Tailwheel
Old December 12th 12, 06:05 PM posted to rec.aviation.soaring
soartech[_2_]
Default Tailwheel
While discussing tailwheel weight I wondered why we need a tail dolly?
Why do most modern sailplanes have fixed tailwheels yet SGS gliders
have castering tailwheels. Shouldn't we have a caster instead?
Old December 12th 12, 06:09 PM posted to rec.aviation.soaring
Mike the Strike
Default Tailwheel
Good luck on cross-wind take-offs!
Old December 12th 12, 08:32 PM posted to rec.aviation.soaring
soartech[_2_]
Default Tailwheel
Wouldn't it be OK, you just would have to use the rudder more?
Actually I like the automatic locking mechanism idea best so far.
Most of the reported weight and balance numbers showed a 20 lbs or
more
difference with the pilot in place.
Old December 12th 12, 06:13 PM posted to rec.aviation.soaring
Grider Pirate[_2_]
Default Tailwheel
Schweizers are 'nose draggers'. The CG is ahead of the main, so they
tend to follow the rope on the runway. A CG hook tail dragger with a
castering tailwheel would be .... very exciting on the ground, but not
in a good way.
Old December 12th 12, 06:24 PM posted to rec.aviation.soaring
Bill D
Default Tailwheel
Your basic question is valid. Back in the round engine days, some big taildraggers had lockable tail wheels which castered for taxiing and locked straight-ahead for takeoff.
One imagines a variation of this could work with gliders. If the cockpit is empty, weight on the tailwheel would make it caster. With a pilot in the cockpit, the lighter weight on the tailwheel locks it straight ahead. The castering shaft would just have a axial spring pushing the tail wheel down 5mm or so to lock it straight ahead. Basically it would be automatic with no input from the pilot.
Old December 12th 12, 06:43 PM posted to rec.aviation.soaring
Dave Nadler
Default Tailwheel
And the first bump it unlocks ?
Complicated and not smart.
Old December 12th 12, 08:08 PM posted to rec.aviation.soaring
Bill D
Default Tailwheel
Geez, more negative experts!
A large enough bump might unlock it for a few milliseconds, but it would re-lock instantly. Note that Blanik's are taildraggers and many have permanently castering tail wheels so it can't be a big deal.
It still worries you, a simple latching down-lock which requires manual unlocking for castering is dead simple but almost certainly unnecessary.
Note that it comes with a major safety advantage - taking off with a tail dolly on becomes impossible.
Old December 12th 12, 09:22 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default Tailwheel
from the pilot.
deal.
Blaniks have a huge rudder that becomes effective even before the wing
runner lets go. Not so for high performance gliders.
Another likely reason: the tailwheel is large but carefully faired in.
Enabling it to swivel would involve tradeoffs in cost, weight, and drag.
And possibly: people tow the gliders around with vehicles attached to
the tail dolly. Attaching a tow bar to just the might be a problem.
But I agree it would be nice; personally, I'd rather have a steerable
tail wheel. No more directional control problems at low speeds. I love
the one on my ASH 26 E even when I take a tow, and, of course, every
time I land.
email me)
Old December 12th 12, 09:59 PM posted to rec.aviation.soaring
Roger Fowler[_3_]
Default Tailwheel
from the pilot.
deal.
time I land.
email me)
Question: How much download can you apply when pulling the stick full back
right after touchdown?
Experience: I forgot to lock the tailwheel on a Stearman once before I
took off. Boy was that exciting!
FR
Old December 12th 12, 11:57 PM posted to rec.aviation.soaring
Tony V
Default Tailwheel
time I land.
The Antares has a steerable tail wheel. I suspect that Dave N would love
to sell you one. :-)
Tony "6N"
Tailwheel ID R. Mueller Aviation Marketplace 2 February 5th 08 10:25 PM
tailwheel [email protected] Soaring 6 December 16th 06 12:46 PM
What's in a tailwheel???? DonMorrisey Home Built 10 October 15th 06 10:17 PM
wanted scott 3200 tailwheel /alaskan bushwheel tailwheel phillip9 Aviation Marketplace 0 June 6th 06 07:57 PM
First Tailwheel!! W P Dixon Piloting 9 May 9th 05 09:07 PM
