comm's RX antenna
Old March 3rd 04, 01:08 PM
acepilot
Default comm's RX antenna
I assume you are putting an antenna on the OUTSIDE of the van. If this
is the case, there is no such thing as too big a groundplane. If you
are putting the antenna inside, then it is probably more easily
understood that all that metal will be a shield to RF. I would
recommend getting a 1/4 wavelength VHF antenna used for either amateur
radio (144 MHz band) or a commercial highband antenna (150-174 MHz).
You can get ones that require a 3/4" hole in the roof or go with a
magnet mount type. Both antennas mentioned above will be a little short
for airband, but will work infinitely better than an inside antenna of
any kind.
Scott "Ham radio guy" L.
karel adams wrote:
I want an airband receiver in my car (well, a van actually)
and wonder what antenna to use best.
just the normal car antenna perhaps?
i even wondered about jim weir's J-antenna
but am afraid the van's body will be too big a grond plane
TIA,
Karel Adams
Wanted: Transponder antenna Grandpa B. Home Built 22 November 28th 03 09:03 AM
Marker Beacon Antenna - Paging Jim Weir. Bart D. Hull Home Built 1 November 27th 03 11:31 PM
Nav antenna diplexers Paul Lee Home Built 6 October 30th 03 06:52 AM
Foil antenna and carbon fiber BD5ER Home Built 11 August 6th 03 05:44 AM
Antenna Ground Plane Grounding Fastglasair Home Built 1 July 8th 03 06:21 PM
