Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Restoration
Harness
Old December 24th 03, 10:35 PM
Nolaminar
Default Harness
What is a British Sutton Harness?
Thanks
Bob Gaines
USA
Old December 25th 03, 11:12 AM
Dave Eadsforth
In article , Nolaminar
writes
Thanks
Bob Gaines
USA
Hi Bob,
It was a cockpit seat harness developed pre-war by a man called Sutton.
It consists of two lap straps and two shoulder straps that are made of
very robust canvas with strong brass eyelets every few inches. Fixing
it is done by passing a steel peg up through the eyelets of the straps,
once it has been placed in position over the wearer, and then trapping
the peg in position with a sprung steel pin after it has emerged from
the top hole.
It was in universal service during the war and for some years
afterwards, and is still to be found in old RAF aircraft such as the
Tiger Moth.
Plus points - very strong, gives excellent support for plus and minus G.
Some aircraft, such as the Spitfire, had a Sutton harness release lever
that payed out the shoulder straps on a wire and allowed the pilot to
lean forwards if need be, and which re-tightened when he leaned back
again.
Minus points - not easy to fit for all sizes of wearer - modern pull
tightening is superior. Very slim people will find it hard to get both
lap strap and shoulder straps to a satisfactory tightness - being a bit
pear-shaped is ideal...
But it did the job for decades, and still does.
Cheers,
Dave
Dave Eadsforth
Old December 25th 03, 04:04 PM
Nolaminar
Thanks for the Sutton Information.
Bob gaines
Of parachutes and things ShawnD2112 Aerobatics 34 July 21st 04 07:13 PM
FA: Slick Mags (used) 600 series with harness BFC Aviation Marketplace 0 June 24th 04 05:21 PM
One Wire Bad on a Slick Harness jls Home Built 2 June 21st 04 04:21 AM
Citabria aerobatic harness Ed Wild Aerobatics 0 February 1st 04 06:38 PM
Aircrew casualities ArtKramr Military Aviation 84 October 15th 03 10:50 PM
