Instrument panel labeling
Old January 10th 20, 02:26 AM posted to rec.aviation.soaring
Default Instrument panel labeling
I'm looking for ideas on how to make professional looking placards/labels for a instrument panel rebuild I'm doing. I need to make tiny labels for fuses, and switches and I hate, hate, hate the look of the continuous strip label maker "sticker" stuck to the panel. It looks tacky, but they never seem to stay stuck. Know what I mean?
I think a stencil might be too small, has any one ever used a pressure transfer and clear top coat? What else have you tried?
Signed,
Working till spring
Old January 10th 20, 03:44 AM posted to rec.aviation.soaring
Not sure what type of "continuous strip label maker sticker" you had so badly - is it the old Dymo style that produces a sort of raised letter on a thick plastic strip? Agree that those look terrible.
I used P-Touch laminated tapes on my panel and they look very professional and haven't had any problems over the last 3 years in the south Texas summer heat. I used their Extra-Strength cartridge (https://www.amazon.com/gp/product/B004ZMVNLO/) and since my panel is black I used clear tape with white lettering. With the P-Touch you can print any sized label, many fonts, etc. I labeled fuses, switches, N-number and all look absolutely professional. Highly recommended.
Robert
Signed,
Working till spring
Old January 10th 20, 04:39 AM posted to rec.aviation.soaring
Tom BravoMike
For a really professionally looking labels I would suggest a 'sign and engraving' business like this found at random on Google:
https://www.myengravedsign.com/Engra...el-Plates.aspx
Old January 10th 20, 05:34 AM posted to rec.aviation.soaring
John DeRosa OHM Ω http://aviation.derosaweb.net
Signed,
Working till spring
I have used Aircraft Engravers many times (https://www.engravers.net/). Not too expensive, quick, and well made.
Here are some examples for a Cessna 150 with an nearly unreadable panel I upgraded (PDF of what I sent them, what they sent me as a proof, and what they produced).
http://derosaweb.net/aviation/images/placards
Old January 10th 20, 05:45 AM posted to rec.aviation.soaring
On Thursday, January 9, 2020 at 11:35:01 PM UTC-6, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
Signed,
Working till spring
Also, if you do decide to use the "Thermal transfer printing" label makers commonly found in office supply stores, definitely use the Dymo brand. Dymo has stepped up their game from the olden days of raised lettering, their adhesive is better than P-Touch's, and they even make printable HEAT SHRINK!! Same price point as P-Touch.
https://www.dymo.com/en-US/label-mak...60-label-maker
Also, a hint on getting these labels to stick better - clip each corner of the label at a 45. Its those 90 degree corners that seem to lift up over time. My $0.02.
Old January 10th 20, 08:27 AM posted to rec.aviation.soaring
krasw
I have printed labels with a good laser printer using Avery industrial strength A4 printable label sheets. Normal office labels do not last more than year or two. Label does not stick to Nextel paint very well, they need to be attached with two sided tesa tape used for mylar seals. Done like this, they outlast the glider.
Old January 10th 20, 01:36 PM posted to rec.aviation.soaring
Tango Whisky
Le vendredi 10 janvier 2020 09:27:23 UTC+1, krasw a écritÂ*:
I print them with a laser printer on standard paper, and the plastify the paper (the thing where you put the paper between to layers of clear plastic through a heating machine). Double sided tape to attach - looks professional and lasts forever.
Old January 13th 20, 08:01 PM posted to rec.aviation.soaring
Signed,
Working till spring
I second Aircraft Engravers. Did a great job on the labels for my Libelle. Been on my panel almost 5 years and not one problem with any of them coming off. Email me off list if you want to see my order page.
Doug
Old January 10th 20, 03:49 PM posted to rec.aviation.soaring
Cookie
On Thursday, January 9, 2020 at 9:26:27 PM UTC-5, wrote:
https://decalprofx.com/aircraft-panels.html
Check out the website above. Many photos of instrument panels done with this method. It transfers only the letters....no backing, no clear tape nothing...just letters
I worked on the restoration of a military Cessna 337...and did all the instrument panels, electrical panels, control labels, special labeling etc. Really looks nice....somewhat complicated and labor intensive....but 100% professional results.
Cookie
Signed,
Working till spring
Old January 10th 20, 03:52 PM posted to rec.aviation.soaring
Cookie
https://decalprofx.com/aircraft-pane...rd-funk-1.html
example of glider panel with this process
ASW 19 instrument panel Charles Longley Soaring 14 November 1st 17 07:47 AM
P-39 Instrument-Panel - P-39 Instrument-Panel.jpg ... Miloch Aviation Photos 0 June 26th 16 01:47 AM
PIK-20D Instrument panel Solo Soaring 5 February 15th 09 06:50 PM
Instrument Panel ccwillwerth Home Built 7 February 9th 06 02:15 PM
DG-300 instrument panel [email protected] Soaring 14 January 29th 06 02:48 PM
