more at https://www.cnn.com/2019/06/26/polit...law/index.html
(CNN) — A new flaw has been discovered in the computer system for the Boeing 737 Max that could push the plane downward, according to two sources familiar with the testing, an issue that is expected to further delay the aircraft's return to service. A series of simulator flights to test new software developed by Boeing revealed the flaw, according to one of the sources. The latest versions of Boeing's popular jet were grounded in March after two crashes -- Lion Air flight 610 and Ethiopian Airlines flight 302 -- that killed 346 people. While the crashes remain under investigation, preliminary reports showed that a new stabilization system pushed both planes into steep nosedives from which the pilots could not recover. The issue is known in aviation vernacular as runaway stabilizer trim. Boeing announced it could break the chain of events that led to both crashes by developing a software fix that would limit the potency of that stabilization system. In simulator tests, government pilots discovered that a microprocessor failure could push the nose of the plane toward the ground. It is not known whether the microprocessor played a role in either crash. When testing the potential failure of the microprocessor in the simulators, "it was difficult for the test pilots to recover in a matter of seconds," one of the sources said. "And if you can't recover in a matter of seconds, that's an unreasonable risk." Boeing engineers are now trying to address the issue, which has led to another delay in recertifying the 737 Max. "The safety of our airplanes is Boeing's highest priority. We are working closely with the FAA to safely return the MAX to service," Boeing said in a statement. The sources say Boeing engineers are trying to determine if the microprocessor issue can be fixed by reprogramming software or if replacing the physical microprocessors on each 737 Max aircraft may be required. An FAA spokesperson would not confirm the specific issue, but told CNN that "the FAA's process is designed to discover and highlight potential risks. The FAA recently found a potential risk that Boeing is required to mitigate." more at https://www.cnn.com/2019/06/26/polit...law/index.html * |
Lancair Legacy Design Flaw? | Gregory Hall | Home Built | 80 | November 13th 08 02:43 AM |
Shaw Flaw | The Old Guy | Aviation Photos | 0 | September 16th 08 05:18 AM |
MANUFACTURING FLAW FOUND IN STOVL JOINT STRIKE FIGHTER LIFT FAN ROTOR | Mike[_7_] | Naval Aviation | 0 | January 4th 08 09:42 PM |
Another Zoom Lie Discovered | anon | Home Built | 47 | February 22nd 07 04:23 AM |
AI Acft- A Gem Discovered | mike popken | Simulators | 4 | January 11th 04 05:06 AM |
