Will using the jpi gauge on my Warrior correctly prvent the formation of
carbutetor ice? |
Tony Woolner wrote:
Will using the jpi gauge on my Warrior correctly prvent the formation of carbutetor ice? No, carburetor heat will prevent the formation of carburetor ice. I wasn't aware JPI made a carburetor inlet temperature gauge. |
leaning the mixture as well as carb heat should melt carbice?
john smith wrote: Tony Woolner wrote: Will using the jpi gauge on my Warrior correctly prvent the formation of carbutetor ice? No, carburetor heat will prevent the formation of carburetor ice. I wasn't aware JPI made a carburetor inlet temperature gauge. |
On Sun, 05 Sep 2004 18:29:08 -0400, Tony Woolner
wrote: Will using the jpi gauge on my Warrior correctly prvent the formation of carbutetor ice? I don't think any gauge will prevent carb ice but I have a Lamar Iceman instrument that is supposed to detect it by way of a probe in the carb. Light passes across a gap and if the light transmission is occluded, it signals that there's ice in the carb. Or the literature says it does. I had it installed and to this day I don't know if it works. The company didn't offer help to my installation shop about how to wire the audio into my panel. So it sits there, never used. But it wouldn't prevent icing even if it worked. |
We had an "Iceman" in the (O-360) Mooney for a couple of years. The
instrument worked very well and detected the ice right when it was starting to form. For education, we tried letting the ice build up but at cruise power settings, the Lyco O-360 seems pretty resistant. We removed the indicator and sold it to a Skylane owner for reasons unrelated to its performance. If I had a Skylane, it would be more important to me I don't think any gauge will prevent carb ice but I have a Lamar Iceman instrument that is supposed to detect it by way of a probe in the carb. Light passes across a gap and if the light transmission is occluded, it signals that there's ice in the carb. Or the literature says it does. I had it installed and to this day I don't know if it works. |
| Thread Tools | |
| Display Modes | |
| Have you ever experienced carb ice with an injector carb? | flybynightkarmarepair | Home Built | 1 | January 31st 05 02:48 AM |
| WANTED ROTAX 912 CARB SYNCHRONIZATION KIT | kksksk | Home Built | 0 | November 15th 04 10:43 PM |
| alternate carb heat | Ray Toews | Home Built | 16 | October 29th 04 01:41 PM |
| Carb heat shroud | Gene Seibel | Owning | 3 | January 27th 04 05:13 AM |
| Carb Temperature Gauge | fly_the_skies | Home Built | 6 | January 14th 04 04:32 PM |
