Aluminum angle
Old June 22nd 07, 09:36 PM posted to rec.aviation.homebuilt
Lou
Default Aluminum angle
Does anyone know where I can get 6061 or 2024 aluminum angle
or tubing 1/8inch thick with at least one side 5-6 inches wide?
Lou
Old June 22nd 07, 09:42 PM posted to rec.aviation.homebuilt
Blueskies
"Lou" wrote in message ups.com...
Lou
http://schupanalum.thomasnet.com/vie...easuresortid=0
Old June 22nd 07, 09:44 PM posted to rec.aviation.homebuilt
Blueskies
"Blueskies" wrote in message t...
Lou
Oops, just realized you said 1/8 thick...don't see any of that...
Old June 22nd 07, 10:13 PM posted to rec.aviation.homebuilt
Bob Kuykendall
Lou
Wow, that's an odd one.
The profile is doable, but I don't know of any commercial sources for
it. I'm betting it's going to come out real pricey if you do find any.
Unless you need more than 4 or 8 feet of it, you may have better luck
getting 1/8" 2024 and having it bent on a brake. Or build the section
up from available angle and strip using rivets or screws.
Good luck, Bob K.
Old June 22nd 07, 11:09 PM posted to rec.aviation.homebuilt
John Kimmel
Lou
You can rivet a piece of extrusion to a web, or you can bend a piece of
flat sheet.
John Kimmel
I think it will be quiet around here now. So long.
Old June 23rd 07, 12:34 AM posted to rec.aviation.homebuilt
Dan[_2_]
Lou
Speedymetals.com has angle with 5" and 6" legs, but and 3/8" and
1/2" thickness respectively.
Dan, U.S. Air Force, retired
Old June 23rd 07, 12:38 AM posted to rec.aviation.homebuilt
Doug Palmer
Try Alan Steel in Redwood city CA, They will not have the 2024 but they
stock a lot of 6061 extrusions.
D
Lou
Old June 25th 07, 01:41 AM posted to rec.aviation.homebuilt
Charlie Smith
metalsupermarkets.com has 6063T52 unequal angle (5X3 or 5X4) in 1/8 inch.
Charlie
"Doug Palmer" wrote in message
. net...
D
Lou
Old June 25th 07, 01:33 PM posted to rec.aviation.homebuilt
Lou
Yea, I've found the 6063 everywhere. Now if you can tell me the
difference between the 6063 and the 6061
I might learn something. The only stuff I can find is very vague.
Sometimes I think they purposly
don't tell you things.
Lou
Old June 25th 07, 06:14 PM posted to rec.aviation.homebuilt
clare at snyder.on.ca
Lou
6063-T52 Aluminum
Minimum Properties Ultimate Tensile Strength, psi 27,000
Yield Strength, psi 21,000
Brinell Hardness 60
Chemistry Aluminum (Al) 97.5% max
Chromium (Cr) 0.1% max
Copper (Cu) 0.1% max
Iron (Fe) 0.35% max
Magnesium (Mg) 0.45 - 0.90%
Manganese (Mn) 0.1% max
Silicon (Si) 0.2 - 0.6%
6061-T6 Aluminum
Physical and Mechanical Properties Ultimate Tensile Strength, psi
45,000
Yield Strength, psi 40,000
Brinell Hardness 95
Rockwell Hardness B60
Chemistry Aluminum (Al) 95.8 - 98.6%
Chromium (Cr) 0.04 - 0.35%
Copper (Cu) 0.15 - 0.40%
Magnesium (Mg) 0.8 - 1.2%
Manganese (Mn) 0.15% max
Silicon (Si) 2.8 - 3.8%
Zinc (Zn) 1.5% max
So 6063 is about HALF the strength of 6061. A bit better than half as
hard. No zink, very little Silicon, half the magnesium, quarter the
copper, etc etc.
Totally different stuff (generally used for architectural extrusions -
non structural)
Posted via a free Usenet account from http://www.teranews.com
aluminum rib, aluminum spar, holes drilled but screws broken off jls Home Built 13 January 3rd 07 08:06 AM
A 'Glenn'ish' angle . . . alf blume Aviation Photos 6 December 6th 06 01:16 AM
Another angle... tongaloa Home Built 0 February 27th 04 11:13 PM
The Dan Rather Angle Dude Owning 7 January 18th 04 09:10 PM
Angle of climb at Vx and glide angle when "overweight": five questions Koopas Ly Piloting 16 November 29th 03 10:01 PM
