Parachute Static Line?
Old June 14th 20, 08:28 PM posted to rec.aviation.soaring
Dee[_2_]
Default Parachute Static Line?
There was a question posed on parachute static lines from a previous thread that I don't think was addressed. How do you configure one? How long and strong a cable and what kind of clips to use? Some cockpits have an attachment ring for this purpose, but where do you clip it for those that don't?
Original Post: "Any comments on static lines?
My S-H glider has an in cockpit attachment point for a static line.
I am interested in comments on bailing out in am emergency.
Not as interested in the captain obvious comments like "you could accidentally open your chute after a normal landing getting out of your glider". That is implicit and obvious.Thoughts on actual emergency bailouts, static line versus regular D handle?"
Old June 15th 20, 05:11 AM posted to rec.aviation.soaring
Mike N.
That was my question.
The general advice I received was to ask a qualified rigger.
I am still very interested in doing a static line conversion to my parachute, just have not had the time to follow up on it.
Further information is of course appreciated.
Old June 16th 20, 03:02 PM posted to rec.aviation.soaring
Charles Dutch
After Dave Nadler’s presentation at the Little Rock SSA convention I asked for the same advice you’re looking for. His response was very emphatically that a qualified parachute rigger is the only one who should install the line. He said I should take a picture of the attach point in the glider, and have the rigger install the static line per your parachute’s requirements. I suspect he’d be willing to post his reply with the points he made to me.
Old June 16th 20, 09:10 PM posted to rec.aviation.soaring
Karl Striedieck[_2_]
I've used static lines for 40 years that connect the D ring on the parachute to the factory provided connection in the ship. Could make a difference if you bang your head going out or can't find the D ring (happened to me once sky diving).
The idea came from flying fighters in the 60's and 70's that had what was called a "zero delay lanyard" that connected the D ring on the chute to the ejection seat. This lanyard was connected before take off and removed above a couple thousand feet, and then reconnected before landing. You didn't want the chute opening immediately at high altitude or high air speeds.
The length of mine is half a wing span, with the nylon strapping layered together and contained by rubber bands. See pics at:
http://karlstriedieck.com/Parachute_Lanyard.pdf
Make sure the tube your D ring cable runs through is securely sewn to the harness so that an out-of-alignment yank by the lanyard doesn't rip it loose..
Karl Striedieck karls at uplink.net
Old June 17th 20, 02:36 AM posted to rec.aviation.soaring
You probably wanted to disconnect it AFTER landing also, lest your immediate charge off the flight line in search of a beer render you a victim of unintended cross-country excursions on a windy day.
Old June 17th 20, 01:19 PM posted to rec.aviation.soaring
https://www.youtube.com/watch?v=9Kx-buGUOhw
I love the way he just kept pontificating as the chute slowly filled, and then when he "helped" it along. Lucky he was in a nice grassy English field. In New Mexico or Arizona, he would be looking for Band-Aids and tweezers. Or maybe Vise-Grips.
Old June 17th 20, 02:36 PM posted to rec.aviation.soaring
Thanks, that was a delightful morning wakeup.
His chest strap had a quick release that didn't look all that quick when he needed it.
When I bought my Softe, Allen suggested a normal buckle with the tail looped back on itself for quick release. Wonder if that works better?
Old June 17th 20, 01:00 PM posted to rec.aviation.soaring
At last, very helpful! Thank you KS.
Dee
CASA C-212 Aviocar pics 3 [5/5] - USASOAC C-212 conducting static-line parachute operations.jpg (1/1) Miloch Aviation Photos 0 August 26th 18 03:02 PM
Chutes - manual or static line (automatic)? [email protected] Soaring 3 May 3rd 12 02:25 PM
Static Line Parachutes GM Soaring 4 January 14th 08 12:08 AM
Sharing static and pitot line Istvan Csonka Soaring 13 March 12th 05 03:00 AM
Getting students to line up with the center line BoDEAN Piloting 27 April 21st 04 11:23 AM
