Nav Antenna Placement
Old September 18th 04, 05:30 PM
Jim Pensinger
Default Nav Antenna Placement
I am building a metal experimental aircraft that has an all moving
rudder/vertical stabilizer (Zenith Zodiac 601XL). Does the moving
stabilizer present any problems to the VOR antenna? It seems to me that the
bottom of the fuselage under the cockpit would be a better mounting place
but I have never seen this used. Is there a reason?
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 100,000 Newsgroups - 19 Different Servers! =-----
Old September 19th 04, 02:20 AM
Bruce Bockius
"Jim Pensinger" wrote in message ...
On my 601HD I mounted my VOR antenna on the bottom of the rear
fuselage just forward of the tailwheel (about 1' from the end if you
have a trike). Seems to work although I use the GPS 99.9% of the time
anyways...
http://home.earthlink.net/~fellrider/nav_ant.jpg
http://www.whiteantelopesoftware.com/zodiac
-Bruce Bockius
Old September 19th 04, 01:38 PM
JFLEISC
anyways...
Exactly the same here. It gets the same or better reception than any other
plane I have flown. The added benefit is (since the top of the tail isn't as
high as my wife's Cessna) you won't take your eye out during a preflight.
Old October 2nd 04, 12:08 AM
Morgans
"Brian Cox" wrote
combination VOR/Comm, "Flying Lady".
Brian
N3827X
Huh?
Jim in NC
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.770 / Virus Database: 517 - Release Date: 9/28/2004
Old October 4th 04, 04:22 PM
Brian Cox
"Morgans" wrote in message ...
Brian
N3827X
Huh?
It is an antenna with separate connectors for the VHF comm and the VOR
antenna. It mounts on top of the fuselage, usually over the
pilot/co-pilot location. The antenna looks like a forward swept VHF
blade. At the top is a backward swept V shaped dipole. The blade is
the comm antenna, the dipole is the VOR antenna. I may be wrong, but
I assume that they were originally designed for the V-tail Bonanza
because it did not have a vertical stabilizer to mount the VOR.
Thanks,
Brian
Retractable Comm Antenna Ron Wanttaja Home Built 11 September 6th 04 06:59 PM
Another antenna question David Wilson Home Built 7 August 12th 04 10:04 PM
Antenna ground plane and coax grounding G. Fred McCutchen Home Built 2 August 8th 04 12:27 PM
ELT antenna -- Pitts Al MacDonald Home Built 0 July 15th 04 03:27 PM
comm's RX antenna acepilot Home Built 5 March 3rd 04 05:34 PM
