Lancair Legacy Design Flaw?
Old October 28th 08, 07:41 PM posted to rec.aviation.homebuilt
Gregory Hall
Default Lancair Legacy Design Flaw?
http://www.youngeagles.org/photos/gallery/Monoplanes/LancairLegacy2000.jpg
Look at the picture. It's easy to see why the Lancair is dangerous. The
horizontal stabilizers appear to be on the too small side. This would result
in their stalling before the wing. Then the aircraft would pitch up making
the main wing stall. Ill-conceived, IMO.
A good lawyer needs to get on this with respect to BadWaterBill's untimely
demise.
Gregory Hall
Old October 28th 08, 08:30 PM posted to rec.aviation.homebuilt
Vaughn Simon
"Gregory Hall" wrote in message
demise.
With all due respect, that is a terrible idea. I think we already have too
many lawyers involved in GA's affairs. The Lancair is a homebuilt, experimental
aircraft; "You pays your money and you takes your chances" AKA, caveat emptor .
Vaughn
Old October 28th 08, 08:31 PM posted to rec.aviation.homebuilt
Stuart Fields
result in their stalling before the wing. Then the aircraft would pitch up
making the main wing stall. Ill-conceived, IMO.
demise.
Gregory Hall
Are you proposing a Lawyer for horizontal stabilizer design review? My
guess is that if you have been able to do a review of the horizontal stab
from a photo, that BwB would have a good idea of just what he was flying and
as the PIC was responsible for the safe operation of the bird. What a
Lawyer could add to this tragedy without creating a second tragedy is not
clear.
Old October 28th 08, 09:12 PM posted to rec.aviation.homebuilt
Gregory Hall
"Bryan Martin" wrote in message
That could only happen if the plane was loaded with the CG way aft of
the limit. Otherwise, the plane would pitch DOWN if the stabilizer
stalled because the stabilizer normally produces a down force to keep
the nose up.
If it worked that way it would be a built-in safety factor helping to
forestall a stall of the main wing. But suppose the motor died and the
aircraft was then a glider. One must glide nose down. The horizontal
stabilizer forcing the nose down would then cause the pilot to pull back on
the stick to counteract the forces for aft. If the stabilizer stalled in
this attitude the nose is supposed to pitch down but would it? The tail
might just continue to drop provided the main wing still gets traction??? CG
is dependent upon both lifting both control surfaces as well as weight
distribution.
Gregory Hall
result
making
untimely
demise.
Gregory Hall
Bryan Martin
N61BM, CH 601 XL, Ram Subaru, Stratus redrive.
Old October 28th 08, 09:46 PM posted to rec.aviation.homebuilt
Alan Baker
the nose up.
distribution.
Sorry. But centre of *mass* (to use the correct term) is not in any way
dependent on the lift from anything.
The centre of mass is a parameter than is completely fixed by the
distribution of the mass of the aircraft's components. Whether any
surface is providing lift will not change it.
So as long as the main wing is located aft of the centre of mass, the
aircraft will pitch *down* when lift from the tail plane is lost.
Period.
Gregory Hall
http://www.youngeagles.org/photos/ga...Legacy2000.jpg
result
making
untimely
demise.
Gregory Hall
Bryan Martin
Alan Baker
Vancouver, British Columbia
http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg
Old October 28th 08, 10:00 PM posted to rec.aviation.homebuilt
Rip[_3_]
distribution.
Gregory Hall
You seem to have the forces on the horizontal stabilizer backwards. The
force on the horizontal is down, (NOT up as with the main wing) which is
why an aircraft is stable in pitch unless improper loading places the CG
too far aft.
Of course, non of this applies to canard designs, which the Lancair is not.
Rip
Old October 28th 08, 10:49 PM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
demise.
Gregory Hall
Bill would cuss you out for saying that.
And?
What is the area ratio of stab/wing?
Did you notice that the wing is tiny too?
Richard
(remove the X to email)
Old October 28th 08, 11:14 PM posted to rec.aviation.homebuilt
Peter Dohm
"cavelamb himself" wrote in message
m...
up making the main wing stall. Ill-conceived, IMO.
untimely demise.
Gregory Hall
And?
Richard
He seems to have missed a great deal, in just a few words.
Peter
Old October 28th 08, 11:49 PM posted to rec.aviation.homebuilt
Gezellig
Greg, no design theorist here but just because the hor stab "appears to
small" isn't much of an argument. The front wing of a canard compared to
the main wings is very small but the combo works in a pusher config. it
wouldn't appear to but it does.
Not knowing the camber and other details including the airflow to the
stabs makes the stalling prior argument unsubstantiated invho.
Old October 28th 08, 11:53 PM posted to rec.aviation.homebuilt
Gezellig
On Tue, 28 Oct 2008 17:12:50 -0400, Gregory Hall wrote:
CG
distribution.
Thankfully that isn't the case otherwise you would have horrendous times
with energy management, for instance, with an ever evolving mass.
Shaw Flaw The Old Guy Aviation Photos 0 September 16th 08 05:18 AM
Lancair Legacy Joaquin Home Built 22 November 13th 06 09:06 AM
BWB has finished his Lancair Legacy... John Ammeter Home Built 1 June 6th 06 04:11 AM
Lancair Legacy 2000 Randy L. Simulators 6 October 9th 03 09:56 PM
