Hi Pilots,
I usually do analysis on my flights and those of other pilots I flew with to try understand what I did right or wrong and what I can learn from pilots better than me. A recent flight on OLC showed that I circled 15.5% of the time at an average of 3.3m/s (about 6.4 kts). Opening the .igc file in SeeYou it showed 20% and an average 4.9 kts. Can any of you shed light on how these differences occurred? Thanks, Bob |
Hi Bob -
I'd guess that OLC is just showing you the stats for your 6 leg OLC scoring. SeeYou stats are for the entire flight. Either way - that's a great flight - both % of circling and thermal strength! Lou |
I recall Seeyou has parameters that define what count as circling (time based IIRC). So a single circle may or may not count as circling.
Ramy |
On Tuesday, August 11, 2020 at 6:04:09 PM UTC-4, Bob Caldwell (BC) wrote:
Hi Pilots, I usually do analysis on my flights and those of other pilots I flew with to try understand what I did right or wrong and what I can learn from pilots better than me. A recent flight on OLC showed that I circled 15.5% of the time at an average of 3.3m/s (about 6.4 kts). Opening the .igc file in SeeYou it showed 20% and an average 4.9 kts. Can any of you shed light on how these differences occurred? Thanks, Bob You can set "marker 1" and "marker 2" in SeeYou (right click...), then look at the "selection" tab under stats to see the stats for that specific segment. Typically, one might do this for the start/finish of a task to cut out the pre-start meandering and post finish pattern/landing. T8 |
Check out video #13 from my SeeYou training videos playlist.
Maybe the optimized task in SeeYou will match the OLC statistics. https://www.youtube.com/playlist?lis...pHhJtdi_7kK7Xm |
On Tuesday, August 11, 2020 at 7:32:30 PM UTC-7, Dave Springford wrote:
Check out video #13 from my SeeYou training videos playlist. Maybe the optimized task in SeeYou will match the OLC statistics. https://www.youtube.com/playlist?lis...pHhJtdi_7kK7Xm Thanks for all the videos you have done! |
There are many different algorithms of analysing flight performance, and they all have small and subtle differences in what they regard as thermalling, cruising, turning and the likes.
I'm currently working on developing https://skyhop.org as a way to analyse flight performance without having to hassle with IGC files, and I bet it'll show a different value again given I'm using a value calculated by an XCSoar derivative. Only limitation right now is that you would need Flarm in your glider (and again, this collection method would also skew data a bit). Ps, I'm just starting out on this endeavour, so if anyone has feedback on the tool, I'd love to hear about it! |
Full Analysis Of The First Flight Of Russia's 'Hunter' Unmanned Combat Air Vehicle [2/5] - A look at the rear of the S-70 from the flight test video.png (1/1) | Miloch | Aviation Photos | 0 | August 8th 19 04:55 AM |
Cloudstreet flight analysis now available on Crosscountry.aero | Alexander Georgas[_2_] | Soaring | 4 | October 19th 14 06:51 PM |
GPS Flight Data Analysis | atlee | Aviation Marketplace | 0 | October 20th 12 08:37 AM |
IGC File / Flight-track Analysis | noel.wade | Soaring | 17 | January 22nd 10 09:00 PM |
Polar Analysis from flight logs? | Mark Zivley | Soaring | 87 | January 13th 05 12:34 AM |
