seat. You need to connect the other ends of the wires to those things in any case. If your glider already has those things and old wires, "just change the connector".. There was a thread here some months ago about where to get the connector to fit the AR4201, I don't know whether the AR3201 uses the same connector.. |
On Thursday, September 5, 2019 at 10:54:10 AM UTC-4, wrote:
On Thursday, September 5, 2019 at 3:00:07 AM UTC-4, Eric Munk wrote: At 22:05 04 September 2019, Dan Daly wrote: On Wednesday, September 4, 2019 at 5:15:06 PM UTC-4, Al McNamara wrote: At 20:36 04 September 2019, Bob Youngblood wrote: I have a radio that needs a wiring harness, Becker AR3201 can anyone help. Thanks, Bob Suggest you try the European site (uras). Must be lots of these kinking around after our recent 833 switch over. Most kept their wiring harness. Jup. Just changed the connector. It is not too hard to make your own harness. Especially if the system is simple: power, mic, PPT and speaker, no intercom or second seat. You need to connect the other ends of the wires to those things in any case. If your glider already has those things and old wires, "just change the connector". There was a thread here some months ago about where to get the connector to fit the AR4201, I don't know whether the AR3201 uses the same connector. 3201 is different from 4201. |
On Thursday, 5 September 2019 09:00:07 UTC+2, Eric Munk wrote:
Jup. Just changed the connector. I upgraded from an ancient, crystal based Dittel FSG 16 to the Becker AR3201 and was pleasantly surprised to find that the wiring in the aircraft for the FSG 16 was basically the same layout as the AR3201 wiring diagram. It looks like the wiring harnesses are fairly standardised with only the connector type and pin order being different. Here's a copy of the AR3201 manual containing the wiring diagrams. http://www.soargbsc.com/Becker3201.pdf |
At 09:24 06 September 2019, Surge wrote:
It looks like the wiring harnesses are fairly standardised with only the connector type and pin order being different. The devil is in the detail! The connector may actually be the same but which wire to which pin, whether wires are linked, and what is earthed may be critically different. At least one radio manufacturer offers adaptors boards to let you link your existing harness to his new generation 8.33 radios. |
simple enough to make using a db15 connector. You should check the manual for your particular serial number radio to be sure nothing has changed but for mine the pinouts are as follows:
+12v - pins 4, 5 Ground - pin 2 PTT switch - pin 12 PTT ground - pin 3 Audio Ground - pin 9 Audio signal - pin 15 Mic in - pin 11 Mic ground - pin 10 All ground lines (2, 3, 9, 10) are tied together internal to the radio. All +12v lines (4, 5) are also tied together internal to the radio. Robert On Wednesday, September 4, 2019 at 3:36:42 PM UTC-5, Bob Youngblood wrote: I have a radio that needs a wiring harness, Becker AR3201 can anyone help. Thanks, Bob |
looking for Hooker harness | Al MacDonald | Home Built | 0 | July 12th 08 03:54 PM |
engine monitor wiring harness install | Jim Burns | Owning | 8 | November 20th 06 02:26 PM |
S-H safety harness (V2C) | [email protected] | Soaring | 20 | April 28th 06 08:54 AM |
Harness | Nolaminar | Restoration | 2 | December 25th 03 03:04 PM |
Narco AT-50A Wiring Diagram Needed | Jerry | Aviation Marketplace | 0 | August 3rd 03 11:07 PM |
