I was looking through the aircraft Maintenance manual and the solo 2350 engine manual, both have the same procedure for long term storage (over 2 months). Neither has the "un-pickle" procedure. Was looking for guidance from those knowledgable.
Thank you in advance, Jon |
On Fri, 22 May 2020 18:32:39 -0700 (PDT), "Jonathan St. Cloud"
wrote: I was looking through the aircraft Maintenance manual and the solo 2350 engine manual, both have the same procedure for long term storage (over 2 months). Neither has the "un-pickle" procedure. Was looking for guidance from those knowledgable. Thank you in advance, Jon I can tell you what I do. 20 years flying a Ventus cT turbo with the 2350 engine. Flying in N Texas, I remove the engine every fall and reinstall every spring (6 months in - 6 months out). 1. I remove and clean the decompression valves. 2. I remove and clean the spark plugs. 3. I replace the lower portion of the fuel line that runs from the impulse fuel pump up to the line tee. It always hardens over the 6 months of summer operation. 4. Following re-installation, I lube the prop. No issues in 20 years of this process. I used to put in new plugs every year and drain and use new gas (100LL), but don't bother now. 1-2 hours to remove, 3-4 hours to reinstall. Engine only, lift mechanism left in place. Bob |
I'm flying a Ventus cM for the 15th season. In fall, I do the maintenance as per the manual, put 5 ml oil in each carburettor, turn the prop a couple of times, seal the carburettors with plastic bags and tape off the exhaust outlet.
In spring, I take off the plastic bags and the tape and fire up the engine. |
| Boost performance of Solo 2350 turbo (sustainer) | [email protected] | Soaring | 10 | January 4th 19 01:37 PM |
| WTB solo 2350 engine | [email protected] | Soaring | 1 | May 27th 15 11:56 PM |
| Oil for Solo 2350 | MNLou | Soaring | 3 | May 26th 15 09:27 AM |
| solo 2350 engines | Rocket | Soaring | 3 | January 24th 07 04:58 PM |
| Help with Solo 2350 | Limus | Soaring | 2 | May 3rd 06 03:15 AM |
