How reliably do CG hooks disconnect when the angle of the ropeexceeds the autorelease angle
Old June 4th 20, 10:33 PM posted to rec.aviation.soaring
Kenz Dale
Default How reliably do CG hooks disconnect when the angle of the ropeexceeds the autorelease angle
I understand that CG hooks are designed to autorelease when the angle of pull passes a certain critical angle. Is this a very reliable disconnect, or is more of an "Eh, it's nice to have but I've seen it fail too many times to trust it"?
Old June 4th 20, 11:25 PM posted to rec.aviation.soaring
Tom BravoMike
From the PW-5 Flight manual:
"RELEASING
The sailplane is equipped with the self-releasing hook.
Two releasing techniques exist:
1) before the intended releasing release the stick to lower the cable
tension then pull the releasing handle in the cockpit;
2) before the intended releasing hold the stick in position till the selfreleasing occurs. After releasing recover immediately the glide and
check the cable releasing pulling the control handle."
It results that self-releasing is considered a normal and reliable procedure.
Old June 4th 20, 11:58 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Over a couple of hundred winch launches on TOST hooks in a variety of gliders, I have seen one problem, which was caused by one of the two springs inside the hook failing, and the failure caused the hook to release (on a friend's glider, not mine or the club's). I have every confidence in the TOST system when winching; our procedure was to release manually, but if a thermal kept the cable tight, the hooks automatically back-released very reliably.
Keeping track of the number of releases and getting the hook refurbished when due is smart, as is keeping it lubricated and clean.
Old June 5th 20, 05:19 AM posted to rec.aviation.soaring
son_of_flubber
Is this a very reliable disconnect,...?
It's very reliable if the Tost hook is maintained/rebuilt on the recommended schedule. But the maintenance costs money, so it is not altogether unheard of to delay the maintenance past the recommended interval. I know one IA who was OK with that because the total number of releases was very low for the elapsed time.
Old June 5th 20, 03:13 PM posted to rec.aviation.soaring
WB
I have never heard of a TOST CG release failing to "back release". The back "jaw" of the TOST CG hook is held closed only by light spring tension. If there is any rearward pressure on it, it has to release. The spring tension is light enough that it is easy to attach the tow ring to the hook simply by pushing the ring against the back jaw of the release. Not many ways that it can fail. A foreign body or broken part falling into the mechanism could conceivably jam it and prevent it from opening. Some of the older TOST CG releases could have a problem with the tow ring jamming sideways in the release. Gliders with those model TOST releases require installation of small metal guides to prevent misalignment of the ring. Those metal guides also act as protective skids if one forgets to extend the landing gear upon landing (one guess as to how I know this).
I think most of the "failure to release" problems for gliders launching with the CG release have not actually involve the CG release as such. Rolling over the launch cable and entangling it in the wheel have been the cause of some incidents. That is why ground launch systems MUST have some means of quickly cutting the cable.
Old June 5th 20, 03:32 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Look at the belly of a Std Libelle to see this setup (s/n 110 or earlier).
There's now a UK annual inspection requirement to check that the guide
spacing is in tolerance.
Martin | martin at
Gregorie | gregorie dot org
Old June 6th 20, 12:09 AM posted to rec.aviation.soaring
George Haeh
I use the back release to hook up and release for ground towing. Basically the cage rotates back and makes room for the tow ring to enter and engage when the cage rotates forward. Strong fingers needed.
Most hooker uppers can learn this - easier in small clubs than at a contest with many newbie volunteers.
Even if the cage spring breaks, back release will work.
Old June 6th 20, 01:00 AM posted to rec.aviation.soaring
Default How reliably do CG hooks disconnect when the angle of the rope exceeds the autorelease angle
So do I, but not with the hook model on my Libelle: its situated between
two fore/aft rails 32mm apart and the end of the back-release isn't a
grabbable cage, big enough or shaped suitably to be pulled back from the
outside.
On the ASK-21, Puchacz, Juniors and Discii its very easy to do.
Martin | martin at
Old June 9th 20, 12:59 AM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
Before I bought my Ventus a, the previous owner rotated the hook backwards as per Schempp instructions to reduce early back releasing. The slot the back release hook moves in wasn't enlaged to the rear and the next time the glider was winch launched it wouldn't release backwards or via a pull on the release.
The process of rotating the hook had also effectively lengthened the release cable and it ended up bottoming out the lever arrangement, that transferred the pull back to the hook, against a bulkhead.
The winch driver didn't cut the cable and the winch was getting destabilised as the glider went through about 45 degress down towards the ground behind the winch. Going through about 400' with lots of frantic pulling on the release and the stick the cable finally let go and the day was saved.. Some badly shaken people and the hook installation got a good working over to ensure that it couldn't happen again
Colin
Old June 9th 20, 03:08 PM posted to rec.aviation.soaring
Dan Marotta
Default How reliably do CG hooks disconnect when the angle of theropeexceeds the autorelease angle
I was taught that, if unable to release, the glider should circle the
winch rather than slingshot towards the ground.Â* And why wouldn't the
driver cut the cable as soon as the glider overflew the winch and
started down?Â* Training...
again
Colin
Dan, 5J
Aluminum angle Lou Home Built 11 June 25th 07 11:57 PM
Blue Angle #3 Elmshoot Naval Aviation 10 May 24th 04 10:35 PM
Another angle... tongaloa Home Built 0 February 27th 04 11:13 PM
The Dan Rather Angle Dude Owning 7 January 18th 04 09:10 PM
Angle of climb at Vx and glide angle when "overweight": five questions Koopas Ly Piloting 16 November 29th 03 10:01 PM
