Can I suspend an A-65 engine by the prop flange without causing undue
strain on the internals? - Mike |
("Michael Horowitz" wrote)
Can I suspend an A-65 engine by the prop flange without causing undue strain on the internals? - Mike What kind of stand did you end up with? Montblack |
"Montblack" wrote:
("Michael Horowitz" wrote) Can I suspend an A-65 engine by the prop flange without causing undue strain on the internals? - Mike What kind of stand did you end up with? Montblack Still up in the air - my A&P got ill so I wasn't able to visit my engine. Based on the post just above this one, which implied "of course", I'll probably bolt the flange to a 2x8 and suspend the engine flange up between two saw horses. All I'm doing is bolting on the exhaust, carb. and some other stuff prior to lifting it onto the engine mount. - Mike |
Michael Horowitz wrote:
Can I suspend an A-65 engine by the prop flange without causing undue strain on the internals? - Mike You better be able to. You get about 3.5 to 4lb of thust from each horse at the prop flange. A 100Hp engine should give you somewhere in the ballpark of 400lbs. The engine has to withstand that 400lbs of thrust trying to pull the prop flange off. If that engine weighs 400lbs and only gives you 100Hp, you'd do better to leave it on the ground and just flap your arms real hard 8*) |
Can I suspend an A-65 engine by the prop flange without causing undue strain on the internals? - Mike A conventional engine stand for an a/c engine is configured so that the engine sits *on* the flange ('nose down'). You start building with just the crank standing upright on the flange & add parts. A plywood disk the same diameter as the widest dimension of the engine drilled with a bolt circle matching the prop flange, a handful of bolts & fender washers & you have a stable stand leaving easy access to all the engine. Obviously you need to shim the bottom of the disk to allow for the bolt head thickness. Hope the word picture is adequate. |
Charlie wrote:
Michael Horowitz wrote: Can I suspend an A-65 engine by the prop flange without causing undue strain on the internals? - Mike A conventional engine stand for an a/c engine is configured so that the engine sits *on* the flange ('nose down'). You start building with just the crank standing upright on the flange & add parts. A plywood disk the same diameter as the widest dimension of the engine drilled with a bolt circle matching the prop flange, a handful of bolts & fender washers & you have a stable stand leaving easy access to all the engine. Obviously you need to shim the bottom of the disk to allow for the bolt head thickness. Hope the word picture is adequate. Short and simple. Thanks - Mike |
![]() "Charlie" wrote in message .. . Michael Horowitz wrote: Can I suspend an A-65 engine by the prop flange without causing undue strain on the internals? - Mike A conventional engine stand for an a/c engine is configured so that the engine sits *on* the flange ('nose down'). You start building with just the crank standing upright on the flange & add parts. A plywood disk the same diameter as the widest dimension of the engine drilled with a bolt circle matching the prop flange, a handful of bolts & fender washers & you have a stable stand leaving easy access to all the engine. Obviously you need to shim the bottom of the disk to allow for the bolt head thickness. Hope the word picture is adequate. I made an engine stand from a Black and Decker folding work table. I drilled the flange hole pattern in tooling plywood for the top. The table, whose structure is rated for about 500 lbs., has been used for 200-lb. C-85's, C-90's, and O-200's. I have seen A-65's hung from the crankshaft end with a hook attachment screwed onto a tapershaft. Hanging from a flanged crankshaft would probably be OK as long as you spread the load over the entire flange. But who would want to? I wouldn't want to be working on an engine swinging on a chain. |
Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 10:18 PM |
Ivo Prop on O-320 | Dave S | Home Built | 14 | October 15th 04 03:04 AM |
Prop Pitch Question | Eugene Wendland | Home Built | 2 | April 25th 04 03:22 AM |
IVO props... comments.. | Dave S | Home Built | 16 | December 6th 03 11:43 PM |
Metal Prop vs. Wood Prop | Larry Smith | Home Built | 21 | September 26th 03 07:45 PM |
