Getting students to line up with the center line
Old April 9th 04, 05:54 AM
BoDEAN
Default Getting students to line up with the center line
I'm having an issue with 2 students.
One has a hard time lining up/staying lined up with the center line
(no wind and xwind). I keep telling him "toes forward" and "Have the
center line cut through your body"
Still not grasping it.
The other student, likes to be 10-20 degrees angled left / right of
center line before touching down (ie. side loading)
Any tips?
Old April 9th 04, 06:19 AM
Orval Fairbairn
Any tips?
I was always taught to line up on the side from which the wind is
blowing, in order to take advantage of any runway crown, for crosswind
takeoffs.
Old April 9th 04, 06:21 AM
ArtP
I started flying at 58 and after 43 years of driving in my lane it
took a lot of practice before I could remember to straddle the line.
Old April 9th 04, 07:12 AM
Casey Wilson
"BoDEAN" wrote in message
Any tips?
I'll tell you what my first instructor did to me after repeated
admonitions about not landing in the middle of the runway. I dunno, maybe I
figured the feet on the Aerobat could fit twenty or thirty times across the
width of the runway -- what's so critical, anyway.
Well, came time for some cross country night flying. Bob M. had me fly
across the valley and over the hills to Trona. I hadn't been there before,
even in the daytime so my tension was up about pucker-factor four when Bob
said to make the approach with a simulated landing light failure. No sweat,
been there and done that once or twice for practice at the home patch.
Downwind, base, final -- the runway lights were lined up pretty good, I was
a little (maybe a wing width or two) from the centerline but the right
margin was way over there to the side. Plenty of room.
I flared, the stall horn beeped, and I touched down... TO THE GOD
AWFULLEST RACKET I'D EVER HEARD!!!. Pucker factor at ten! Shove the carb
heat and throttle full forward! Pull the nose up! The NOISE went away.
"What the hell was that?" I asked when I finally remembered to breathe.
"Turn downwind, now. Shoot another approach and use the landing light
this time," he said.
Remember I said I'd not flown to Trona before? When I turned final, I
saw what the noise was. The paved surface of the runway was a tiny narrow
strip of pavement between rows of lights that were five times wider with
desert between.
Bob's only comment was, "I've told you to use the middle of the runway
enough times. I don't want to tell you again."
To this day, it takes a helluva crosswind to move that white stripe
outside my gear span.
Old April 9th 04, 11:58 AM
Bob Noel
In article , BoDEAN
Any tips?
I know this doesn't help you, but...
During my instrument instruction, my CFII was tired of me landing to
the left of centerline on a 150' wide runway. He took me to TEWMAC,
which was (iifc) 26' wide. When I landed on the runway he said "see!,
I knew you could land on the centerline." I replied that I can when
it matters. I still land left of centerline on wide runways.
Bob Noel
Old April 9th 04, 06:58 PM
Ben Jackson
For me the experience of landing on narrower runways 'stuck' and cured
my laziness about hitting the centerline of a 150' wide runway.
I think my offcenter landings were mostly due to my tendancy to 'settle'
for configurations that are good enough, if not perfect. So if I got
lined up on the left side of the runway with my perfect slip in I wasn't
going to mess with that just to fly over to the centerline and then have
to get the slip dialed in again.
Ben Jackson
http://www.ben.com/
Old April 9th 04, 09:32 PM
John Gaquin
"Ben Jackson" wrote in message news:gvBdc.464
Bob Noel wrote:
......I can when
You've got it, Ben. Fact is, you could land a Boeing along one side of the
runway if you wanted to. Lots of people settle for adequacy, but you don't
see much of that among people who have developed a sense of discipline and
professionalism.
Old April 9th 04, 09:36 PM
John Gaquin
"Bob Noel" wrote in message
...He took me to TEWMAC,
I remember TewMac.... very narrow, with Rt 38 right over the fence, and the
fried clam place right there beside the runway end. Yum! Used to take a
310 in and out of there sometimes years ago. All gone now, nothing but
condos, but the eatery is still there, I think.
Old April 19th 04, 03:31 AM
DP
On Fri, 09 Apr 2004 10:58:11 GMT, Bob Noel
In article , BoDEAN
Any tips?
Correct........ TEWMAC was 26 feet..... or two plow blades wide, if
you prefer...
Don Paquette
PP-ASEL
N9723X
Old April 19th 04, 04:43 AM
Rob McDonald
In article , BoDEAN
Any tips?
This is from the point of view of a student who is just waiting for his
check ride. I had both problems for a while...
The angled landings occurred early in my training, primarily due to
"information overload." Not enough was happening automatically yet, I had
to think through everything I was doing. As my landings got better in other
respects, I had more time to focus on and fix this problem. I think I was
more concerned about how hard we collided with the ground than at what
particular angle :-)
The alignment problem lasted a lot longer. Our main runway is 75' wide, I
was always to the left of center. It seems that I just didn't have "the
picture" quite right. My instructors reminded me periodically and as my
training progressed my landings migrated to the center. It took most of the
training period to fix that one, and even now I catch myself left of center
on final occasionally.
I am training in a C172. It will be interesting to see what happens when I
transition to my Champ.
Rob
Bush's Attempt to Usurp the Constitution WalterM140 Military Aviation 20 July 2nd 04 04:09 PM
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 04:24 AM
FAA Investigates American Flyers SFM Instrument Flight Rules 57 November 7th 03 09:33 PM
FAA Investigates American Flyers SFM Piloting 64 November 7th 03 09:33 PM
CAD outline of Rans S6S instrument panel? Rob Turk Home Built 2 October 21st 03 09:27 PM
