Oil for Solo 2350
Old May 25th 15, 08:16 PM posted to rec.aviation.soaring
MNLou
Default Oil for Solo 2350
To all you Solo 2350 owners -
What make/brand 2 cycle oil do you mix with your 100LL gas?
Thanks in advance -
Lou
Old May 26th 15, 02:44 AM posted to rec.aviation.soaring
Thanks in advance -
Lou
Yamalube 2R. Easily bought in motorcycle/snowmobile shops. It suspends indefinitely in 100LL. I can no longer remember the post link, but do vividly recall the photograph of results after 2 years on the shelf. Several motor oils were mixed with fuel in clear glass jars. The yamalube 2R remained suspended while the others did not. I've been using it for the past seven+ years in my self launching Ventus with a solo engine. Never a problem. I never worry about using a mixture of this oil and 100LL even if it has been in storage for quite a while. I wouldn't use anything else.
Old May 26th 15, 04:33 AM posted to rec.aviation.soaring
Bob Gibbons[_2_]
On Mon, 25 May 2015 12:16:43 -0700 (PDT), MNLou
Thanks in advance -
Lou
This is what I have used for the past 15 years in my Ventus cT, 4oz
per gal.
PENNZOIL® 2-CYCLE AIR-COOLED ENGINE OIL
http://oilstore.stores.yahoo.net/pe2cyforairc.html
Fuel is standard 100LL avgas.
I also add 2 oz per gal of SeaFoam Motor Treatment (injector cleaner).
Check Amazon or any auto parts store. Not sure it does any good, but
I've also used this for so many years I don't see any reason to quit.
Bob
Old May 26th 15, 08:27 AM posted to rec.aviation.soaring
Thanks in advance -
Lou
Castrol Act-Evo, which is recommended by Solo for the 2350.
http://www.castrol.com/en_gb/united-...l/act-evo.html
Boost performance of Solo 2350 turbo (sustainer) [email protected] Soaring 10 January 4th 19 12:37 PM
solo 2350 engines Rocket Soaring 3 January 24th 07 03:58 PM
Help with Solo 2350 Limus Soaring 2 May 3rd 06 02:15 AM
L33 Solo Jeff Runciman Soaring 1 November 14th 05 08:57 AM
Solo 2350 Engine Overhaul Manual - Translation Requested Bob Gibbons Soaring 2 January 10th 04 08:45 AM
