Amongst all the weighty deliberations on improving safety,
maybe someone experienced and knowlegable about diaphrgam carburetors could give me guidance. I fly a PIK 20E , Rotax 501 unreliable engine which has been behaving erratically, surging but not misfiring that I can detect. From the plugs I see rear cyl lean, front cyl a bit rich. Does a split carb diaphragm enrich or lean the mixture? thanks John F |
On Friday, May 15, 2020 at 8:34:29 AM UTC-7, john firth wrote:
Amongst all the weighty deliberations on improving safety, maybe someone experienced and knowlegable about diaphrgam carburetors could give me guidance. I fly a PIK 20E , Rotax 501 unreliable engine which has been behaving erratically, surging but not misfiring that I can detect. From the plugs I see rear cyl lean, front cyl a bit rich. Does a split carb diaphragm enrich or lean the mixture? thanks John F I am surprised that it runs at all - the diaphragm is critical for regulating fuel flow thru the carb: https://www.youtube.com/watch?v=jWBre4-tHsg You need to overhaul the carb which includes replacing the diaphragm. Tom |
Before you get too excited about pulling that carb apart check the rubber mount between it and the engine. I’ve heard of them cracking out.
On Friday, May 15, 2020 at 11:34:29 AM UTC-4, john firth wrote:
Amongst all the weighty deliberations on improving safety, maybe someone experienced and knowlegable about diaphrgam carburetors could give me guidance. I fly a PIK 20E , Rotax 501 unreliable engine which has been behaving erratically, surging but not misfiring that I can detect. From the plugs I see rear cyl lean, front cyl a bit rich. Does a split carb diaphragm enrich or lean the mixture? thanks John F An air leak was found at the shutoff valve , and fixed. The carbs were pulled and the diaphragms examined; one is a bit stretched but no holes found. Search for Tillotoson HC spares unsuccessfull. Rebuilt everything with diaphragms swapped. Engine now runs smoothly slightly lacking full power. Rear cyl still hot as shown by EGT. JMF |
The carbs were pulled and the diaphragms examined; one is a bit stretched but no holes found. Search for Tillotoson HC spares unsuccessfull. Rebuilt everything with diaphragms swapped. Engine now runs smoothly slightly lacking full power. Rear cyl still hot as shown by EGT. JMF[/quote] Hi John I had a Pik30E in an earlier life and the rear cylinder always ran hotter due I expect to reduced cooling airflow as it is partially shielded by the front cylinder. Regards Brett |
| Thread Tools | |
| Display Modes | |
| Have you ever experienced carb ice with an injector carb? | flybynightkarmarepair | Home Built | 1 | January 31st 05 02:48 AM |
| WANTED ROTAX 912 CARB SYNCHRONIZATION KIT | kksksk | Products | 0 | November 15th 04 10:45 PM |
| WANTED ROTAX 912 CARB SYNCHRONIZATION KIT | kksksk | Home Built | 0 | November 15th 04 10:43 PM |
| Carb temp guage vs. Iceman carb ice detector | Mike Rapoport | Piloting | 1 | September 28th 04 04:13 AM |
| carb ice | john smith | Owning | 5 | September 6th 04 01:41 PM |
