ventus tailwheel
Old January 4th 20, 10:32 PM posted to rec.aviation.soaring
Default ventus tailwheel
Does anyone know a US source for the solid-tire tailwheel of a 2003 Ventus 2cxm (steerable)? Its marked Downey California, but the maker's name is worn away.
Old January 4th 20, 10:36 PM posted to rec.aviation.soaring
Dan Marotta
Measure the inner and outer diameter.Â* You may be able to find one at a
wheel chair supply store.Â* I put one on the tail dolly of my Stemme and
it works fine, though it doesn't go as fast as a glider tail wheel.Â*
Still, at the price, it may be worth a look.
Dan, 5J
Old January 5th 20, 04:53 PM posted to rec.aviation.soaring
John McLaughlin
This is serendipitous - I was just about to start a new thread to ask
pretty
much the same question: is it reasonable and acceptable to the
manufacturer, the regulator and insurers if I replace the pneumatic
tailwheel of my Ventus with a solid one?
My initial thought is that the loss of protection from impacts would be bad
for the structure, but then a solid tire can't be much worse than a solid
skid, can it? The only difference I can see is that the skid might spread
load, rather than transferring it through the axle mountings?
Tailwheel soartech[_2_] Soaring 28 December 14th 12 12:41 AM
Tailwheel ID R. Mueller Aviation Marketplace 2 February 5th 08 11:25 PM
tailwheel [email protected] Soaring 6 December 16th 06 01:46 PM
wanted scott 3200 tailwheel /alaskan bushwheel tailwheel phillip9 Aviation Marketplace 0 June 6th 06 08:57 PM
First Tailwheel!! W P Dixon Piloting 9 May 9th 05 10:07 PM
